查看: 1911|回复: 6
[基础] 坐标点的精度如何控制
发表于 2011-1-3 13:40:11 | 显示全部楼层 |阅读模式
在拾取坐标时,想把坐标保留到一位小数该怎么表达,望高人指点。
 楼主| 发表于 2011-1-3 15:43:31 | 显示全部楼层
貌似斑竹不在啊
发表于 2011-1-4 10:35:09 | 显示全部楼层
修改设置就可以了
(command "text" ......... (rtos x 2 1))
  (command "text" ........ (rtos y 2 1))
发表于 2011-1-4 11:16:36 | 显示全部楼层
Math.Round
 楼主| 发表于 2011-1-7 16:20:39 | 显示全部楼层
帮我看一下坐标保留到一位小数 如何设置? 求高手帮帮忙!
[CommandMethod("LZ")]
        public void testfunction2()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            SelectionFilter sf = new SelectionFilter(new TypedValue[]{ new TypedValue(0, "Line") });
            PromptSelectionResult psr = ed.GetSelection(sf);
            if (psr.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord curSpace = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                foreach (ObjectId id in psr.Value.GetObjectIds())
                    Entity ent = tr.GetObject(id, OpenMode.ForRead) as Entity;
                    if (ent.GetType() == typeof(Line))
                        Line l = ent as Line;
                        Point3d pt1 = l.StartPoint;
                        Point3d pt2 = l.EndPoint;
                        ed.WriteMessage("\n" + pt1 + pt2);
                    else
                tr.Commit();
发表于 2011-1-7 18:14:21 | 显示全部楼层
            Point3d pt = new Point3d(12.345,56.567,0);
            ed.WriteMessage("\nPoint:{0:f2}", pt);
 楼主| 发表于 2011-1-8 13:51:00 | 显示全部楼层
问题解决,感谢飞狐大哥的帮忙
GMT+8, 2025-5-11 08:51 , Processed in 0.169672 second(s), 23 queries , Gzip On.
