查看: 2320|回复: 0
求助bojectarx高手关于jig类画固定长度的多段线
发表于 2010-11-29 11:41:11 | 显示全部楼层 |阅读模式
jig头文件:class CDrawESL_Jig : public AcEdJig
public:
CDrawESL_Jig();
CDrawESL_Jig(AcDbPolyline *pPLine);
virtual ~CDrawESL_Jig();
//设置匀坡线长度
void SetLength(double rLength){ m_rESLLength = rLength;} //开始拖动
DragStatus StartDrag(); //获取点坐标数组
void GetPoints(AcGePoint3dArray & arPoints) const; //采样函数
    virtual DragStatus sampler();  //更新实体绘图
    virtual Adesk::Boolean  update();    virtual AcDbEntity* entity() const{return m_pPLine;}
private:
//匀坡线长度
double m_rESLLength;
AcDbPolyline *m_pPLine;
AcGePoint3d m_CurPoint;
AcGePoint3dArray m_Points;
};jig类的代码:CDrawESL_Jig::CDrawESL_Jig()
m_pPLine = new AcDbPolyline(); m_rESLLength = 10;
}CDrawESL_Jig::CDrawESL_Jig(AcDbPolyline *pPLine)
m_pPLine = pPLine; //从AcDbPolyline *实体中提取点坐标, 写入m_Points
int i;
AcGePoint3d GPt;
for (i = 0; i < m_pPLine->numVerts(); i++)
  m_pPLine->getPointAt(i, GPt);
  m_Points.append(GPt);
// m_Points.append(AcGePoint3d(0.0,0.0,0.0));
}CDrawESL_Jig::~CDrawESL_Jig()
if (m_pPLine != NULL) delete m_pPLine;
m_pPLine = NULL;
}//获取点坐标数组
void CDrawESL_Jig::GetPoints(AcGePoint3dArray & arPoints) const
while (arPoints.length() != 0)
  arPoints.removeFirst(); arPoints.append(m_Points); return;
}//***************开始拖动***************
AcEdJig::DragStatus CDrawESL_Jig::StartDrag()
if (m_Points.length() == 0)
  setDispPrompt(_T("\n请指定第一个点:"));
else
  setDispPrompt(_T("\n请指定下一个点:"));
} AcEdJig::DragStatus Sta = drag();
if (Sta == AcEdJig::kNormal)
  m_Points.append(m_CurPoint);
return Sta;
}//***************采样函数***************
AcEdJig::DragStatus CDrawESL_Jig::sampler()
setUserInputControls( ( UserInputControls )
        ( kNullResponseAccepted | kAccept3dCoordinates | //kGovernedByOrthoMode  |
  kDontUpdateLastPoint | kNoZeroResponseAccepted));
DragStatus stat;
AcGePoint3d CurPoint;//  if (m_Points.length() == 0)
//   stat = acquirePoint(CurPoint);
//  else
//  stat = acquirePoint(CurPoint, m_Points[m_Points.length() - 1]);
stat = acquirePoint(CurPoint); //判断鼠标是否移动
if (stat == AcEdJig::kNormal)
  if (m_CurPoint.distanceTo(CurPoint) < 1e-6)
   return AcEdJig::kNoChange;
  else m_CurPoint = CurPoint;
return stat;
} //***************更新实体绘图*************************************
Adesk::Boolean  CDrawESL_Jig::update()
/*AcDbObjectId EntId;*/
ads_point basePt, resultPt, RefPt; RefPt[X] = m_CurPoint.x;
RefPt[Y] = m_CurPoint.y;
RefPt[Z] = m_CurPoint.z; ads_printf("\n点数:%d", m_Points.length());
  return Adesk::kTrue;
else
  basePt[X] = m_Points[m_Points.length() - 1].x;
  basePt[Y] = m_Points[m_Points.length() - 1].y;
  basePt[Z] = m_Points[m_Points.length() - 1].z;  double rAngle = ads_angle(basePt, RefPt);
  ads_polar(basePt, rAngle, m_rESLLength, resultPt);
  m_CurPoint = AcGePoint3d(resultPt[X], resultPt[Y], resultPt[Z]);
  m_pPLine->setPointAt(m_Points.length(), AcGePoint2d(resultPt[X], resultPt[Y]));
} return Adesk::kTrue;
绘制图像的函数代码://消息处理函数---绘制按钮
void CDialog_DrawESL::OnButtonDraw()
// TODO: Add your control notification handler code here
BeginEditorCommand(); int i;
CDrawESL_Jig *pPLineJig = NULL;
AcEdJig::DragStatus ds;
AcDbObjectId EntId; do {
// pPline = NULL;
  AcDbPolyline *pPline = NULL;  if (pPLineJig == NULL)
   pPLineJig = new CDrawESL_Jig();
   pPLineJig->SetLength(m_rESLLength);
  else
   AcGePoint3dArray arPoints;
   pPLineJig->GetPoints(arPoints);
   if (pPline != NULL) delete pPline;
   pPline = new AcDbPolyline(arPoints.length());   for (i = 0; i < arPoints.length(); i++)
    pPline->addVertexAt(i, AcGePoint2d(arPoints.x, arPoints.y));
   delete pPLineJig;
   pPLineJig = new CDrawESL_Jig(pPline);
  ds = pPLineJig->StartDrag();
  ads_printf("\nDragStatus = %d", ds);
  if (ds != AcEdJig::kNormal)
   CompleteEditorCommand();
   delete pPLineJig;
   return;
}while (ds != AcEdJig::kCancel); delete pPLineJig; CompleteEditorCommand();
} 其中多段线的长度是由一个编辑框传入的数值。可是这个程序最后我发现不知道怎么把画出的多段线添加进数据库,无法显示出来。而且我想要的效果是鼠标点一个点,拖动的虚拟线并不是到鼠标当前点,只是到我求出来的resultPt请高手帮我看一下错在什么地方。
附件中是我建立的工程
GMT+8, 2025-5-26 00:34 , Processed in 0.158370 second(s), 25 queries , Gzip On.
