查看: 1834|回复: 5
[基础] 如何编辑局部变量和全体变量(用lisp实现焊缝画法)?
发表于 2010-12-6 14:25:56 | 显示全部楼层 |阅读模式
用lisp实现焊缝画法
贱人工具箱里面就有一个
仿照那个编写了一个
方法比较笨
别见笑。
里面的局部变量 和全体变量怎么编辑?
标注后出现错误
(defun c:hf()
(get_data)
(draw)
(prin1)
(defun draw()
  (command "_arc" pts pt1 pt2)
  (setq en1 (entlast))
    (setq pt3 (polar pts (+ ang 0) rad))
    (setq pt4 (polar pt2 (+ ang 0) rad))
    (setq pt5 (polar pt1 (+ ang 0) rad))
  (repeat  (1- nn )
    (command "_arc" pt3 pt5 pt4)
    (setq en2 (entlast))
    (command "_TRIM" en1 "" (list en2 pt3 ) "")
   (setq  en1 en2)
    (setq pt3 (polar pt3 (+ ang 0) rad))
    (setq pt4 (polar pt4 (+ ang 0) rad))
    (setq pt5 (polar pt5 (+ ang 0) rad))
(defun get_data()
  (setq pts (getpoint"\n 请输入起点:"))
  (setq pte (getpoint pts"\n 请输入终点:"))
  (setq rad (getreal"\n请输入半径<1>:"))
  (if (null rad) (setq rad 1))
  (setq ang (angle pts pte))
  (setq pt2 (polar pts (+ ang 0) (* rad 2)))
  (setq pt1 (polar pts (+ ang (/ pi 4)) (* rad (sqrt 2))))
  (setq dd (distance pts pte))
  (setq  nn (fix (/ dd rad)))
发表于 2010-12-6 18:16:32 | 显示全部楼层
局部变量你要在你的(defun c:hf (/ pts pt1 pt2.....)....)声明,如果未在斜线后声明的话,将是全局变量。不光是在命令中,在你自定义的函数中一样可以声明局部变量,当然你要掌握好你到底需要什么变量。
 楼主| 发表于 2010-12-6 20:26:09 | 显示全部楼层
唉 就是不知道怎么声明
发表于 2010-12-7 21:43:13 | 显示全部楼层
我不是给你例子了吗,LISP中不需要专门的声明语句,只要在斜线后把你的变量名写上去就是局部变量了,不写就是全局变量
发表于 2018-4-29 08:36:39 | 显示全部楼层
修改下:焊缝高度不用输入,用第三点点击即可,这样更准确!
  1. (defun c:hf(/ pts pte rad ang pt1 pt2 pt3 pt4 pt5 dd nn en1 en2)
  2.   (setq pts (getpoint "\n请输入起点: ")
  3.     pte (getpoint pts "\n请输入终点: ")
  4.     pt1 (getpoint pte "\n请点出焊缝厚度: ")
  5.   )
  6.   (setq rad (distance pte pt1))
  7.   (setq ang (angle pts pte))
  8.   (setq pt2 (polar pts (+ ang 0) (* rad 2)))
  9.   (setq pt1 (polar pts (+ ang (/ pi 4)) (* rad (sqrt 2))))
  10.   (setq dd (distance pts pte))
  11.   (setq  nn (fix (/ dd rad)))
  12.   (command "_arc" pts pt1 pt2)
  13.   (setq en1 (entlast))
  14.   (setq pt3 (polar pts (+ ang 0) rad))
  15.   (setq pt4 (polar pt2 (+ ang 0) rad))
  16.   (setq pt5 (polar pt1 (+ ang 0) rad))
  17.   (repeat  (1- nn )
  18.     (command "_arc" pt3 pt5 pt4)
  19.     (setq en2 (entlast))
  20.     (command "_TRIM" en1 "" (list en2 pt3 ) "")
  21.     (setq  en1 en2)
  22.     (setq pt3 (polar pt3 (+ ang 0) rad))
  23.     (setq pt4 (polar pt4 (+ ang 0) rad))
  24.     (setq pt5 (polar pt5 (+ ang 0) rad))
  25.   )
  26.   (prin1)
  27. )
发表于 2018-4-29 08:57:05 | 显示全部楼层
就是
(defun c:hf ( / ))
括号里 斜杠前面的是局部变量 斜杠后面的是全局变量
GMT+8, 2025-10-25 03:47 , Processed in 0.172251 second(s), 26 queries , Gzip On.
