查看: 2474|回复: 2
[函数] 时间
发表于 2011-1-8 11:22:29 | 显示全部楼层 |阅读模式
  1. (DEFUN C:znowtime(/ OLDOS oldclay PT STA )
  2. ;;
  3. (setq oldclay (getvar "CLAYER"))
  4.   (setq olderr *error*)
  5.   (setq *error* myerr)
  6.   (SETVAR "CMDECHO" 0)
  7.   (SETQ OLDOS (GETVAR "OSMODE"))
  8. ;;
  9. (command "layer" "m" "00AC-nowtime" "c" 1 "00AC-nowtime" "L" "CONTINUOUS" "00AC-nowtime" "LW" "0.45" "00AC-nowtime" "")
  10. (command ^c^c "layer" "p" "n" "00AC-nowtime"  "")
  11. (command"style" "@@ZHJ-AC" "gbeitc.shx,hztxt.shx" "0" "0.8" "" "" "")
  12.   (SETVAR "OSMODE" 0)
  13. (while  (SETQ PT (GETPOINT"\nPick the point you want to write nowtime number:"))
  14. (SETQ znowtime (menucmd "M=$(edtime,$(getvar,date),DDD\", \"D MON YYYY)"))
  15. (SETQ znowtime (menucmd "M=$(edtime,$(getvar,date),YYYY.M.DD hh:mm:ss)"))
  16. ;(SETQ znowtime (menucmd "M=$(edtime,$(getvar,date),YYYY\"年\"M\"月\"DD\"日\" hh\"时\"mm\"分\"ss\"秒\")"))
  17. (command "text" "s"  "@@ZHJ-AC"  "j" "m" PT 300 0 znowtime)
  18. )
  19.   (SETVAR "OSMODE" OLDOS)
  20.   (SETVAR "CMDECHO" 1)
  21.   (setq *error* olderr)
  22. (setvar "CLAYER" oldclay)
  23.   (PRIN1)
  24. )
;与大家分享 标注出系统时间
发表于 2011-1-8 12:42:29 | 显示全部楼层
帖子分享了...
发表于 2018-10-24 18:37:24 | 显示全部楼层
谢谢! xigemapenis 分享程序!!!!
GMT+8, 2025-5-19 02:38 , Processed in 0.156172 second(s), 25 queries , Gzip On.
