查看: 2992|回复: 6
[基础] 单行文字齐的属性
发表于 2010-12-15 21:30:26 | 显示全部楼层 |阅读模式
请教老师: 单行文字中心对齐属性设置是那个函数(我设置为Center不对,请问应该是什么)
txent.AlignmentPoint = Center;
另外单行文字宽度是那个属性
发表于 2010-12-15 21:46:14 | 显示全部楼层
DBText.Justify Property
DBText.WidthFactor Property
 楼主| 发表于 2010-12-16 12:30:18 | 显示全部楼层
请问老师我设置文字以中心对齐这一句(txent.AlignmentPoint = Center;)编译出错,应该如何写这一句,请帮助指正...
发表于 2010-12-16 18:18:08 | 显示全部楼层
  1.         [CommandMethod("t2")]
  2.         public static void Test2()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Editor ed = doc.Editor;
  6.             Database db = doc.Database;
  7.             using(var tr = db.TransactionManager.StartTransaction())
  8.             {
  9.                 DBText txt = new DBText();
  10.                 txt.TextString = "ABC";
  11.                 txt.Justify = AttachmentPoint.MiddleCenter;
  12.                 txt.AlignmentPoint = new Point3d(10, 10, 0);
  13.                 txt.SetDatabaseDefaults();
  14.                 var btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
  15.                 AddEntity(tr, btr, txt);
  16.                 tr.Commit();
  17.             }
  18.         }
 楼主| 发表于 2010-12-16 19:31:52 | 显示全部楼层
谢谢老师的指点,问题已解决。。。
另外再请教一下单行文字角度是那个属性?
发表于 2010-12-16 20:57:43 | 显示全部楼层
这个在文档很容易就查到的
最好的老师是帮助啊
Autodesk.AutoCAD.DatabaseServices Namespace > DBText Class > DBText Properties > DBText.Rotation Property
Collapse AllC#
[UnitType(Autodesk.AutoCAD.DatabaseServices.UnitType.Angle), Category("Text")]
public double Rotation;
Visual Basic
<UnitType(Autodesk.AutoCAD.DatabaseServices.UnitType.Angle), Category("Text")>
Public Property Rotation() As double
Description
Accesses the rotation angle of the text. The rotation angle is relative to the X axis of the text's OCS, with positive angles going counterclockwise when looking down the Z axis towards the origin. The OCS X axis is determined by using the text's normal, the WCS Z axis, and the arbitrary axis algorithm.
Conditions
Read / Write
Links
DBText Class, Autodesk.AutoCAD.DatabaseServices Namespace
 楼主| 发表于 2010-12-17 12:31:42 | 显示全部楼层
谢谢老师提供的帮助,我英文差,看的似懂非懂...
GMT+8, 2025-6-3 07:14 , Processed in 0.174858 second(s), 23 queries , Gzip On.
