查看: 3789|回复: 15
自动画穿线孔
发表于 2011-4-28 19:26:09 | 显示全部楼层 |阅读模式
(defun c:czk()(setq cmd(getvar "cmdecho"))
             (setvar "cmdecho" 0)
             (setq pl(getpoint "\nselect a point:"))
             (command "circle" "none" pl 1.5 )
             (command "line" "none" "@-2,0" "none" "@4,0" "")
             (command "line" "none" "@-2,-2" "none" "@0,4" "")
             (setvar "cmdecho" cmd))
上面是一个画穿线孔的程序,但是它只能画出孔来,不能将它变成一个块,谁能给它加上画出穿线孔后变成图块啊,谢谢大家了
发表于 2011-4-28 21:00:35 | 显示全部楼层
为什么要做块。编程的时只要把块炸开。要做块不难!
发表于 2011-4-28 21:21:07 | 显示全部楼层
defun c:ah()
(vl-load-com)
(command "undo" be)
(princ "/n请选取要加引线孔的槽孔 POLYLINE:")
(setq hy_ms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq ss (ssget '((0 . "*POLYLINE") (70 . 1) (90 . 4))));对POLYLINE图形有效
;(setq ss (ssget '((0 . "line") )))  ---这里是对线条有效,
(setq k 0)
;(command "pedit" "m" ss "" "y" "j" "" "")
(setq ent (entlast))
;(repeat (sslength ss)
;(setq ent (ssname ss k))
(vla-getboundingbox (vlax-ename->vla-object ent) 'minpoint 'maxpoint )
(setq maxpoint (vlax-safearray->list maxpoint)
minpoint (vlax-safearray->list minpoint)
maxpoint (trans maxpoint 0 1)
minpoint (trans minpoint 0 1)
mx (/ (+ (car maxpoint) (car minpoint)) 2.0)
my (/ (+ (cadr maxpoint) (cadr minpoint)) 2.0)
dx (/ (- (car maxpoint) (car minpoint)) 2.0)
dy (/ (- (cadr maxpoint) (cadr minpoint)) 2.0)
mpt (list mx my)
(cond
((> dx dy)(setq mpt1 (list mx (+ my dy))))
((< dx dy)(setq mpt1 (list (+ mx dx) my)))
(command "layer" "s" "4" "")
;(command "line" mpt mpt1 "")
(command "layer" "s" "0" "")
(command "circle" mpt "0.33")
(vla-addline hy_ms (vlax-3d-point (trans mpt 1 0)) (vlax-3d-point (trans mpt1 1 0)))
(setq k (1+ k))
;(command "explode" ent)
;(command "undo" e)
(command "layer" "s" "cut" "")
这个相对小些的图形用来画还OK,因为是在中心画线和圆,
 楼主| 发表于 2011-4-28 21:31:53 | 显示全部楼层
回复 lenlenq 的帖子
公司的习惯,我们这里是这样的,所以想问问大家有没有这样的程序,请楼主指教
 楼主| 发表于 2011-4-28 21:42:57 | 显示全部楼层
回复 linheyuanpcb 的帖子
谢谢楼主的程序,只是穿线孔爱跑到别的地方去了,愿楼主再改一改
发表于 2011-4-29 06:32:52 | 显示全部楼层
回复 linheyuanpcb 的帖子
怪,加载不了,与我的程序方式冲突,慢慢看看
谢谢楼主的分享
发表于 2011-4-29 06:56:30 | 显示全部楼层
谢谢楼主的分享
发表于 2011-4-29 08:58:16 | 显示全部楼层
把它炸开就行了
发表于 2011-4-29 09:07:41 | 显示全部楼层
这个不好用,
试下这个吧,虽然不能批量放,但也比线圆这样去画
两点中心画引线孔[输入距离或点取距离/2 中心处]
(defun c:tt (/ pt1 pt2 pt12 bj)
(princ "/n两点中心放置线切割引线+0.66mm孔:")
(setq bj 0.33);这里修改圆孔的半径
(setq pt1 (getpoint "\n点取第一点:")
  pt2 (getpoint pt1 "\n点取第二点:")
  pt12 (list
(* 0.5 (+ (nth 0 pt1) (nth 0 pt2)))
(* 0.5 (+ (nth 1 pt1) (nth 1 pt2)))
(* 0.5 (+ (nth 2 pt1) (nth 2 pt2)))
(command "layer" "s" "4" "");放置层
(command "line" PT1 pt12  "")
(command "layer" "s" "0" "");放置层
;(command "color" 255)
(command ".circle" pt12 bj)
发表于 2011-4-29 09:37:47 | 显示全部楼层
defun c:ah()
(vl-load-com)
(command "undo" be)
(setq k 0)
mpt (list mx my)
(cond
(setq k (1+ k))
(command "undo" e)
这只对一个新图形有效,有高手改动下,  如果两个图,只对一个有效,但另画一个新的就可以操作,
GMT+8, 2025-4-30 14:27 , Processed in 0.187774 second(s), 27 queries , Gzip On.
