查看: 737|回复: 0
Implementing drag & drop of an image at a location and size using .NET
发表于 2011-3-1 10:25:05 | 显示全部楼层 |阅读模式
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/02/implementing-drag-drop-of-an-autocad-raster-image-at-a-specified-location-and-size-using-net.html
I’m in Las Vegas, running between meetings, presentations and performance reviews, so just a quick post, today (it’s just before midnight here, but already Monday morning in Europe).
I promised in the last post and the one before that I’d extend the code we’ve been looking at to enable drag & drop of raster images into AutoCAD with resizing of the dropped image via a jig, using the code in this previous post as a foundation.
The below C# code does just that, with the new/modified lines in red (and the complete, unnumbered source file here):
    1 using Autodesk.AutoCAD.ApplicationServices;
    2 using Autodesk.AutoCAD.DatabaseServices;
    3 using Autodesk.AutoCAD.EditorInput;
    4 using Autodesk.AutoCAD.Geometry;
    5 using Autodesk.AutoCAD.Runtime;
    6 using Autodesk.AutoCAD.Windows;
    7 using System.Runtime.InteropServices;
    8 using System.Windows.Forms;
    9 using System.Drawing;
   10 using System.IO;
   11 using System;
   12
   13 namespace DragAndDrop
   14 {
   15   public enum Msgs
   16   {
   17     WM_DRAWCLIPBOARD = 0x0308,
   18     WM_CHANGECBCHAIN = 0x030D
   19   }
   20
   21   public class ClipboardView : UserControl
   22   {
   23     [DllImport("user32.dll")]
   24     public static extern IntPtr SetClipboardViewer(
   25       IntPtr hWndNewViewer
   26     );
   27
   28     [DllImport("user32.dll", CharSet = CharSet.Auto)]
   29     public static extern IntPtr SendMessage(
   30       IntPtr hWnd, int Msg, IntPtr wParam, IntPtr lParam
   31     );
   32
   33     private IntPtr _nxtVwr;
   34     private PictureBox _img;
   35     private PaletteSet _ps;
   36
   37     public System.Drawing.Image Contents
   38     {
   39       get { return _img.Image; }
   40     }
   41
   42     public ClipboardView(PaletteSet ps)
   43     {
   44       _img = new PictureBox();
   45       _img.Anchor =
   46         (AnchorStyles)(AnchorStyles.Top |
   47                       AnchorStyles.Bottom |
   48                       AnchorStyles.Left |
   49                       AnchorStyles.Right);
   50       _img.Location = new Point(0, 0);
   51       _img.Size = this.Size;
   52       _img.SizeMode = PictureBoxSizeMode.StretchImage;
   53       Controls.Add(_img);
   54
   55       // Add our event handler to launch a new drag event
   56       // when someone clicks on the control
   57
   58       _img.MouseDown +=
   59         delegate(object sender, MouseEventArgs e)
   60         {
   61           // Simply initiate the drag & drop in AutoCAD,
   62           // specifying an instance of our custom "drop
   63           // target" class
   64
   65           Autodesk.AutoCAD.ApplicationServices.
   66           Application.DoDragDrop(
   67             _img, this.Contents, DragDropEffects.Copy,
   68             new MyDropTarget()
   69           );
   70         };
   71
   72       _nxtVwr = SetClipboardViewer(this.Handle);
   73       _ps = ps;
   74     }
   75
   76     private void ExtractImage()
   77     {
   78       IDataObject iData;
   79       try
   80       {
   81         iData = Clipboard.GetDataObject();
   82       }
   83       catch (System.Exception ex)
   84       {
   85         MessageBox.Show(ex.ToString());
   86         return;
   87       }
   88
   89       if (iData.GetDataPresent("Bitmap"))
   90       {
   91         object o = iData.GetData("Bitmap");
   92         Bitmap b = o as Bitmap;
   93         if (b != null)
   94         {
   95           _img.Image = b;
   96           if (_ps != null)
   97           {
   98             _ps.Size =
   99               new Size(b.Size.Width / 3, b.Size.Height / 3);
  100           }
  101         }
  102       }
  103     }
  104
  105     protected override void WndProc(ref Message m)
  106     {
  107       switch ((Msgs)m.Msg)
  108       {
  109         case Msgs.WM_DRAWCLIPBOARD:
  110           ExtractImage();
  111           SendMessage(_nxtVwr, m.Msg, m.WParam, m.LParam);
  112           break;
  113         case Msgs.WM_CHANGECBCHAIN:
  114           if (m.WParam == _nxtVwr)
  115             _nxtVwr = m.LParam;
  116           else
  117             SendMessage(_nxtVwr, m.Msg, m.WParam, m.LParam);
  118           break;
  119         default:
  120           base.WndProc(ref m);
  121           break;
  122       }
  123     }
  124   }
  125
  126   // Our custom drop target class
  127
  128   public class MyDropTarget : DropTarget
  129   {
  130     public override void OnDrop(DragEventArgs e)
  131     {
  132       Document doc =
  133         Autodesk.AutoCAD.ApplicationServices.Application.
  134         DocumentManager.MdiActiveDocument;
  135
  136       // If we have a valid bitmap, save it and send
  137       // our custom command (RINS)
  138
  139       if (e.Data.GetDataPresent("Bitmap"))
  140       {
  141         object o = e.Data.GetData("Bitmap");
  142         Bitmap b = o as Bitmap;
  143         if (b != null)
  144         {
  145           // We'll save the bitmap as a "temp" file
  146           // (as its unique - a better approach
  147           // would probably to create a unique file
  148           // in the same folder as the drawing, but
  149           // that's left to the reader)
  150
  151           string path = Path.GetTempFileName();
  152           b.Save(path);
  153
  154           // Call our command
  155
  156           string cmd =
  157             String.Format(
  158               "_RINS {0}\n{1},{2},0\n", path, e.X, e.Y
  159             );
  160           doc.SendStringToExecute(
  161             cmd, false, false, false
  162           );
  163         }
  164       }
  165     }
  166   }
  167
  168   public class Commands
  169   {
  170     private PaletteSet _ps = null;
  171     private ClipboardView _cv = null;
  172     static private Point3d _pt = Point3d.Origin;
  173
  174     [CommandMethod("DRAGDROP")]
  175     public void DragAndDropClipboardRaster()
  176     {
  177       if (_ps == null)
  178       {
  179         _ps = new PaletteSet(
  180           "DRAGDROP",
  181           new Guid("5C8FC28C-45ED-4796-BD40-28D235B6D7DA")
  182         );
  183
  184         if (_cv == null)
  185         {
  186           _cv = new ClipboardView(_ps);
  187         }
  188
  189         _ps.Text = "Clipboard";
  190         _ps.DockEnabled =
  191           DockSides.Left | DockSides.Right | DockSides.None;
  192         _ps.Size = new System.Drawing.Size(300, 500);
  193         _ps.Add("ClipboardView", _cv);
  194       }
  195       _ps.Visible = true;
  196     }
  197
  198
  199     // Our custom command to insert a raster image
  200
  201     [CommandMethod("RINS")]
  202     public void RasterInsert()
  203     {
  204       Document doc =
  205       Autodesk.AutoCAD.ApplicationServices.Application.
  206       DocumentManager.MdiActiveDocument;
  207       Database db = doc.Database;
  208       Editor ed = doc.Editor;
  209
  210       // Pick up the location of the bitmap image
  211
  212       PromptStringOptions pso =
  213         new PromptStringOptions(
  214           "\nPath of raster image: "
  215         );
  216       pso.AllowSpaces = true;
  217       PromptResult pr = ed.GetString(pso);
  218       if (pr.Status != PromptStatus.OK)
  219         return;
  220
  221       if (!File.Exists(pr.StringResult))
  222       {
  223         ed.WriteMessage(
  224           "\nFile does not exist."
  225         );
  226         return;
  227       }
  228
  229       string path = pr.StringResult;
  230
  231       // Pick up the position of the drop in screen coords
  232
  233       PromptPointOptions ppo =
  234         new PromptPointOptions(
  235           "\nPosition of raster image: "
  236         );
  237       PromptPointResult ppr = ed.GetPoint(ppo);
  238       if (pr.Status != PromptStatus.OK)
  239         return;
  240
  241       Point3d pos = ppr.Value;
  242
  243       // Calculate the displacement vector
  244
  245       Point3d pt =
  246         ed.PointToWorld(new Point((int)pos.X, (int)pos.Y));
  247       Matrix3d disp =
  248         Matrix3d.Displacement(pt - Point3d.Origin);
  249
  250       Transaction tr =
  251         db.TransactionManager.StartTransaction();
  252       using (tr)
  253       {
  254         // Get or create our raster image dictionary
  255
  256         ObjectId dictId =
  257           RasterImageDef.GetImageDictionary(db);
  258         if (dictId == ObjectId.Null)
  259           dictId = RasterImageDef.CreateImageDictionary(db);
  260
  261         // And open it for write
  262
  263         DBDictionary dict =
  264           (DBDictionary)tr.GetObject(
  265             dictId, OpenMode.ForWrite
  266           );
  267
  268         // Get a unique name for our definition object
  269
  270         string name = RasterImageDef.SuggestName(dict, path);
  271
  272         // Create the definition and add it to the dictionary
  273
  274         RasterImageDef rid = new RasterImageDef();
  275         rid.SourceFileName = path;
  276         rid.Load();
  277         ObjectId ridId = dict.SetAt(name, rid);
  278         tr.AddNewlyCreatedDBObject(rid, true);
  279
  280         // Now we'll add our raster image reference
  281         // to the current space
  282
  283         BlockTableRecord btr =
  284           (BlockTableRecord)tr.GetObject(
  285             db.CurrentSpaceId,
  286             OpenMode.ForWrite
  287           );
  288
  289         // Call our jig to define the raster
  290
  291         RasterJig jig =
  292           new RasterJig(
  293             ridId,
  294             rid.Size,
  295             ed.CurrentUserCoordinateSystem,
  296             pt
  297           );
  298         PromptResult prj = ed.Drag(jig);
  299
  300         if (prj.Status != PromptStatus.OK)
  301         {
  302           rid.Erase();
  303           return;
  304         }
  305
  306         // Get our entity and add it to the modelspace
  307
  308         RasterImage ri = (RasterImage)jig.GetEntity();
  309         ri.ImageDefId = ridId;
  310         ri.SetClipBoundaryToWholeImage();
  311         btr.AppendEntity(ri);
  312         tr.AddNewlyCreatedDBObject(ri, true);
  313
  314         // Create a reactor between the RasterImage and the
  315         // RasterImageDef to avoid the "unreferenced"
  316         // warning in the XRef palette
  317
  318         RasterImage.EnableReactors(true);
  319         ri.AssociateRasterDef(rid);
  320
  321         // Of course we commit
  322
  323         tr.Commit();
  324       }
  325     }
  326   }
  327
  328   class RasterJig : EntityJig
  329   {
  330     Matrix3d _ucs;
  331     Vector2d _sz;
  332     Point3d _start = Point3d.Origin;
  333     Point3d _end = Point3d.Origin;
  334
  335     public RasterJig(
  336       ObjectId defId,
  337       Vector2d sz,
  338       Matrix3d ucs,
  339       Point3d start
  340     )
  341       : base(new RasterImage())
  342     {
  343       _sz = sz;
  344       _start = start;
  345       _ucs = ucs;
  346
  347       RasterImage ri = (RasterImage)Entity;
  348       ri.ImageDefId = defId;
  349
  350       // Create a near zero size default image,
  351       // to avoid the boundary flicker
  352
  353       double size = Tolerance.Global.EqualPoint;
  354       ri.Orientation =
  355         new CoordinateSystem3d(
  356           _start,
  357           new Vector3d(size, 0, 0),
  358           new Vector3d(0, size, 0)
  359         );
  360       ri.ShowImage = true;
  361     }
  362
  363     protected override SamplerStatus Sampler(
  364       JigPrompts prompts
  365     )
  366     {
  367       JigPromptPointOptions opts =
  368         new JigPromptPointOptions();
  369       opts.UserInputControls =
  370         (UserInputControls.Accept3dCoordinates |
  371         UserInputControls.NoNegativeResponseAccepted);
  372       opts.Message = "\nSecond corner of raster image: ";
  373
  374       // Get the point itself
  375
  376       PromptPointResult res = prompts.AcquirePoint(opts);
  377
  378       if (res.Status == PromptStatus.OK)
  379       {
  380         // Convert the supplied point into UCS
  381
  382         Point3d tmp =
  383           res.Value.TransformBy(_ucs.Inverse());
  384
  385         // Check if changed (reduces flicker)
  386
  387         if (_end == tmp)
  388         {
  389           return SamplerStatus.NoChange;
  390         }
  391         else
  392         {
  393           _end = tmp;
  394           return SamplerStatus.OK;
  395         }
  396       }
  397       return SamplerStatus.Cancel;
  398     }
  399
  400     protected override bool Update()
  401     {
  402       RasterImage ri = (RasterImage)Entity;
  403
  404       // Get offset between the two corners
  405
  406       Vector3d diff = _end - _start;
  407
  408       // Get the ratios of the dimensions of the dragged
  409       // image with the source
  410
  411       double sizeX = Math.Abs(diff.X),
  412             sizeY = Math.Abs(diff.Y),
  413             ratX = sizeX / _sz.X,
  414             ratY = sizeY / _sz.Y;
  415
  416       // Find out which is bigger and use that to decide
  417       // which size should change to keep the proportion
  418
  419       bool biggerX = (ratX > ratY);
  420
  421       if (biggerX)
  422         sizeY = ratX * _sz.Y;
  423       else
  424         sizeX = ratY * _sz.X;
  425
  426       // Determine the image's orientation...
  427
  428       // The original will depend on the order of the corners
  429       // It will be offset to the left and/or down depending
  430       // on the values of the vector between the two points
  431
  432       Point3d orig;
  433
  434       // The axes stay the same, as we will always keep the
  435       // image oriented the same way relative to the UCS
  436
  437       Vector3d xAxis = new Vector3d(sizeX, 0, 0);
  438       Vector3d yAxis = new Vector3d(0, sizeY, 0);
  439
  440       if (diff.X > 0 && diff.Y > 0) // Dragging top-right
  441         orig = _start;
  442       else if (diff.X < 0 && diff.Y > 0) // Top-left
  443         orig = _start + new Vector3d(-sizeX, 0, 0);
  444       else if (diff.X > 0 && diff.Y < 0) // Bottom-right
  445         orig = _start + new Vector3d(0, -sizeY, 0);
  446       else // if (diff.X < 0 && diff.Y < 0) // Bottom-left
  447         orig = _start - new Vector3d(sizeX, sizeY, 0);
  448
  449       // Set the image's orientation in WCS
  450
  451       ri.Orientation =
  452         new CoordinateSystem3d(
  453           orig.TransformBy(_ucs),
  454           xAxis.TransformBy(_ucs),
  455           yAxis.TransformBy(_ucs)
  456         );
  457
  458       return true;
  459     }
  460
  461     public Entity GetEntity()
  462     {
  463       return Entity;
  464     }
  465   }
  466 }
When we run the new DRAGDROP command and drag & drop from our palette onto the drawing, we see the raster images are now inserted and sized by the jig proportionally to the original image’s size:
GMT+8, 2025-11-25 11:36 , Processed in 0.235611 second(s), 31 queries , Gzip On.
