;;明经通道发帖专用LISP函数简写&常用函数(2011.1) ;;;红色部分即为直接使用的常量和函数 ;;;http://bbs.mjtd.com/forum.php?mod=post&action=edit&fid=3&tid=85250&pid=450859&page=1 (setq En2Obj vlax-ename->vla-object Obj2En vlax-vla-object->ename 2PI (* PI 2) 0.5PI (/ PI 2) 0.25PI (/ PI 4) ;;常用VLA对象、集合 *ACAD* (vlax-get-acad-object) *DOC* (vla-get-ActiveDocument *ACAD*) *DOCS* (vla-get-Documents *ACAD*) *MS* (vla-get-modelSpace *DOC*) *PS* (vla-get-paperSpace *DOC*) *BLKS* (vla-get-Blocks *DOC*) *LAYS* (vla-get-Layers *DOC*) *LTS* (vla-get-Linetypes *DOC*) *STS* (vla-get-TextStyles *DOC*) *GRPS* (vla-get-groups *DOC*) *DIMS* (vla-get-DimStyles *DOC*) *LOUTS* (vla-get-Layouts *DOC*) *VPS* (vla-get-Viewports *DOC*) *VS* (vla-get-Views *DOC*) *DICS* (vla-get-Dictionaries *DOC*) ;;常用的几个外部接口对象 *FSO* (vlax-get-or-create-object "Scripting.FileSystemObject") *WSH* (vlax-get-or-create-object "wscript.shell") *SHELL* (vlax-get-or-create-object "Shell.Application") *SCR* (vlax-get-or-create-object "ScriptControl") *WBEM* (vlax-get-or-create-object "WbemScripting.SWbemLocator") ) ;; [功能] 将弧度转换为十进制角度 ;; [参数] ang---弧度 ;; [返回] 十进制角度 (defun MJ:R2D (ANG) (* (/ ANG 180.0) PI)) ;; [功能] 将十进制角度转换为弧度 ;; [参数] ang---十进制角度 ;; [返回] 弧度 (defun MJ:D2R (ANG) (/ (* ANG 180.0) PI)) ;; [功能] 在当前视图状况下将图形单位转换为像素 (defun MJ:U2P (UN) (* UN (/ (cadr (getvar 'SCREENSIZE)) (getvar 'VIEWSIZE))) ) ;; [功能] 获取 0~1 之间的随机数 (by zml84) (defun MJ:RAD () (/ (rem (getvar "CPUTICKS") 1984) 1983) ) ;; [功能] 判断 X 是否是图元名 (defun MJ:enP (X) (= (type X) 'ENAME)) ;; [功能] 判断 X 是否是选择集且长度不为 0 (defun MJ:ssP (x) (and (= (type X) 'PICKSET) (> (sslength X) 0))) ;; [功能] 判断 X 是否是字符串 (defun MJ:strP (X) (= (type X) 'STR)) ;; [功能] 判断 X 是否是实数 (defun MJ:realP (x) (= (type X) 'REAL)) ;; [功能] 判断 X 是否是整数 (defun MJ:intP (X) (= (type X) 'INT)) ;; [功能] 判断 FileName 是否为文件且存在(替代针对文件的findfile) ;; [参数] FileName---字符串 ;; [返回] 包含路径的文件名或 nil (defun MJ:FileP (FileName) (if (and (MJ:STRP FileName) (setq FileName (findfile FileName)) (not (vl-file-directory-p FileName)) ) FileName ) ) ;; [功能] 将 ACI 索引颜色转换成 RGB 配色系统 (defun MJ:ACI->RGB (ACI / COL) (setq COL (vla-get-truecolor (vla-get-ActiveLayer *DOC*)))) (if (not (vl-catch-all-apply 'vla-put-ColorIndex (list COL ACI))) (list (vla-get-red COL) (vla-get-green COL) (vla-get-blue COL) ) ) ) ;; [功能] 将 RGB 配色系统转换成 ACI 索引颜色 (defun MJ:RGB->ACI (R G B / COL ACI) (setq COL (vla-get-truecolor (vla-get-ActiveLayer *DOC*))) (vl-catch-all-apply '(lambda () (vla-SetRGB COL R G B) (setq ACI (vla-get-ColorIndex COL)) ) ) ACI ) ;; [功能] 将选择集转换为图元列表 ;; [参数] SS---选择集 ;; [返回] 表(图元列表长度 图元列表) (defun MJ:SS->LIST (SS) (vl-remove-if-not 'MJ:enP (mapcar 'cadr (ssnamex SS))) ) ;; [功能] 根据当前文档的图形单位精度将实数转换为字符串 ;; [参数] REL----实数 (defun MJ:RTOS (REL / DZIN) (setq DZIN (getvar 'DIMZIN)) (setvar 'DIMZIN 0) (setq REL (rtos REL 2 (getvar 'LUPREC))) (setvar 'DIMZIN DZIN) REL ) ;; [功能] 遍历选择集对所包含的图元进行指定函数操作 ;; [参数] SS----选择集 ;; FUN---函数名 ;; [返回] 包含每个图元的操作结果的表 (defun MJ:SS-MAP (SS FUN / N LST) (repeat (setq N (sslength SS)) (setq LST (cons (apply FUN (list (ssname SS (setq N (1- N))))) LST)) ) LST ) ;; [功能] 遍历选择集对所包含的图元进行指定函数操作 ;; [参数] SS----选择集 ;; FUN---函数名 ;; [返回] 最后一个图元的操作结果 (defun MJ:SS-FOR (SS FUN / N) (repeat (setq N (sslength SS)) (apply FUN (list (ssname SS (setq N (1- N))))) ) ) ;; [功能] 获取当前 AutoCAD 的版本 (defun MJ:ACAD-VAR () (atof (getvar "ACADVER"))) ;; [功能] 获取两点的中点坐标 ;; [参数] p1,p2---二维点或三维点,但两个表的长度要一致 ;; [返回] 点 (defun MJ:MIDPOINT (P1 P2) (mapcar '(lambda (X Y) (/ (+ X Y) 2.0)) P1 P2) ) ;; [功能] 获取 DXF 组码值 (defun MJ:DXF (IT LST) (cdr (assoc IT LST)) ) ;; [功能] 获取在图元 en 之后产生的图元列表 ;; [参数] en----图元名 ;; [返回] 图元列表 ;; [测试]1.(setq en (entlast)) ;; 执行创建图元的命令,如 LINE,BOUNDARY ;; (MJ:EntNextAll en) ;; 2.(MJ:EntNextAll (car(entsel))) (defun MJ:EntNextAll (EN / LST) (if EN (while (setq EN (entnext EN)) (if (not (member (cdr (assoc 0 (entget EN))) '("ATTRIB" "VERTEX" "SEQEND") ) ) (setq LST (cons EN LST)) ) ) ) (reverse LST) ) ;; [功能] 打印列表中的数据 (defun MJ:Print-List (LST) (mapcar 'princ LST))
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-12-25 04:42 , Processed in 0.189442 second(s), 29 queries , Gzip On.
