- 积分
- 5715
- 明经币
- 个
- 注册时间
- 2006-12-19
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2013-1-9 19:22:09
显示全部楼层
哪位高手把这个翻译成lisp的代码,想写一个lisp版的日程日历.
 - 万年历算法
- 一、 阳历算法
- 具体算法见函数Void get_solar_day_date(void),这样阳历日历的星期排法就确定了。
- 表1:
- 月份 1 2 3 4 5 6 7 8 9 10 11 12
- 闰年 31 29 31 30 31 30 31 31 30 31 30 31
- 非闰年 31 28 31 30 31 30 31 31 30 31 30 31
- 变量定义:
- Public:
- Unsigned int temp_total_day;
- Unsigned char gc_solar_calendar_year;
- Unsigned char gc_solar_calendar_month;
- Unsigned char gc_solar_calendar_date;
- Unsigned char gc_lunar_calendar_year;
- Unsigned char gc_lunar_calendar_month;
- Unsigned char gc_lunar_calendar_date;
- Unsigned char start_day_of_week;
- 说明:函数get_solar_day_date(void)的输入变量:gc_solar_calendar_year和gc_solar_calendar_month
- 输出变量:start_day_of_week和temp_total_day
- Void get_solar_day_date(void)
- unsigned char temp01;
- /*------calculate what day is the day of the current month and year. Mon~Sun?---*/
- /*条件初始化二次,减少运算数据量. temp_total_day 是int型变量*/
- start_day_of_week = 2; temp_total_day = 0;calculate_temp = 1;
- if(gc_solar_calendar_year > 99)
- {start_day_of_week = 6;calculate_temp = 100;}
- for(temp01 = calculate_temp; temp01
- 二、 阴历算法
- 200年需要200 × 2 = 400个字节,构成阴历压缩数据表lunar_calendar_month_table[]如下:
- const char lunar_calendar_month_table[]={ //从阴历年1900年到2100年
- /*the total day of each month pointer */
- /* from 1901~2100*/
- /* (0110)110000001001 (0110)leap month,110000001001
- lunar month total day: 1:29 0:30*/
- 0x00,0x04,0xad,0x08,0x5a,0x01,0xd5,0x54,0xb4,0x09,0x64,0x05,0x59,0x45, 0x95,0x0a,0xa6,0x04,0x55,0x24,0xad,0x08,0x5a,0x62,0xda,0x04,0xb4,0x05, 0xb4,0x55,0x52,0x0d,0x94,0x0a,0x4a,0x2a,0x56,0x02,0x6d,0x71,0x6d,0x01, 0xda,0x02,0xd2,0x52,0xa9,0x05,0x49,0x0d,0x2a,0x45,0x2b,0x09,0x56,0x01, 0xb5,0x20,0x6d,0x01,0x59,0x69,0xd4,0x0a,0xa8,0x05,0xa9,0x56,0xa5,0x04, 0x2b,0x09,0x9e,0x38,0xb6,0x08,0xec,0x74,0x6c,0x05,0xd4,0x0a,0xe4,0x6a, 0x52,0x05,0x95,0x0a,0x5a,0x42,0x5b,0x04,0xb6,0x04,0xb4,0x22,0x6a,0x05, 0x52,0x75,0xc9,0x0a,0x52,0x05,0x35,0x55,0x4d,0x0a,0x5a,0x02,0x5d,0x31, 0xb5,0x02,0x6a,0x8a,0x68,0x05,0xa9,0x0a,0x8a,0x6a,0x2a,0x05,0x2d,0x09, 0xaa,0x48,0x5a,0x01,0xb5,0x09,0xb0,0x39,0x64,0x05,0x25,0x75,0x95,0x0a, 0x96,0x04,0x4d,0x54,0xad,0x04,0xda,0x04,0xd4,0x44,0xb4,0x05,0x54,0x85, 0x52,0x0d,0x92,0x0a,0x56,0x6a,0x56,0x02,0x6d,0x02,0x6a,0x41,0xda,0x02, 0xb2,0xa1,0xa9,0x05,0x49,0x0d,0x0a,0x6d,0x2a,0x09,0x56,0x01,0xad,0x50, 0x6d,0x01,0xd9,0x02,0xd1,0x3a,0xa8,0x05,0x29,0x85,0xa5,0x0c,0x2a,0x09, 0x96,0x54,0xb6,0x08,0x6c,0x09,0x64,0x45,0xd4,0x0a,0xa4,0x05,0x51,0x25, 0x95,0x0a,0x2a,0x72,0x5b,0x04,0xb6,0x04,0xac,0x52,0x6a,0x05,0xd2,0x0a, 0xa2,0x4a,0x4a,0x05,0x55,0x94,0x2d,0x0a,0x5a,0x02,0x75,0x61,0xb5,0x02, 0x6a,0x03,0x61,0x45,0xa9,0x0a,0x4a,0x05,0x25,0x25,0x2d,0x09,0x9a,0x68, 0xda,0x08,0xb4,0x09,0xa8,0x59,0x54,0x03,0xa5,0x0a,0x91,0x3a,0x96,0x04, 0xad,0xb0,0xad,0x04,0xda,0x04,0xf4,0x62,0xb4,0x05,0x54,0x0b,0x44,0x5d, 0x52,0x0a,0x95,0x04,0x55,0x22,0x6d,0x02,0x5a,0x71,0xda,0x02,0xaa,0x05, 0xb2,0x55,0x49,0x0b,0x4a,0x0a,0x2d,0x39,0x36,0x01,0x6d,0x80,0x6d,0x01, 0xd9,0x02,0xe9,0x6a,0xa8,0x05,0x29,0x0b,0x9a,0x4c,0xaa,0x08,0xb6,0x08, 0xb4,0x38,0x6c,0x09,0x54,0x75,0xd4,0x0a,0xa4,0x05,0x45,0x55,0x95,0x0a, 0x9a,0x04,0x55,0x44,0xb5,0x04,0x6a,0x82,0x6a,0x05,0xd2,0x0a,0x92,0x6a, 0x4a,0x05,0x55,0x0a,0x2a,0x4a,0x5a,0x02,0xb5,0x02,0xb2,0x31,0x69,0x03, 0x31,0x73,0xa9,0x0a,0x4a,0x05,0x2d,0x55,0x2d,0x09,0x5a,0x01,0xd5,0x48, 0xb4,0x09,0x68,0x89,0x54,0x0b,0xa4,0x0a,0xa5,0x6a,0x95,0x04,0xad,0x08, 0x6a,0x44,0xda,0x04,0x74,0x05,0xb0,0x25,0x54,0x03,};
- 确定阳历日和阴历日的对应关系的算法:
- 对于其他任何一个阳历日和阴历日的对应关系,都可以通过以下算法求得结果。具体算法由如下函数get_lunar_day(void)实现:
- 说明:函数get_lunar_day(void)的输入变量:gc_solar_calendar_year和gc_solar_calendar_month
- 输出变量:gc_lunar_calendar_year、gc_lunar_calendar_month和gc_lunar_calendar_date
- void get_lunar_day(void)/*计算出输入阳历年、阳历月,对应该阳历月第一天对应阴历时间,即阴历年、月、日*/
- {unsigned char temp_leap_month;
- unsigned char temp_flag;
- unsigned char calculate_temp;
- unsigned char mc_tpumenus_temp_loop;
- unsigned char mc_tpumenus_temp_01;
- temp_leap_month = 0;temp_flag = 1;
- //条件初始化二次,减少运算数据量.
- {gc_lunar_calendar_year = 99;gc_lunar_calendar_month = 11;
- gc_lunar_calendar_date = 25;temp_total_day = 25;calculate_temp = 100;}
- else
- {gc_lunar_calendar_year = 0;gc_lunar_calendar_month = 11;
- gc_lunar_calendar_date = 11;temp_total_day = 11;calculate_temp = 1;}
- if(gc_solar_calendar_year >calculate_temp||gc_solar_calendar_month>1)
- { for(mc_tpumenus_temp_loop = 1;mc_tpumenus_temp_loop>0;){
- temp_total_day -=calendar_calculate_lunar_month_total_day();
- temp_leap_month = tpumenus_lunar_calendar_month_table[2*gc_lunar_calendar_year 1];
- temp_leap_month = (temp_leap_month>>4)&0x0F;
- if(gc_lunar_calendar_month == temp_leap_month)
- {switch(gc_lunar_calendar_year)
- {case 6,14,19,25,33,36,38,41,44,52,55,79,117,
- 136,147,150,155,158,185,193:
- if(temp_total_day60,ignore compare
- {mc_tpumenus_temp_01 = calendar_calculate_lunar_month_total_day();
- if(temp_total_day > mc_tpumenus_temp_02)&0x01)return(29);
- else return(30);}
- 阳历日和农历节气的对应关系
- 压缩节气数据表:
- 根据规律可以得到四个数据表(每个阳历月有两个节气,每个节气需要两个数据表):
- const unsigned char calendar_solar_term_table_01[12][33] = {
- {7,6,6,6,6,6,6,6,6,5,6,6,6,5,5,6,6,5,5,5,5,5,5,5,5,4,5,5}, //month 1
- {5,4,5,5,5,4,4,5,5,4,4,4,4,4,4,4,4,3,4,4,4,3,3,4,4,3,3,3}, //2
- {6,6,6,7,6,6,6,6,5,6,6,6,5,5,6,6,5,5,5,6,5,5,5,5,4,5,5,5,5}, //3
- {5,5,6,6,5,5,5,6,5,5,5,5,4,5,5,5,4,4,5,5,4,4,4,5,4,4,4,4,5}, //4
- {6,6,6,7,6,6,6,6,5,6,6,6,5,5,6,6,5,5,5,6,5,5,5,5,4,5,5,5,5}, //5
- {6,6,7,7,6,6,6,7,6,6,6,6,5,6,6,6,5,5,6,6,5,5,5,6,5,5,5,5,4,5,5,5,5}, //6
- {7,8,8,8,7,7,8,8,7,7,7,8,7,7,7,7,6,7,7,7,6,6,7,7,6,6,6,7,7}, //7
- {8,8,8,9,8,8,8,8,7,8,8,8,7,7,8,8,7,7,7,8,7,7,7,7,6,7,7,7,6,6,7,7,7}, //8
- {8,8,8,9,8,8,8,8,7,8,8,8,7,7,8,8,7,7,7,8,7,7,7,7,6,7,7,7,7}, //9
- {9,9,9,9,8,9,9,9,8,8,9,9,8,8,8,9,8,8,8,8,7,8,8,8,7,7,8,8,8}, //10
- {8,8,8,8,7,8,8,8,7,7,8,8,7,7,7,8,7,7,7,7,6,7,7,7,6,6,7,7,7}, //11
- {7,8,8,8,7,7,8,8,7,7,7,8,7,7,7,7,6,7,7,7,6,6,7,7,6,6,6,7,7}, //12
- }; //这个数据表表示了每个月第一个节气出现的规律
- const unsigned char calendar_solar_term_year_01[12][9] = {
- {13,49,85,117,149,185,201,250,250}, //month 1
- {13,45,81,117,149,185,201,250,250}, //2
- {13,48,84,112,148,184,200,201,250}, //3
- {13,45,76,108,140,172,200,201,250}, //4
- {13,44,72,104,132,168,200,201,250}, //5
- {5 ,33,68,96 ,124,152,188,200,201}, //6
- {29,57,85,120,148,176,200,201,250}, //7
- {13,48,76,104,132,168,196,200,201}, //8
- {25,60,88,120,148,184,200,201,250}, //9
- {16,44,76,108,144,172,200,201,250}, //10
- {28,60,92,124,160,192,200,201,250}, //11
- {17,53,85,124,156,188,200,201,250}, //12
- }; //这个数据表表示了每个月第一个节气出现规律对应的阳历年份范围
- const unsigned char calendar_solar_term_table_02[12][29] = {
- {21,21,21,21,21,20,21,21,21,20,20,21,21,20,20,20,20,20,20,20,20,19,20,20,20,19,19,20},
- {20,19,19,20,20,19,19,19,19,19,19,19,19,18,19,19,19,18,18,19,19,18,18,18,18,18,18,18},
- {21,21,21,22,21,21,21,21,20,21,21,21,20,20,21,21,20,20,20,21,20,20,20,20,19,20,20,20,20},
- {20,21,21,21,20,20,21,21,20,20,20,21,20,20,20,20,19,20,20,20,19,19,20,20,19,19,19,20,20},
- {21,22,22,22,21,21,22,22,21,21,21,22,21,21,21,21,20,21,21,21,20,20,21,21,20,20,20,21,21},
- {22,22,22,22,21,22,22,22,21,21,22,22,21,21,21,22,21,21,21,21,20,21,21,21,20,20,21,21,21},
- {23,23,24,24,23,23,23,24,23,23,23,23,22,23,23,23,22,22,23,23,22,22,22,23,22,22,22,22,23},
- {23,24,24,24,23,23,24,24,23,23,23,24,23,23,23,23,22,23,23,23,22,22,23,23,22,22,22,23,23},
- {24,24,24,24,23,24,24,24,23,23,24,24,23,23,23,24,23,23,23,23,22,23,23,23,22,22,23,23,23},
- {23,23,23,23,22,23,23,23,22,22,23,23,22,22,22,23,22,22,22,22,21,22,22,22,21,21,22,22,22},
- {22,22,23,23,22,22,22,23,22,22,22,22,21,22,22,22,21,21,22,22,21,21,21,22,21,21,21,21,22},
- }; //这个数据表表示了每个月第二个节气出现的规律
- const unsigned char calendar_solar_term_year_02[12][8] = {
- {13,45,81,113,149,185,201},{21,57,93,125,161,193,201},{21,56,88,120,152,188,200,201},
- {21,49,81,116,144,176,200,201},{17,49,77,112,140,168,200,201},
- {28,60,88,116,148,180,200,201},{25,53,84,112,144,172,200,201},
- {29,57,89,120,148,180,200,201},{17,45,73,108,140,168,200,201},
- {28,60,92,124,160,192,200,201},{16,44,80,112,148,180,200,201},
- {17,53,88,120,156,188,200,201},};
- //这个数据表表示了每个月第二个节气出现规律对应的阳历年份范围
- 每个阳历月对应的两个农历节气出现的日期,可根据条件规律算法,分别由以下两个函数实现:
- unsigned char calendar_calculate_solar_term_1(void)
- zpage unsigned char done_index;
- zpage unsigned char solar_term;
- done_index = 0;
- while(gc_solar_calendar_year >= calendar_solar_term_year_01[gc_solar_calendar_month - 1][done_index]) {done_index ;}
- solar_term = calendar_solar_term_table_01[gc_solar_calendar_month - 1][4*done_index gc_solar_calendar_year4];
- if((gc_solar_calendar_year == 121)&&(gc_solar_calendar_month == 4))solar_term = 5;
- if((gc_solar_calendar_year == 132)&&(gc_solar_calendar_month == 4))solar_term = 5;
- if((gc_solar_calendar_year == 194)&&(gc_solar_calendar_month == 6))solar_term = 6;
- return(solar_term);
- } //计算阳历月对应的第一个节气
- unsigned char calendar_calculate_solar_term_2(void)
- done_index = 0;
- while(gc_solar_calendar_year >= calendar_solar_term_year_02[gc_solar_calendar_month - 1][done_index]){done_index ;}
- solar_term = calendar_solar_term_table_02[gc_solar_calendar_month - 1][4*done_index gc_solar_calendar_year4];
- if((gc_solar_calendar_year == 171)&&(gc_solar_calendar_month == 3))solar_term = 21;
- if((gc_solar_calendar_year == 181)&&(gc_solar_calendar_month == 5))solar_term = 21;
- } //计算阳历月对应的第二个节气
- 以上就是万年历的完整算法。它首先计算出对应阳历月第一天对应是星期几,然后根据数据压缩算法确定,确定对应的阴历日期;而阴历节气,则有条件规律算法实现。
