查看: 1767|回复: 2
环境变量cmddia的问题
发表于 2011-1-26 21:02:56 | 显示全部楼层 |阅读模式
我家里电脑cmddia不管设成0还是1,都是命令行模式,改不过来,
碰巧我公司电脑cmddia不管设成0还是1,都是对话框模式,晕了,到底是怎么回事?
高手给解释下,怎么改回来?谢谢!
发表于 2011-1-26 22:50:29 | 显示全部楼层
cmddia
Controls the display of the In-Place Text Editor for the QLEADER command.
0 Off
1 On
filedia
Suppresses display of the file dialog boxes.
0 Does not display dialog boxes. You can still request a file dialog box to appear by entering a tilde (~) in response to the command's prompt. The same is true for AutoLISP and ADS functions.
1 Displays file dialog boxes. However, if a script or AutoLISP/ObjectARX program is active, AutoCAD displays an ordinary prompt.
 楼主| 发表于 2011-1-26 23:30:27 | 显示全部楼层
filedia 多谢版主
GMT+8, 2025-4-30 11:43 , Processed in 0.180029 second(s), 31 queries , Gzip On.
