查看: 1418|回复: 3
怎么在已有的块定义增加个圆?
发表于 2011-1-4 21:33:45 | 显示全部楼层 |阅读模式
我想在图中已有的块定义里增加圆,运行结果加了圆 但是会过一会儿就 或者 双击块定义 致命错误了
Public Sub AddCircle()
        '' Get the current document and database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        '' Start a transaction
        Using acLckDoc As DocumentLock = acDoc.LockDocument()
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '' Open the Block table for read
                Dim acBlkTbl As BlockTable
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite)
                '' Open the Block table record Model space for write
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = acTrans.GetObject(acBlkTbl("11"), OpenMode.ForWrite)
                '' Create a circle that is at 2,3 with a radius of 4.25
                Dim acCirc As Circle = New Circle()
                acCirc.SetDatabaseDefaults()
                acCirc.Center = New Point3d(2, 3, 0)
                acCirc.Radius = 4.25
                '' Add the new object to the block table record and the transaction
                acBlkTblRec.AppendEntity(acCirc)
                ' acTrans.AddNewlyCreatedDBObject(acCirc, True)
                acBlkTblRec.Dispose()
                acBlkTbl.Dispose()
                '' Save the new object to the database
                acTrans.Commit()
            End Using
        End Using
    End Sub
 楼主| 发表于 2011-1-4 22:01:25 | 显示全部楼层
"11" 是我预先随便定义的一个块名
发表于 2011-1-4 23:05:01 | 显示全部楼层
这句不要注释掉
 楼主| 发表于 2011-1-5 08:40:12 | 显示全部楼层
呵呵  谢谢 sxpd
GMT+8, 2025-7-16 06:33 , Processed in 0.154747 second(s), 23 queries , Gzip On.
