查看: 1389|回复: 2
请教扩展数据问题
发表于 2011-3-14 19:02:29 | 显示全部楼层 |阅读模式
请问XDATA中扩展数据组码从1000到1071好像只有1000与1001可以存储字符串数据,
我想存储字符串应该怎么做。我想在图元上存储厚度,名称等信息
 楼主| 发表于 2011-3-14 19:38:19 | 显示全部楼层
' This example creates a line and attaches extended data to that line.
    ' Create the line
    Dim lineObj As AcadLine
    Dim startPt(0 To 2) As Double, endPt(0 To 2) As Double
    startPt(0) = 1#: startPt(1) = 1#: startPt(2) = 0#
    endPt(0) = 5#: endPt(1) = 5#: endPt(2) = 0#
    Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
    ZoomAll
    ' Initialize all the xdata values. Note that first data in the list should be
    ' application name and first datatype code should be 1001
    Dim DataType(0 To 9) As Integer
    Dim Data(0 To 9) As Variant
    Dim reals3(0 To 2) As Double
    Dim worldPos(0 To 2) As Double
    DataType(0) = 1001: Data(0) = "Test_Application"
    DataType(1) = 1000: Data(1) = "This is a test for xdata"
    DataType(2) = 1003: Data(2) = "0"                   ' layer
    DataType(3) = 1040: Data(3) = 1.23479137438413E+40  ' real
    DataType(4) = 1041: Data(4) = 1237324938            ' distance
    DataType(5) = 1070: Data(5) = 32767                 ' 16 bit Integer
    DataType(6) = 1071: Data(6) = 32767                 ' 32 bit Integer
    DataType(7) = 1042: Data(7) = 10                    ' scaleFactor
    reals3(0) = -2.95: reals3(1) = 100: reals3(2) = -20
    DataType(8) = 1010: Data(8) = reals3                ' real
    worldPos(0) = 4: worldPos(1) = 400.99999999: worldPos(2) = 2.798989
    DataType(9) = 1011: Data(9) = worldPos              ' world space position
    ' Attach the xdata to the line
    lineObj.SetXData DataType, Data
也就是说能不能把Data(0) ~Data(9)全部改为字符串类型?
发表于 2011-9-20 16:27:46 | 显示全部楼层
你把你所有的数据全部变成字符串后,用物殊字符串间隔一下后全部连成一个单一的字符串放入Data(1)就可以了,取出来时,用Split函数分开就行了.
GMT+8, 2025-9-10 04:29 , Processed in 0.157397 second(s), 24 queries , Gzip On.
