查看: 1603|回复: 0
Generating a mesh for a 3D solid using AutoCAD’s Brep API from .NET
发表于 2011-3-25 13:52:41 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/03/generating-a-mesh-for-a-3d-solid-using-autocads-brep-api-from-net.html
Thanks for Balaji Ramamoorthy – who recently joined our team in India – and Adam Nagy for helping generate the code for this post.
There are lots of reasons people might want to tessellate a 3D solid in AutoCAD to generate a mesh. The code in today’s post uses the  Boundary Representation (Brep) API in AutoCAD to do just that, generating a set of 3D faces.
A few points about the implementation:
  • I’ve only made a small number of settings to control the mesh generation: more are available for you to experiment with.
  • It should be simple enough to generate a SubDMesh, rather than a set of faces, but that’s left as an exercise for the reader.
  • I only tested with a very simple solid (a sphere). The settings may need tweaking depending on he complexity of the solid you’re meshing.
Here’s the C# code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.BoundaryRepresentation;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
namespace MeshSolid
  public class MeshCreator
    // Mesh a selected solid
    [CommandMethod("SOLMESH")]
    static public void MeshFromSolid()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      // Ask the user to select a solid
      PromptEntityOptions peo =
        new PromptEntityOptions("Select a 3D solid");
      peo.SetRejectMessage("\nA 3D solid must be selected.");
      peo.AddAllowedClass(typeof(Solid3d), true);
      PromptEntityResult per = ed.GetEntity(peo);
      if (per.Status != PromptStatus.OK)
        return;
      Transaction tr =
        db.TransactionManager.StartTransaction();
      using (tr)
        BlockTable bt =
          (BlockTable)tr.GetObject(
            db.BlockTableId,
            OpenMode.ForRead,
            false
        BlockTableRecord btr =
          (BlockTableRecord)tr.GetObject(
            bt[BlockTableRecord.ModelSpace],
            OpenMode.ForWrite,
            false
        Solid3d sol =
          tr.GetObject(
            per.ObjectId,
            OpenMode.ForRead
          ) as Solid3d;
        // Calculate the approximate size of our solid
        double length =
          sol.GeometricExtents.MinPoint.GetVectorTo(
            sol.GeometricExtents.MaxPoint
          ).Length;
        try
          using (Brep brp = new Brep(sol))
            // Create and set our mesh control object
            using (Mesh2dControl mc = new Mesh2dControl())
              // These settings seem extreme, but only result
              // in ~500 faces for a sphere (during my testing,
              // anyway). Other control settings are available
              mc.MaxNodeSpacing = length / 10000;
              mc.MaxSubdivisions = 100000000;
              // Create a mesh filter object
              using (Mesh2dFilter mf = new Mesh2dFilter())
                // Use it to map our control settings to the Brep
                mf.Insert(brp, mc);
                // Generate a mesh using the filter
                using (Mesh2d m = new Mesh2d(mf))
                  // Extract individual faces from the mesh data
                  foreach (Element2d e in m.Element2ds)
                    Point3dCollection pts = new Point3dCollection();
                    foreach (Node n in e.Nodes)
                      pts.Add(n.Point);
                    // A face could be a triangle or a quadrilateral
                    // (the Booleans indicate the edge visibility)
                    AcDb.Face face = null;
                    if (pts.Count == 3)
                      face =
                        new AcDb.Face(
                          pts[0], pts[1], pts[2],
                          true, true, true, true
                    else if (pts.Count == 4)
                      face =
                        new AcDb.Face(
                          pts[0], pts[1], pts[2], pts[3],
                    // If we have a valid face, add it to the
                    // database and the transaction
                    if (face != null)
                      // Make each face yellow for visibility
                      face.ColorIndex = 2;
                      btr.AppendEntity(face);
                      tr.AddNewlyCreatedDBObject(face, true);
          tr.Commit();
        catch (System.Exception ex)
          ed.WriteMessage("Exception: {0}", ex.Message);
Here’s what happens when we run the SOLMESH command, selecting a simple sphere (which I later moved to the side, for comparison):
And now with the realistic visual style set, just to show we have opacity:
GMT+8, 2025-5-24 01:34 , Processed in 0.160762 second(s), 31 queries , Gzip On.
