查看: 3245|回复: 6
计算几何源码
发表于 2010-12-30 16:19:47 | 显示全部楼层 |阅读模式
本人收集的一些计算几何源码,包括判断点是否在多边形内,计算多边形面积、方向,直线、线段相交的源码。
bool collinear(double x1, double y1, double x2, double y2, double x3, double y3, double epsilon)
  return (fabs((x2 - x1) * (y3 - y1)  - (x3 - x1) * (y2 - y1)) <= epsilon);
bool point_in_polygon(double px, double py, const polygon<double, 2> &polygon)
bool result = false;
if (polygon.size() < 3)
  return false;
std::size_t j = polygon.size() - 1;
for(std::size_t i = 0; i < polygon.size(); ++i)
  if (((polygon[i].y <= py) && (py < polygon[j].y)) || ((polygon[j].y <= py) && (py < polygon[i].y)))
   if (px - polygon[i].x < ((polygon[j].x - polygon[i].x) * (py - polygon[i].y) / (polygon[j].y - polygon[i].y)))
    result = !result;
  j = i;
return result;
int polygon_orientation(LPPOINT pp, int n)
double t = 0;
for(int i = 1; i <= n-1; i++)
  t += pp[i-1].x*pp[i].y - pp[i].x*pp[i-1].y;
t += pp[n-1].x*pp[0].y - pp[0].x*pp[n-1].y;
return t < 0 ? CounterClockwise : Clockwise;
int polygon_orientation(const polygon<T, 2> &polygon)
if(polygon.size() < 3)
  return 0;
double area = double(0.0);
std::size_t prev_index = polygon.size() - 1;
for(std::size_t index = 0; index < polygon.size(); ++index)
  area += (polygon[prev_index].x * polygon[index].y - polygon[index].x * polygon[prev_index].y);
  prev_index = index;
return (((area >= double(0.0))) ? CounterClockwise : Clockwise);
double area(const polygon<double,2>& polygon)
  return double(0.0);
double result = double(0.0);
  result += ((polygon[j].x * polygon[i].y) - (polygon[j].y * polygon[i].x));
  j = i;
return fabs(result * double(0.5));
void intersect_line_to_line(double x3, double y3, double x4, double y4, double x1, double y1, double x2, double y2, double &ix, double &iy)
double dx1 = x2 - x1;
double dx2 = x4 - x3;
double dx3 = x1 - x3;
double dy1 = y2 - y1;
double dy2 = y1 - y3;
double dy3 = y4 - y3;
double ratio = dx1 * dy3 - dy1 * dx2;
if (ratio != 0.0)
  ratio = (dy2 * dx2 - dx3 * dy3) / ratio;
  ix    = x1 + ratio * dx1;
  iy    = y1 + ratio * dy1;
else
  if ((dx1 * -dy2) == (-dx3 * dy1))
   ix = x3;
   iy = y3;
  else
   ix = x4;
   iy = y4;
bool intersect_segment_to_segment(double x1, double y1, double x2, double y2, double x3, double y3, double x4, double y4, double &ix, double &iy)
double ax = x2 - x1;
double bx = x3 - x4;
double lowerx;
double upperx;
double uppery;
double lowery;
if (ax < double(0.0))
  lowerx = x2;
  upperx = x1;
else
  upperx = x2;
  lowerx = x1;
if (bx > double(0.0))
  if ((upperx < x4) || (x3 < lowerx))
   return false;
else if ((upperx < x3) || (x4 < lowerx))
  return false;
double ay = y2 - y1;
double by = y3 - y4;
if (ay < double(0.0))
  lowery = y2;
  uppery = y1;
else
  uppery = y2;
  lowery = y1;
if (by > double(0.0))
  if ((uppery < y4) || (y3 < lowery))
   return false;
else if ((uppery < y3) || (y4 < lowery))
  return false;
double cx = x1 - x3;
double cy = y1 - y3;
double d  = (by * cx) - (bx * cy);
double f  = (ay * bx) - (ax * by);
if (f > double(0.0))
  if ((d < double(0.0)) || (d > f))
   return false;
else if ((d > double(0.0)) || (d < f))
  return false;
double e = (ax * cy) - (ay * cx);
  if ((e < double(0.0)) || (e > f))
   return false;
else if ((e > double(0.0)) || (e < f))
  return false;
double ratio = (ax * -by) - (ay * -bx);
if (ratio != double(0.0))
  ratio = ((cy * -bx) - (cx * -by)) / ratio;
  ix    = x1 + (ratio * ax);
  iy    = y1 + (ratio * ay);
else
  if ((ax * -cy) == (-cx * ay))
   ix = x3;
   iy = y3;
  else
   ix = x4;
   iy = y4;
return true;
发表于 2011-2-15 20:36:09 | 显示全部楼层
是C语言程序吗?
发表于 2011-4-2 13:17:54 | 显示全部楼层
新手来学习一下,多谢分享
发表于 2011-6-18 13:25:52 | 显示全部楼层
好像是C语言写的吧,楼主这些程序在什么环境下运行啊
发表于 2011-6-18 22:14:27 | 显示全部楼层
如果有显卡直接调用opengl或D3D是不是比较方便一些.
发表于 2012-2-6 03:46:07 | 显示全部楼层
C语言程序啊
发表于 2012-9-26 23:36:33 | 显示全部楼层
好东西,谢谢分享!
GMT+8, 2025-5-24 23:22 , Processed in 0.279891 second(s), 23 queries , Gzip On.
