查看: 1699|回复: 3
[基础] 选择一个曲线,得到与之相连接的线的选择集
发表于 2011-2-17 18:23:20 | 显示全部楼层 |阅读模式
我记得以前有个高人发过~
那位好心人帮帮忙
发表于 2011-2-25 23:42:32 | 显示全部楼层
飞诗大侠的程序:
;;选择连续&相切线 -----fsxm 2007/01/29
发表于 2025-1-18 09:04:50 | 显示全部楼层
年久失修了,不适合高版本
发表于 2025-1-21 10:56:08 | 显示全部楼层
;;--------------------=={ Chain Selection }==-----------------;;
;;  Prompts the user to select an object and generates a      ;;
;;  selection chain of all objects sharing endpoints with     ;;
;;  objects in the accumulative selection.                    ;;
;;  Author: Lee Mac, Copyright ?2012 - www.lee-mac.com       ;;
(defun c:cs ( / en fl in l1 l2 s1 s2 sf vl )
    (setq sf
        (list
           '(-4 . "<OR")
               '(0 . "LINE,ARC")
               '(-4 . "<AND")
                   '(0 . "LWPOLYLINE,SPLINE")
                   '(-4 . "<NOT")
                       '(-4 . "&=")
                       '(70 . 1)
                   '(-4 . "NOT>")
               '(-4 . "AND>")
               '(-4 . "<AND")
                   '(0 . "POLYLINE")
                   '(-4 . "<NOT")
                       '(-4 . "&")
                       '(70 . 89)
                   '(-4 . "NOT>")
                   '(-4 . "AND>")
               '(-4 . "<AND")
                   '(0 . "ELLIPSE")
                   '(-4 . "<OR")
                       '(-4 . "<>")
                       '(41 . 0.0)
                       '(-4 . "<>")
                        (cons 42 (+ pi pi))
                   '(-4 . "OR>")
               '(-4 . "AND>")
           '(-4 . "OR>")
            (if (= 1 (getvar 'cvport))
                (cons 410 (getvar 'ctab))
               '(410 . "Model")
    (if (setq s1 (ssget "_X" sf))
        (if (setq en (ssget "_+.:E:S" sf))
                (setq s2 (ssadd)
                      en (ssname en 0)
                      l1 (list (vlax-curve-getstartpoint en) (vlax-curve-getendpoint en))
                (repeat (setq in (sslength s1))
                    (setq en (ssname s1 (setq in (1- in)))
                          vl (cons (list (vlax-curve-getstartpoint en) (vlax-curve-getendpoint en) en) vl)
                (while
                        (foreach v vl
                            (if (vl-some '(lambda ( p ) (or (equal (car v) p 1e-8) (equal (cadr v) p 1e-8))) l1)
                                (setq s2 (ssadd (caddr v) s2)
                                      l1 (vl-list* (car v) (cadr v) l1)
                                      fl t
                                (setq l2 (cons v l2))
                        fl
                    (setq vl l2 l2 nil fl nil)
        (princ "\nNo valid objects found.")
    (sssetfirst nil s2)
(vl-load-com) (princ)
GMT+8, 2025-4-5 14:35 , Processed in 0.155114 second(s), 26 queries , Gzip On.
