查看: 1467|回复: 3
求助:xdata
发表于 2011-4-3 19:32:05 | 显示全部楼层 |阅读模式
代码运行到出错,添加时候出错  pObj->close();
        acutRelRb(pRb);
        return TRUE;请教:源码如下:
 楼主| 发表于 2011-4-3 19:32:43 | 显示全部楼层
代码:
bool AddXData(ads_name ename,ACHAR *appname,ACHAR *resString){
        struct resbuf *pRb=NULL,*pTemp;
        AcDbObjectId objId;
        AcDbObject *pObj;
        if(acdbGetObjectId(objId,ename)!=Acad::eOk)return 0;
        acdbOpenObject(pObj,objId,AcDb::kForWrite);
        pRb=pObj->xData(appname);
        if (pRb==NULL) {
                acdbRegApp(appname);
                pRb=acutNewRb(AcDb::kDxfRegAppName);
                pTemp=pRb;
                pTemp->resval.rstring=(ACHAR*)malloc(_tcslen(appname)+1);
                _tcscpy(pTemp->resval.rstring,appname);
        }else{
                for (pTemp=pRb;pTemp->rbnext!=NULL;pTemp=pTemp->rbnext) {;}
        pTemp->rbnext=acutNewRb(AcDb::kDxfXdAsciiString);
        pTemp=pTemp->rbnext;
        pTemp->resval.rstring=(ACHAR*)malloc(_tcslen(resString)+1);
        _tcscpy(pTemp->resval.rstring,resString);
        //pObj->upgradeOpen();
        pObj->setXData(pRb);
        pObj->close();
        acutRelRb(pRb);
        return TRUE;
 楼主| 发表于 2011-4-3 19:33:21 | 显示全部楼层
static void S001xdata_2_MyCommand1(void)
        {                 ads_name ename;
                         ads_point pt1;
                         if (acedEntSel(L"\n请选择对象:",ename,pt1)!=RTNORM)return;
                        ACHAR appname[20],resString[80];
                         _tcscpy(appname,                                 L"abcd");
                         _tcscpy(resString,L"BDYCAD在学习ARX");
                         //if (acedGetString(NULL,"\n请输入扩展名:",appname)!=RTNORM)return;
                         //if (acedGetString(NULL,"\n请输入扩展数据的内容吧:",resString)!=RTNORM)return;
                         AddXData(ename,L"abcd",resString);
                         //return;
 楼主| 发表于 2011-4-3 19:34:00 | 显示全部楼层
请大神出手,谢谢
GMT+8, 2025-7-16 14:48 , Processed in 0.174290 second(s), 23 queries , Gzip On.
