查看: 3543|回复: 5
新手求救 DCl参数太少错误
发表于 2011-2-26 19:46:41 | 显示全部楼层 |阅读模式
初学DCl做一个简单的矩形输入长宽后绘制矩形总是提示"参数太少“
代码如下
lisp
(DEFUN C:RECT()
(SETQ DCL_ID (LOAD_DIALOG "rec"))
(NEW_DIALOG "rect" DCL_ID)
(ACTION_TILE "accept" "(S_RECT)(DONE_DIALOG)")
(START_DIALOG)
(UNLOAD_DIALOG)
(SETQ PT_0 (GETPOINT "\nSelect rectangle lower leftpoint : "))
(SETQ PT_1 (POLAR PT_0 0 TMP_W)
PT_2 (POLAR PT_1 (/ PI 2) TMP_H)
PT_3 (POLAR PT_2 PI TMP_W))
(COMMAND "PLINE" PT_0 PT_1 PT_2 PT_3 "C")
(PRINC))
(DEFUN S_RECT()
(SETQ TMP_W (ABS (ATOF (GET_TILE "rect_w")))
TMP_H (ABS (ATOF (GET_TILE "rect_h"))))
dcl
rect:dialog {
    label = "rec" ;
    :edit_box {
        edit_limit = 16 ;
        edit_width = 10 ;
        fixed_width = true ;
        key = "rect_w" ;
        label = "rec width:" ;
        value = "50" ;
    :edit_box {
        edit_limit = 16 ;
        edit_width = 10 ;
        key = "rect_h" ;
        label = "rec   len:" ;
        value = "25" ;
    ok_only;
请各位高手指教下
发表于 2011-2-26 20:13:13 | 显示全部楼层
回复 daiguafan 的帖子
(UNLOAD_DIALOG)
(UNLOAD_DIALOG  DCL_ID )
 楼主| 发表于 2011-2-26 20:50:54 | 显示全部楼层
回复 Gu_xl 的帖子
谢谢斑竹,
现在不提示参数太少出错,但是提示Select rectangle lower leftpoint : 参数类型错误: numberp: nil
麻烦再次帮忙
发表于 2011-2-26 23:27:15 | 显示全部楼层
  1. (DEFUN C:tt ()
  2.   (DEFUN S_RECT        ()
  3.     (SETQ ww (ABS (ATOF (GET_TILE "rect_w")))
  4.           hh (ABS (ATOF (GET_TILE "rect_h")))
  5.     )
  6.   )
  7.   (NEW_DIALOG "rect" (LOAD_DIALOG "rec"))
  8.   (ACTION_TILE "accept" "(S_RECT)(done_dialog)")
  9.   (START_DIALOG)
  10.   (while (SETQ P1 (GETPOINT "\np1: "))
  11.     (setq p2 (list (+ (car p1) ww) (+ (cadr p1) hh)))
  12.     (COMMAND "rectang" "non" p1 "non" p2)
  13.   )
  14.   (princ)
  15. )
 楼主| 发表于 2011-2-27 00:13:38 | 显示全部楼层
回复 xyp1964 的帖子
谢谢,楼上果然高手
发表于 2014-3-10 17:59:48 | 显示全部楼层
我也是刚学现在也碰到这种问题了
GMT+8, 2025-5-25 08:58 , Processed in 0.193457 second(s), 25 queries , Gzip On.
