查看: 9775|回复: 13
[界面] PaletteSet
发表于 2010-12-29 15:06:01 | 显示全部楼层 |阅读模式
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Drawing;
using System.Data;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.Runtime;
namespace Palette
    public partial class ModelessForm : UserControl
        private Autodesk.AutoCAD.Windows.PaletteSet palSet;
        public ModelessForm()
            InitializeComponent();
        public void AddPalette()
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            try
                if (palSet == null)
                    palSet = new PaletteSet("My Palette");
                    palSet.Style = PaletteSetStyles.ShowTabForSingle;
                    palSet.Style = PaletteSetStyles.NameEditable;
                    palSet.Style = PaletteSetStyles.ShowPropertiesMenu;
                    palSet.Style = PaletteSetStyles.ShowAutoHideButton;
                    palSet.Style = PaletteSetStyles.ShowCloseButton;
                    palSet.Opacity = 90;
                    palSet.MinimumSize = new System.Drawing.Size(300, 300);
                    System.Windows.Forms.UserControl myPageCtrl = new ModelessForm();
                    palSet.Add("My Palette",ModelessForm);
                    palSet.Visible = true;
            catch {
                ed.WriteMessage("Create panel set wrong");
帮忙看下红色标记的哪里错了?
发表于 2010-12-29 16:42:49 | 显示全部楼层
报的什么错?你的Cad版本?
另外,你可以看下ObjectArxSdk下dotNet的例子DockingPalette
 楼主| 发表于 2010-12-29 22:56:13 | 显示全部楼层
Error        1        The type 'System.Windows.Interop.IWin32Window' is defined in an assembly that is not referenced. You must add a reference to assembly 'PresentationCore, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.        E:\learning Example\AutoCAD.NET API\CeateOpject\Palette\Palette\ModelessForm.cs        20        53        Palette
就是这个
发表于 2010-12-29 22:57:56 | 显示全部楼层
添加引用->PresentationCore
发表于 2010-12-30 10:19:02 | 显示全部楼层
你似乎想在一个非模式窗口中显示paletteset?好像不是这么做吧
 楼主| 发表于 2010-12-30 10:54:53 | 显示全部楼层
是无模式窗体,我只是写了个创建的
 楼主| 发表于 2010-12-30 11:30:51 | 显示全部楼层
using System;
using System.Data;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsSystem;
using System.IO;
namespace palette2
            label5.MouseMove += new System.Windows.Forms.MouseEventHandler(label5_MouseMove);
        //createPaletteSet
        [CommandMethod("CreatePaletteSet")]
            try
                if (palSet == null)
                    palSet = new PaletteSet("MyPalette");
                    palSet.Add("MyPalette", myPageCtrl);
            catch
        /// <summary>
        /// click movent
        /// </summary>
        /// <param name="sender"></param>
        /// <param name="e"></param>
        private void label5_MouseMove(object sender, MouseEventArgs e)
            if (System.Windows.Forms.Control.MouseButtons == System.Windows.Forms.MouseButtons.Left)
                //star DropTarge
                Autodesk.AutoCAD.ApplicationServices.Application.DoDragDrop(this, this, System.Windows.Forms.DragDropEffects.All, new MyDropTarget());
    public class MyDropTarget : Autodesk.AutoCAD.Windows.DropTarget
        public override void OnDrop(DragEventArgs e)
            try
                Point3d pt = ed.PointToWorld(new Point(e.X, e.Y));
                using (DocumentLock docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument())
                    //get Data
                   ModelessForm ctrl = (ModelessForm)e.Data.GetData(typeof(ModelessForm));                    //creat Entity
                    Utility.CreateEmployee();
            catch
                ed.WriteMessage("Create fail");
    public class Utility
        public static ObjectId CreateEmployee(String name, String division, Double salary, Point3d pos)
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForWrite);
                BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                // create circle
                Circle cir = new Circle();
                cir.Center = pos;
                cir.Radius = 100;
                cir.ColorIndex = 1;
                btr.AppendEntity(cir);
                trans.AddNewlyCreatedDBObject(cir, true);
                //create record
                Xrecord xRec = new Xrecord();
                xRec.Data = new ResultBuffer(
                    new TypedValue((int)DxfCode.Text, name),
                    new TypedValue((int)DxfCode.Real, salary),
                    new TypedValue((int)DxfCode.Text, division));
                cir.CreateExtensionDictionary();
                DBDictionary brExtDict = (DBDictionary)trans.GetObject(cir.ExtensionDictionary, OpenMode.ForWrite, false);
                brExtDict.SetAt("EmpInfor", xRec);
                trans.AddNewlyCreatedDBObject(xRec, true);
                trans.Commit();
                return cir.ObjectId;
全部的代码,但是出现了问题无法取出控件中的值
 楼主| 发表于 2010-12-30 11:31:46 | 显示全部楼层
能不能帮我看下什么原因.初学者
发表于 2010-12-30 13:09:23 | 显示全部楼层
不是用窗体的,而是用户控件
 楼主| 发表于 2010-12-30 14:47:22 | 显示全部楼层
我是用的用户控件
GMT+8, 2025-5-24 17:12 , Processed in 0.197375 second(s), 24 queries , Gzip On.
