查看: 704|回复: 0
Exploding AutoCAD objects using .NET
发表于 2011-2-24 11:26:08 | 显示全部楼层 |阅读模式
Time to go back to basics. I realised recently – on receiving this comment – that I hadn’t specifically covered the nature of Entity.Explode() in a post (even if it’s been used in a few of them, over the years).
Entity.Explode() is one of those tricky methods: it’s actually a
faux-ami with the AutoCAD command of the same name, in a very similar way to Database.Purge(). The way in which Explode() and Purge() differ from their “equivalent” commands is that they’re non-destructive: they don’t actually result in a change to the AutoCAD drawing database. Explode() populates a DBObjectCollection with the results of the explode operation, and it’s then up to the caller of the function to add them to the appropriate location (typically the current – i.e. model- or paper- – space). Purge() checks a list of objects for ones that can safely be erased, and then it’s up to the caller of the function to do so.
So there is some occasional – and understandable – confusion around Explode() or Purge() not working as expected.
Here’s a simple approach to mimicking the behaviour of the EXPLODE command programmatically: after calling Entity.Explode() on each selected entity, we optionally erase the original entities and add the results of the Explode() to the drawing.
There’s a lot this code doesn’t do – such as check for entities that did not actually generate any exploded results (and so probably shouldn’t be erased) or output some feedback on what is happening to the command-line – but the principle should be clear enough.
Here’s the C# code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace Explosion
public
class
Commands
    [CommandMethod("EXP", CommandFlags.UsePickSet)]
public
void ExplodeEntities()
Document doc =
Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
// Ask user to select entities
PromptSelectionOptions pso =
new
PromptSelectionOptions();
      pso.MessageForAdding = "\nSelect objects to explode: ";
      pso.AllowDuplicates = false;
      pso.AllowSubSelections = true;
      pso.RejectObjectsFromNonCurrentSpace = true;
      pso.RejectObjectsOnLockedLayers = false;
PromptSelectionResult psr = ed.GetSelection(pso);
if (psr.Status != PromptStatus.OK)
return;
// Check whether to erase the original(s)
bool eraseOrig = false;
if (psr.Value.Count > 0)
PromptKeywordOptions pko =
new
PromptKeywordOptions("\nErase original objects?");
        pko.AllowNone = true;
        pko.Keywords.Add("Yes");
        pko.Keywords.Add("No");
        pko.Keywords.Default = "No";
PromptResult pkr = ed.GetKeywords(pko);
if (pkr.Status != PromptStatus.OK)
return;
        eraseOrig = (pkr.StringResult == "Yes");
Transaction tr =
        db.TransactionManager.StartTransaction();
using (tr)
// Collect our exploded objects in a single collection
DBObjectCollection objs = new
DBObjectCollection();
// Loop through the selected objects
foreach (SelectedObject so in psr.Value)
// Open one at a time
Entity ent =
            (Entity)tr.GetObject(
              so.ObjectId,
OpenMode.ForRead
// Explode the object into our collection
          ent.Explode(objs);
// Erase the original, if requested
if (eraseOrig)
            ent.UpgradeOpen();
            ent.Erase();
// Now open the current space in order to
// add our resultant objects
BlockTableRecord btr =
          (BlockTableRecord)tr.GetObject(
            db.CurrentSpaceId,
OpenMode.ForWrite
// Add each one of them to the current space
// and to the transaction
foreach (DBObject obj in objs)
Entity ent = (Entity)obj;
          btr.AppendEntity(ent);
          tr.AddNewlyCreatedDBObject(ent, true);
// And then we commit
        tr.Commit();
The results of calling the EXP command should be obvious enough – and do not result in anything very visually stimulating – so I’ll finish the post here.
GMT+8, 2025-11-25 11:33 , Processed in 0.162535 second(s), 31 queries , Gzip On.
