查看: 900|回复: 0
Drawing transient graphics appropriately in AutoCAD within m-paperspace vp
发表于 2011-3-30 20:43:12 | 显示全部楼层 |阅读模式
Drawing transient graphics appropriately in AutoCAD within multiple paperspace viewports using .NET
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/03/drawing-transient-graphics-appropriately-in-autocad-within-multiple-paperspace-viewports-using-net.html
We’ve been looking a lot at transient graphics, recently. The standard approach we’ve been using to displaying graphics in all viewports has been to pass in an empty IntegerCollection into the various transient graphics-related methods, rather than listing the viewports specifically in which we want to display the graphics.
Thorsten Meinecke made the very valid point that this doesn’t always work as you’d like, particularly when you have multiple floating paperspace viewport. Now I fully admit I’m not a big user of viewports, as far as it goes, so I sometimes forget to cater for scenarios that are probably extremely common among AutoCAD users. Thorsten also kindly provided some code that does a much better job of supporting display in multiple viewports.
Here’s Thorsten’s C# code (formatted to fit this blog):
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using System.Collections.Generic;
using System;
namespace MyInsert
  public class MyInsertCommand
    // The command MyInsert displays the transient entity
    // in all viewports (IntegerCollection is always empty)
    [CommandMethod("MyInsert")]
    public void MyInsert()
      MyInsertCmd(new int[] { });
    // The command MyInsertVP tries to be sensible: it
    // shows the transient entity in all viewports only
    // when TILEMODE = 1; in the paper space viewport
    // alone when CVPORT = 1; else in the active floating
    // viewports
    [CommandMethod("MyInsertVP")]
    public void MyInsertVP()
      MyInsertCmd(ViewportNumbers());
    // Naive implementation of block insert to demonstrate
    // the display of a transient entity
    void MyInsertCmd(int[] vps)
      Document doc =
          Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Database db = HostApplicationServices.WorkingDatabase;
      // Ask user for a block name and check if it's in
      // the BlockTable
      PromptStringOptions pso =
        new PromptStringOptions("Block name")
          AllowSpaces = true
      PromptResult psr = ed.GetString(pso);
      if (psr.Status != PromptStatus.OK)
        return;
      Transaction tr =
        db.TransactionManager.StartTransaction();
      using (tr)
        BlockTable bt =
          (BlockTable)tr.GetObject(
            db.BlockTableId, OpenMode.ForRead
        if (!bt.Has(psr.StringResult))
          ed.WriteMessage(
            "\nBlock {0} not found.", psr.StringResult
        else
          // Set up the BlockReference to draw as transient
          AcGi.TransientManager ctm =
            AcGi.TransientManager.CurrentTransientManager;
          IntegerCollection ints = new IntegerCollection(vps);
          BlockReference br =
            new BlockReference(
              Point3d.Origin, bt[psr.StringResult]
          ctm.AddTransient(
            br, AcGi.TransientDrawingMode.DirectShortTerm,
            128, ints
          // Add event handler for PointMonitor event, then
          // let user select an insertion point, afterwards
          // ensure removal of event handler and transient
          PointMonitorEventHandler handler =
            delegate(object sender, PointMonitorEventArgs e)
              br.Position = e.Context.RawPoint;
              ctm.UpdateTransient(br, ints);
          ed.PointMonitor += handler;
          PromptPointResult ppr;
          try
            ppr = ed.GetPoint("Select insertion point");
          finally
            ed.PointMonitor -= handler;
            ctm.EraseTransient(br, ints);
          // If insertion point selection was
          // successfull, add BlockReference to
          // current space
          if (ppr.Status == PromptStatus.OK)
            BlockTableRecord cs =
              (BlockTableRecord)tr.GetObject(
                db.CurrentSpaceId, OpenMode.ForWrite
            cs.AppendEntity(br);
            tr.AddNewlyCreatedDBObject(br, true);
        // Common exit point for all code paths inside
        // using statement
        tr.Commit();
    // Determines which viewports will display the transient
    int[] ViewportNumbers()
      Document doc =
      // Are we in model space outside floating viewports?
      // Then we'll initalize an empty IntegerCollection
      if (db.TileMode)
        return new int[] {};
      IList<int> vps = new List<int>();
      Transaction tr =
      using (tr)
        Viewport vp =
          tr.GetObject(ed.ActiveViewportId, OpenMode.ForRead)
            as Viewport;
        // Are we in paper space and not inside a floating
        // viewport? Then only the paper space viewport itself
        // is of interest
        if (vp != null && vp.Number == 1)
          vps.Add(1);
        else
          // Now we're inside a floating viewport and
          // will display transients in active viewports
          foreach (ObjectId vpId in db.GetViewports(false))
            vp = (Viewport)tr.GetObject(vpId, OpenMode.ForRead);
            vps.Add(vp.Number);
        tr.Commit();
      int[] ints = new int[vps.Count];
      vps.CopyTo(ints, 0);
      return ints;
The above code defines two commands:
  • MYINSERT, which uses the “empty IntegerCollection” approach to show transients in all viewports
  • MYINSERTVP, which uses a more controlled approach to display the graphics in selected paperspace viewports
To demonstrate the problem with the first approach, let’s take a paperspace view with two floating viewports:
When we make the larger viewport active and start the MYINSERT command to insert a block, we sometimes see unwanted graphics in the top-level paperspace view:
But if we use MYINSERTVP, we don’t have that problem:
Many thanks, Thorsten, for highlighting this issue and providing a solution for it! :-)
GMT+8, 2025-5-24 01:37 , Processed in 0.206262 second(s), 32 queries , Gzip On.
