查看: 1279|回复: 2
请教高手:¥¥¥¥¥未找到主键
发表于 2011-1-12 00:20:52 | 显示全部楼层 |阅读模式
Sub aa()
Dim a As Object
Dim b As Object
Dim c As Object
Dim filterType(0) As Integer, filterData(0) As Variant
Dim sset As AcadSelectionSet
Set a = CreateObject("excel.application")
Set b = a.Workbooks.Add
Set c = b.Worksheets(1)
Set sset = ThisDrawing.SelectionSets.Item("ToExcel")
filterType(0) = 0
filterData(0) = "line,circle,point"
sset.SelectOnScreen filterType, filterData
c.Range("A1") = "ObjectCount" '写入标题
c.Range("B1") = sset.Count       '写入数据
Dim Obj As AcadEntity, i As Long, varCP As Variant
   i = 2
   For Each Obj In sset
  Select Case Obj.ObjectName
    Case "AcDbLine"
    c.Range(("A" & i)) = "111" '写入对象名
       End Select
i = i + 1
Next
a.Visible = True
End Sub
发表于 2011-1-12 19:09:02 | 显示全部楼层
thisdrawing对象里面没有选择集
请先创建一个选择集
If Not IsNull(ThisDrawing.SelectionSets.Item("ToExcel")) Then
   sset.Delete
End If
Set sset = ThisDrawing.SelectionSets.Add("ToExcel")
 楼主| 发表于 2011-1-13 08:17:31 | 显示全部楼层
回复 chmenf087 的帖子
多谢指点,能否给个QQ号,交个朋友
GMT+8, 2025-5-26 03:23 , Processed in 0.169081 second(s), 23 queries , Gzip On.
