查看: 1871|回复: 7
DCL读取TXT程序 哪位高手帮忙看看为什么会卡死
发表于 2011-1-11 09:57:43 | 显示全部楼层 |阅读模式
这个是网上的一个程序 可是为什么TEXT1中有文字程序就会卡死呢 哪位高手帮忙改改吧 哈哈
  1. (DEFUN C:LBOX ()
  2.   (SETQ DCL_ID (LOAD_DIALOG "C:/LBOX.DCL") CHK 0)
  3. (NEW_DIALOG "LBOX" DCL_ID)
  4. (ADDL)
  5. (ACTION_TILE "LBOX_L" "(SETQ TMP_R (ATOI (GET_TILE \"LBOX_L\")))(SETC)")
  6. (ACTION_TILE "accept" "(SETQ CHK 1
  7. TMP_S (GET_TILE \"LBOX_E\"))(DONE_DIALOG)")
  8. (START_DIALOG) (UNLOAD_DIALOG DCL_ID)
  9. (IF (= CHK 1)
  10. (COMMAND "TEXT" (GETPOINT "\Select text insert point :")
  11. "200" "" TMP_S)
  12. )
  13.   (print "\aaaa")
  14. (PRINC))
  15. (DEFUN ADDL() (SETQ F_ID (OPEN "C:/TEXT1.TXT" "r"))
  16. (SETQ TMP_T (READ-LINE F_ID) TMP_L (LIST ""))
  17. (WHILE (/= TMP_T NIL)
  18. (SETQ TMP_L (APPEND TMP_L (LIST TMP_T)))
  19. (SETQ TMP_L (READ-LINE F_ID))
  20. )
  21. (CLOSE F_ID)
  22. (SETQ TMP_L (LIST (CDR TMP_L)))
  23. (START_LIST "LBOX_L" 3 0)
  24. (MAPCAR 'ADD_LIST (CAR TMP_L))
  25. (END_LIST))
  26. (print "\bbbb")
  27. (DEFUN SETC() (SETQ F_ID (OPEN "C:/TEXT1.TXT" "r"))
  28. (IF (> TMP_R 0)
  29. (REPEAT TMP_R (READ-LINE F_ID)))
  30. (SETQ TMP_S (GET_TILE "LBOX_E"))
  31. (SETQ TMP_S (STRCAT TMP_S (READ-LINE F_ID)))
  32. (CLOSE F_ID)
  33. (SET_TILE "LBOX_E" TMP_S))
  34. (print "\cccc")
发表于 2011-1-11 12:22:10 | 显示全部楼层
(SETQ TMP_T (READ-LINE F_ID))
 楼主| 发表于 2011-1-11 19:58:58 | 显示全部楼层
哦  感谢GU_XL 大哥 哈哈
发表于 2011-3-11 15:16:43 | 显示全部楼层
很有用啊,谢谢
 楼主| 发表于 2011-4-18 09:27:28 | 显示全部楼层
大哥能不能再帮忙改一下  让这个程序 直接能从对话框中 往TXT文件中写语句  并且能从对话框中删除TXT中的语句。。。
哈哈
发表于 2013-10-28 21:09:05 | 显示全部楼层
保存学习
发表于 2019-8-20 18:49:44 | 显示全部楼层
  1. (defun c:lbox ()
  2.   (setq dcl_id (load_dialog "c:/lbox.dcl")
  3.         chk    0
  4.   )
  5.   (new_dialog "lbox" dcl_id)
  6.   (addl)
  7.   (action_tile "lbox_l"
  8.                "(setq tmp_r (atoi (get_tile "lbox_l")))(setc)"
  9.   )
  10.   (action_tile "accept"
  11.                "(setq chk 1tmp_s (get_tile "lbox_e"))(done_dialog)"
  12.   )
  13.   (start_dialog)
  14.   (unload_dialog dcl_id)
  15.   (if (= chk 1)
  16.     (command "text"
  17.              (getpoint "\select text insert point :")
  18.              "200"
  19.              ""
  20.              tmp_s
  21.     )
  22.   )
  23.   (princ)
  24. )
  25. (defun addl ()
  26.   (setq f_id (open "c:/text1.txt" "r"))
  27.   (setq tmp_t (read-line f_id)
  28.         tmp_l (list "")
  29.   )
  30.   (while (/= tmp_t nil)
  31.     (setq tmp_l (append tmp_l (list tmp_t)))
  32.     (setq tmp_t (read-line f_id))
  33.   )
  34.   (close f_id)
  35.   (setq tmp_l (list (cdr tmp_l)))
  36.   (start_list "lbox_l" 3 0)
  37.   (mapcar 'add_list (car tmp_l))
  38.   (end_list)
  39. )
  40. (defun setc ()
  41.   (setq f_id (open "c:/text1.txt" "r"))
  42.   (if (> tmp_r 0)
  43.     (repeat tmp_r (read-line f_id))
  44.   )
  45.   (setq tmp_s (get_tile "lbox_e"))
  46.   (setq tmp_s (strcat tmp_s (read-line f_id)))
  47.   (close f_id)
  48.   (set_tile "lbox_e" tmp_s)
  49. )
GMT+8, 2025-5-18 15:46 , Processed in 0.186547 second(s), 25 queries , Gzip On.
