查看: 704|回复: 0
Adding ortho support to the transient graphics AutoCAD MOVE using .NET
发表于 2011-3-17 15:23:57 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/03/adding-ortho-support-to-the-transient-graphics-autocad-move-using-net.html
As promised, I ended up burning more that a few hours this evening (after being up very early for meetings this morning), to add orthographic drawing support to the code shown in the last post. It took quite some work, switching between UCS and WCS until my head was more than a little twisted. This thread on The Swamp provided well-needed inspiration, too (thanks, MickD :-).
Here’s the C# code – I would have highlighted the modified lines in red, but the code is too wide to add 3-digit lines without it looking ugly, and – besides – I need to call it a night.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Runtime;
using System.Collections.Generic;
using System;
namespace CustomMove
  public class Commands
    [CommandMethod("MYMOVE", CommandFlags.UsePickSet)]
    public static void CustomMoveCmd()
      Document doc =
        Autodesk.AutoCAD.ApplicationServices.
          Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Matrix3d ucs = ed.CurrentUserCoordinateSystem;
      // Start by getting the objects to move
      // (will use the pickfirst set, if defined)
      PromptSelectionResult psr = ed.GetSelection();
      if (psr.Status != PromptStatus.OK || psr.Value.Count == 0)
        return;
      // Create a collection of the selected objects' IDs
      ObjectIdCollection ids =
        new ObjectIdCollection(psr.Value.GetObjectIds());
      // Ask the user to select a base point for the move
      PromptPointResult ppr =
        ed.GetPoint("\nSpecify base point: ");
      if (ppr.Status != PromptStatus.OK)
        return;
      Point3d baseUcs = ppr.Value;
      CoordinateSystem3d cs = ucs.CoordinateSystem3d;
      // Transform from UCS to WCS
      Matrix3d mat =
        Matrix3d.AlignCoordinateSystem(
          Point3d.Origin,
          Vector3d.XAxis,
          Vector3d.YAxis,
          Vector3d.ZAxis,
          cs.Origin,
          cs.Xaxis,
          cs.Yaxis,
          cs.Zaxis
      Point3d baseWcs = baseUcs.TransformBy(mat);
      Point3d curPt = baseWcs;
      // A local delegate for our event handler so
      // we can remove it at the end
      PointMonitorEventHandler handler = null;
      // Our transaction
      Transaction tr =
        doc.Database.TransactionManager.StartTransaction();
      using (tr)
        // Create our transient drawables, with associated
        // graphics, from the selected objects
        List<Drawable> drawables = CreateTransGraphics(tr, ids);
        try
          // Add our point monitor
          // (as a delegate we have access to basePt and curPt,
          //  which avoids having to access global/member state)
          handler =
            delegate(object sender, PointMonitorEventArgs e)
              // Get the point, with "ortho" applied, if needed
              Point3d pt = e.Context.ComputedPoint;
              if (IsOrthModeOn())
                // Point is in WCS, we need UCS for ortho calcs
                Point3d destUcs = pt.TransformBy(mat.Inverse());
                pt = GetOrthoPoint(baseUcs, destUcs);
                // Then we transform back to WCS
                pt = pt.TransformBy(mat);
              // Update our graphics and the current point
              UpdateTransGraphics(drawables, curPt, pt);
              curPt = pt;
          ed.PointMonitor += handler;
          // Ask for the destination, during which the point
          // monitor will be updating the transient graphics
          PromptPointOptions opt =
            new PromptPointOptions("\nSpecify second point: ");
          opt.UseBasePoint = true;
          opt.BasePoint = baseUcs;
          ppr = ed.GetPoint(opt);
          // If the point was selected successfully...
          if (ppr.Status == PromptStatus.OK)
            // ... move the entities to their destination
            Point3d destUcs = ppr.Value;
            Point3d dest =
              (IsOrthModeOn() ?
                GetOrthoPoint(baseUcs, destUcs) :
                destUcs);
            MoveEntities(tr, baseWcs, dest.TransformBy(mat), ids);
            // And inform the user
            ed.WriteMessage(
              "\n{0} object{1} moved.", ids.Count,
              ids.Count == 1 ? "" : "s"
        catch (Autodesk.AutoCAD.Runtime.Exception ex)
          ed.WriteMessage("\nException: {0}", ex.Message);
        finally
          // Clear any transient graphics
          ClearTransGraphics(drawables);
          // Remove the event handler
          if (handler != null)
            ed.PointMonitor -= handler;
          tr.Commit();
          tr.Dispose();
    private static bool IsOrthModeOn()
      // Check the value of the ORTHOMODE sysvar
      object orth =
        Autodesk.AutoCAD.ApplicationServices.Application.
        GetSystemVariable("ORTHOMODE");
      return Convert.ToInt32(orth) > 0;
    private static Point3d GetOrthoPoint(
      Point3d basePt, Point3d pt
      // Apply an orthographic mode
      double x = pt.X,
            y = pt.Y,
            z = pt.Z;
      Vector3d vec = basePt.GetVectorTo(pt);
      double absX = Math.Abs(vec.X),
            absY = Math.Abs(vec.Y),
            absZ = Math.Abs(vec.Z);
      if (absX < absY && absX < absZ)
        x = basePt.X;
      else if (absY < absX && absY < absZ)
        y = basePt.Y;
      else
        z = pt.Z;
      return new Point3d(x, y, z);
    private static void MoveEntities(
      Transaction tr, Point3d basePt, Point3d moveTo,
      // Transform a set of entities to a new location
      Matrix3d mat =
        Matrix3d.Displacement(basePt.GetVectorTo(moveTo));
      foreach (ObjectId id in ids)
        Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
        ent.TransformBy(mat);
    private static List<Drawable> CreateTransGraphics(
      Transaction tr, ObjectIdCollection ids
      // Create our list of drawables to return
      List<Drawable> drawables = new List<Drawable>();
        // Read each entity
        Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
        // Clone it, make it red & add the clone to the list
        Entity drawable = ent.Clone() as Entity;
        drawable.ColorIndex = 1;
        drawables.Add(drawable);
      // Draw each one initially
      foreach (Drawable d in drawables)
        TransientManager.CurrentTransientManager.AddTransient(
          d, TransientDrawingMode.DirectShortTerm,
          128, new IntegerCollection()
      return drawables;
    private static void UpdateTransGraphics(
      List<Drawable> drawables, Point3d curPt, Point3d moveToPt
      // Displace each of our drawables
      Matrix3d mat =
        Matrix3d.Displacement(curPt.GetVectorTo(moveToPt));
      // Update their graphics
        Entity e = d as Entity;
        e.TransformBy(mat);
        TransientManager.CurrentTransientManager.UpdateTransient(
          d, new IntegerCollection()
    private static void ClearTransGraphics(
      // Clear the transient graphics for our drawables
      TransientManager.CurrentTransientManager.EraseTransients(
      // Dispose of them and clear the list
        d.Dispose();
      drawables.Clear();
The code should now work irrespective of non-standard UCS and 3D views being active, supporting ORTHOMODE in 3D, also.
I think the next step is to look at paperspace viewport issues – as raised by Thorsten Meinecke – and probably to compare this implementation with that of a jig. We’ll see about that next week, I expect.
GMT+8, 2025-11-25 11:31 , Processed in 0.188512 second(s), 31 queries , Gzip On.
