查看: 2920|回复: 4
菜单问题
发表于 2011-3-1 09:22:12 | 显示全部楼层 |阅读模式
using System;
using System.Collections.Generic;
using System.Text;
using System.Drawing;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.Windows;
using Autodesk.AutoCAD.Runtime;
using System.Windows.Forms;
namespace menu
    public class Class1
        [CommandMethod("SendCommand")]
        public void SendCommand()
            MessageBox.Show("dddd");
        [CommandMethod("AddRibbon")]
        public void AddRibbon()
            Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Text = "CGBridge";
            RibbonControl rc = RibbonControl();
            RibbonTab rt = RibbonTab("系统", "1");
            RibbonPanel rp = RibbonPanel("菜单面板");
            RibbonButton rblogin = RibbonButton("登陆系统", "登陆系统", "\\Demo.bmp");
            RibbonButton rbconnect = RibbonButton("连接设置", "连接设置", "\\Demo.bmp");
            RibbonButton rbdatain = RibbonButton("数据加载", "数据加载", "\\Demo.bmp");
            RibbonButton rbuser = RibbonButton("用户管理", "用户管理", "\\Demo.bmp");
            RibbonButton rbquit = RibbonButton("系统退出", "系统退出", "\\Demo.bmp");
            rp.Source.Items.Add(rblogin);
            rp.Source.Items.Add(rbconnect);
            rp.Source.Items.Add(rbdatain);
            rp.Source.Items.Add(rbuser);
            rp.Source.Items.Add(rbquit);
            rt.Panels.Add(rp);
            RibbonTab rtedit = RibbonTab("要素编辑", "1");
            RibbonPanel rpedit = RibbonPanel("菜单");
            RibbonButton rbaddpoint = RibbonButton("增加点", "增加点", "\\Demo.bmp");
            RibbonButton rbaddpolyline = RibbonButton("增加折线", "增加折线", "\\Demo.bmp");
            RibbonButton rbaddpolygon = RibbonButton("增加区域", "增加区域", "\\Demo.bmp");
            rpedit.Source.Items.Add(rbaddpoint);
            rpedit.Source.Items.Add(rbaddpolyline);
            rpedit.Source.Items.Add(rbaddpolygon);
            rtedit.Panels.Add(rpedit);
            rc.Tabs.Clear();
            rc.Tabs.Add(rt);
            rc.Tabs.Add(rtedit);
        /// <summary> /// 获得菜单控制 /// </summary> /// <returns></returns>
        public static  RibbonControl RibbonControl()
            if (Autodesk.Windows.ComponentManager.Ribbon == null)
                Autodesk.Windows.ComponentManager.ItemInitialized += new EventHandler<RibbonItemEventArgs>(ComponentManager_ItemInitialized);
            return ComponentManager.Ribbon;
        /// <summary> /// 创建菜单标签 /// </summary> /// <param name="Name">标签名</param> /// <param name="id">标签ID</param> /// <returns></returns>
        public static RibbonTab RibbonTab(string Name, string id)
            RibbonTab ribTab = new Autodesk.Windows.RibbonTab();
            ribTab.Title = Name;
            ribTab.Id = id;
            ribTab.IsActive = true;
            return ribTab;
        /// <summary> /// 创建菜单面板 /// </summary> /// <param name="Title">面板名</param> /// <returns></returns>
       public static RibbonPanel RibbonPanel(string Title)
           RibbonPanelSource ribSourcePanel = new RibbonPanelSource();
           //Autodesk.Windows
           ribSourcePanel.Title = Title;//now the panel
           RibbonPanel ribPanel = new RibbonPanel();
           ribPanel.Source = ribSourcePanel;
           return ribPanel;
       } /// <summary> /// 创建菜单按钮 /// </summary> /// <param name="btName">按钮名</param> /// <param name="cmdName">命令名</param> /// <returns></returns>
        public static RibbonButton RibbonButton(string btName, string cmdName,string strbmp)
            RibbonButton ribButton = new RibbonButton();
            ribButton.Text = btName;
            ribButton.CommandParameter = cmdName;
            ribButton.ShowText = true;
            ribButton.LargeImage = new System.Windows.Media.Imaging.BitmapImage(new System.Uri(System.Windows.Forms.Application.StartupPath +strbmp));
            ribButton.Size = Autodesk.Windows.RibbonItemSize.Large;
            ribButton.ShowImage = true;
            ribButton.CommandHandler = new AdskCommandHandler();
            return ribButton;
        ///// <summary> /// 用于激活菜单 /// </summary> /// <param name="sender"></param> /// <param name="e"></param>
        static void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e)
            if (Autodesk.Windows.ComponentManager.Ribbon != null)
                Autodesk.Windows.ComponentManager.ItemInitialized -= new EventHandler<RibbonItemEventArgs>(ComponentManager_ItemInitialized);
        /// <summary> /// 执行按钮的命令 /// </summary>
        public class AdskCommandHandler : System.Windows.Input.ICommand
            /// <summary> /// 是否可执行(接口) /// </summary> /// <param name="parameter">命令名</param>
            /// /// <returns></returns>
            public bool CanExecute(object parameter)
            { return true; } /// <summary> /// 改变可执行状态 /// </summary>
            public event EventHandler CanExecuteChanged; /// <summary> /// 执行命令 /// </summary> /// <param name="parameter">命令的名字</param>
            public void Execute(object parameter)
                //is from a Ribbon Button?
                Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                RibbonButton ribBtn = parameter as RibbonButton;
                if (ribBtn != null)
                    if ((String)ribBtn.CommandParameter == "系统退出")
                         Autodesk.AutoCAD.ApplicationServices.Application.Quit();
                    else if((String)ribBtn.CommandParameter == "数据加载")
                         doc.SendStringToExecute("COSQL ", true, false, false);
                    else
                         Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute((String)ribBtn.CommandParameter, true, false, true);
                    //MessageBox.Show((String)ribBtn.CommandParameter);
                //Autodesk.AutoCAD.ApplicationServices.Application.Quit();// Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Text = "CGBridge"; Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute((String)ribBtn.CommandParameter, true, false, true);
                //is from s Ribbon Textbox?
                RibbonTextBox ribTxt = parameter as RibbonTextBox;
                if (ribTxt != null) //System.Windows.Forms.MessageBox.Show(ribTxt.TextValue);
                    MessageBox.Show("fff");
第2个菜单不能激活 如何修改?
发表于 2011-3-2 13:23:41 | 显示全部楼层
用局部cui实现更简单
发表于 2011-8-5 16:29:34 | 显示全部楼层
在CAD2012上无法显示菜单,这是为什么?
发表于 2011-8-5 18:10:38 | 显示全部楼层
回楼上,应该是2010以后版本需要是在 "AutoCAD 经典" 模式下才会显示下拉菜单;
"AutoCAD 经典" 是中文版的名字,英文版我猜应该是"AutoCAD Classic";
另,本人没用过2011,2012版本
发表于 2012-7-28 20:41:05 | 显示全部楼层
正想学习呢,有用
GMT+8, 2025-5-15 22:01 , Processed in 0.168130 second(s), 24 queries , Gzip On.
