查看: 2385|回复: 5
[源码] 怎样判断两条多段线的采集方向是否相同?
发表于 2011-4-3 23:34:16 | 显示全部楼层 |阅读模式
如题,怎样判断两条多段线的采集方向是否相同?只要判断是否大致相同就可以了...
发表于 2012-9-13 17:06:28 | 显示全部楼层
取之明经,用之明经
(defun c:ttt()
(setq en (car (entsel)))
(setq ptlist (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget en))))
(GE_WhatPoly ptlist)
(defun GE_WhatPoly (ptlist / nverts cnt area tmp pt1 pt2)
(setq
        cnt 0
        nverts (length ptlist)
        area 0.0
(while (< cnt (1- nverts))
(setq
        pt1 (nth cnt ptlist)
        pt2 (nth (1+ cnt) ptlist)
        area (+ area (* (cadr pt1) (car pt2)))
        cnt (1+ cnt)
(setq
        pt1 (nth (1- nverts) ptlist)
        pt2 (nth 0 ptlist)
        cnt 0
        tmp 0.0
(setq
        tmp (+ tmp (* (cadr pt2) (car pt1)))
        cnt (1+ cnt)
(setq
        pt1 (nth 0 ptlist)
        pt2 (nth (1- nverts) ptlist)
        tmp (+ tmp (* (cadr pt1) (car pt2)))
        area (* 0.5 (- area tmp))
(cond
        ((< area 0.0) (setq area -1) )
        ((> area 0.0) (setq area  1) )
        (T (setq area 0) )
area
发表于 2011-4-4 10:43:45 | 显示全部楼层
采集方向是什么意思?如果是顺逆时针的话,论坛上判断顺逆的lsp很多。
发表于 2011-4-4 12:54:37 | 显示全部楼层
跟着了解一下.....
 楼主| 发表于 2011-4-4 17:00:51 | 显示全部楼层
采集方向不是顺逆时针,类似于水流方向的意思
GMT+8, 2025-5-19 17:52 , Processed in 0.364175 second(s), 27 queries , Gzip On.
