查看: 1996|回复: 7
[基础] 修改多选择性替换
发表于 2010-12-12 15:28:27 | 显示全部楼层 |阅读模式
以下块替换程序是我在论坛看到由狐哥编写的,此程序实现一次单选一个块来进行替换,
我现将此程序再贴出来,是想请老师帮助修改成一次性可以选择多个块进行替换。。。
 楼主| 发表于 2010-12-12 15:29:05 | 显示全部楼层
  1. public static void tt1()
  2.         {
  3.             Document doc = Application.DocumentManager.MdiActiveDocument;
  4.             Editor ed = doc.Editor;
  5.             PromptEntityOptions optsEnt = new PromptEntityOptions("\nSelect a Block:");
  6.             optsEnt.SetRejectMessage("\nNot a Block!");
  7.             optsEnt.AddAllowedClass(typeof(BlockReference), false);
  8.             PromptEntityResult resEnt = ed.GetEntity(optsEnt);
  9.             if (resEnt.Status == PromptStatus.OK)
  10.             {
  11.                 PromptResult resStr = ed.GetString("\nInput BlockName:");
  12.                 if(resStr.Status == PromptStatus.OK)
  13.                 {
  14.                     Database db = doc.Database;
  15.                     using (Transaction tr = db.TransactionManager.StartTransaction())
  16.                     {
  17.                         BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
  18.                         BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  19.                         string blkname = resStr.StringResult;
  20.                         if(bt.Has(blkname))
  21.                         {
  22.                             BlockReference blkref = (BlockReference)tr.GetObject(resEnt.ObjectId, OpenMode.ForWrite);
  23.                             BlockReference blkrefnew = new BlockReference(blkref.Position, bt[blkname]);
  24.                             blkrefnew.BlockTransform = blkref.BlockTransform;
  25.                             btr.AppendEntity(blkrefnew);
  26.                             tr.AddNewlyCreatedDBObject(blkrefnew, true);
  27.                             foreach(ObjectId attid in blkref.AttributeCollection)
  28.                             {
  29.                                 AttributeReference att = (AttributeReference)tr.GetObject(attid, OpenMode.ForRead);
  30.                                 AttributeReference attnew = (AttributeReference)att.Clone();
  31.                                 blkrefnew.AttributeCollection.AppendAttribute(attnew);
  32.                                 tr.AddNewlyCreatedDBObject(attnew, true);
  33.                             }
  34.                             blkrefnew.XData = blkref.XData;
  35.                             blkref.Erase();
  36.                             tr.Commit();
  37.                         }
  38.                     }
  39.                 }
  40.             }
  41.         }
 楼主| 发表于 2010-12-12 16:42:24 | 显示全部楼层
自己先顶一下...
发表于 2010-12-12 18:37:15 | 显示全部楼层
似乎用.NET也不能绝对化,例如这种问题,lisp一行就能解决,且特性、XData、EDictionary自动继承。
(vla-put-Name objRef BlockName)
发表于 2010-12-12 18:49:54 | 显示全部楼层
汗,不知道什么时候的代码
其实NetApi也是一句话
            using (var tr = new DBTransaction())
                var ed = tr.Editor;
                var resEnt = ed.GetEntity("\n选择块参照");
                var bref = tr.GetObject<BlockReference>(resEnt.ObjectId, OpenMode.ForWrite);
                bref.BlockTableRecord = tr.BlockTable.GetRecorId("2");
 楼主| 发表于 2010-12-12 21:19:28 | 显示全部楼层
谢谢老师! 你上面这代码是如何用的啊!
发表于 2010-12-13 20:03:15 | 显示全部楼层
把块名为“2”的块定义的Id赋值给块参照的BlockTableRecord 属性
 楼主| 发表于 2010-12-13 22:46:48 | 显示全部楼层
请问老师,这个DBTransaction函数是你自己写的吧...
GMT+8, 2025-5-11 09:18 , Processed in 0.170609 second(s), 24 queries , Gzip On.
