查看: 761|回复: 0
Enhanced Kinect integration for 3D polyline creation
发表于 2011-4-29 17:47:58 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/04/enhanced-kinect-integration-for-3d-polyline-creation.html
I’ve improved the basic implementation in this previous post pretty significantly over the last week:
  • New ability to draw multiple polylines
    • Added a gesture of lowering/raising the left hand to start/finish drawing with the right
  • Addition of a transient sphere as a 3D cursor for polyline drawing
  • Quick flash of a transient skeleton (arms and chest only) on user detection
  • The jig now perpetuates by changing the screen cursor minutely to and fro
    • Mouse input is needed to keep the jig active; Kinect input doesn’t yet count :-)
  • A new gesture of placing hands together to end drawing
At Barry Ralphs’ suggestion, I also invested some time in creating a video of the application in action:
http://www.youtube.com/embed/V5cZtxfeSwg
The updated C# code is here:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using System.Runtime.InteropServices;
using System.Collections.Generic;
using System.Windows.Media;
using System.Diagnostics;
using System.Reflection;
using System.IO;
using System;
using NKinect;
namespace KinectIntegration
  public class KinectJig : DrawJig
    [DllImport("acad.exe", CharSet = CharSet.Auto,
      CallingConvention = CallingConvention.Cdecl,
      EntryPoint = "?acedPostCommand@@YAHPB_W@Z"
    extern static private int acedPostCommand(string strExpr);
    // A transaction and database to add polylines
    private Transaction _tr;
    private Document _doc;
    // We need our nKinect sensor
    private Sensor _kinect = null;
    // A list of points captured by the sensor
    // (for eventual export)
    private List<ColorVector3> _vecs;
    // A list of points to be displayed
    // (we use this for the jig)
    private Point3dCollection _points;
    // A list of vertices to draw between
    // (we use this for the final polyline creation)
    private Point3dCollection _vertices;
    // The most recent vertex being captured/drawn
    private Point3d _curPt;
    private Entity _cursor;
    // A list of line segments being collected
    // (pass these as AcGe objects as they may
    // get created on a background thread)
    private List<LineSegment3d> _lineSegs;
    // The database lines we use for temporary
    // graphics (that need disposing afterwards)
    private DBObjectCollection _lines;
    // An offset value we use to move the mouse back
    // and forth by one screen unit
    private int _offset;
    // Flags to indicate Kinect gesture modes
    private bool _calibrating; // First skeleton callback
    private bool _drawing;     // Drawing mode active
    private bool _finished;    // Finished - want to exit
    public bool Finished
      get { return _finished; }
    public KinectJig(Document doc, Transaction tr)
      // Initialise the various members
      _doc = doc;
      _tr = tr;
      _points = new Point3dCollection();
      _vertices = new Point3dCollection();
      _lineSegs = new List<LineSegment3d>();
      _lines = new DBObjectCollection();
      _cursor = null;
      _offset = 1;
      _calibrating = true;
      _drawing = false;
      _finished = false;
      // Create our sensor object - the constructor takes
      // three callbacks to receive various data:
      // - skeleton movement
      // - rgb data
      // - depth data
      _kinect =
        new Sensor(
          s =>
            if (_calibrating)
              DrawSkeleton(s);
            else
              if (!_finished)
                _drawing = (s.LeftHand.Y < s.LeftHip.Y);
                // Get the current position of the hands
                Point3d right =
                  new Point3d(
                    s.RightHand.X,
                    s.RightHand.Y,
                    s.RightHand.Z
                Point3d left =
                  new Point3d(
                    s.LeftHand.X,
                    s.LeftHand.Y,
                    s.LeftHand.Z
                if (left.DistanceTo(right) < 50.0)
                  _drawing = false;
                  _finished = true;
                if (_drawing)
                  // If we have at least one prior vertex...
                  if (_vertices.Count > 0)
                    // ... connect them together with
                    // a temp LineSegment3d
                    Point3d lastVert =
                      _vertices[_vertices.Count - 1];
                    if (lastVert.DistanceTo(right) >
                        Tolerance.Global.EqualPoint)
                      _lineSegs.Add(
                        new LineSegment3d(lastVert, right)
                  // Add the new vertex to our list
                  _vertices.Add(right);
          r =>
          d =>
    public void StartSensor()
      if (_kinect != null)
        _kinect.Start();
    public void StopSensor()
        _kinect.Stop();
        _kinect.Dispose();
        _kinect = null;
    private void DrawSkeleton(UserSkeleton s)
      _lineSegs.Add(
        new LineSegment3d(
          new Point3d(
            s.LeftHand.X, s.LeftHand.Y, s.LeftHand.Z
          new Point3d(
            s.LeftElbow.X, s.LeftElbow.Y, s.LeftElbow.Z
      _lineSegs.Add(
        new LineSegment3d(
          new Point3d(
          new Point3d(
            s.LeftShoulder.X, s.LeftShoulder.Y, s.LeftShoulder.Z
      _lineSegs.Add(
        new LineSegment3d(
          new Point3d(
          new Point3d(
            s.RightShoulder.X, s.RightShoulder.Y, s.RightShoulder.Z
      _lineSegs.Add(
        new LineSegment3d(
          new Point3d(
          new Point3d(
            s.RightElbow.X, s.RightElbow.Y, s.RightElbow.Z
      _lineSegs.Add(
        new LineSegment3d(
          new Point3d(
          new Point3d(
            s.RightHand.X, s.RightHand.Y, s.RightHand.Z
    protected override SamplerStatus Sampler(JigPrompts prompts)
      // Se don't really need a point, but we do need some
      // user input event to allow us to loop, processing
      // for the Kinect input
      PromptPointResult ppr =
        prompts.AcquirePoint("\nClick to capture: ");
      if (ppr.Status == PromptStatus.OK)
        if (_finished)
          _doc.SendStringToExecute(
            "\x1b\x1b ", false, false, false
          acedPostCommand("CANCELCMD");
          return SamplerStatus.Cancel;
        if (!_drawing && _lines.Count > 0)
          AddPolylines();
        // Generate a point cloud via nKinect
        try
          _vecs = _kinect.GeneratePointCloud();
          // Extract the points for display in the jig
          // (note we only take 1 in 5)
          _points.Clear();
          for (int i = 0; i < _vecs.Count; i += 10)
            ColorVector3 vec = _vecs[i];
            _points.Add(
              new Point3d(vec.X, vec.Y, vec.Z)
          // Let's move the mouse slightly to avoid having
          // to do it manually to keep the input coming
          System.Drawing.Point pt =
            System.Windows.Forms.Cursor.Position;
          System.Windows.Forms.Cursor.Position =
            new System.Drawing.Point(
              pt.X, pt.Y + _offset
          _offset = -_offset;
        catch {}
        return SamplerStatus.OK;
    protected override bool WorldDraw(AcGi.WorldDraw draw)
      // This simply draws our points
      draw.Geometry.Polypoint(_points, null, null);
      AcGi.TransientManager ctm =
        AcGi.TransientManager.CurrentTransientManager;
      IntegerCollection ints = new IntegerCollection();
      // Draw any outstanding segments (and do so only once)
      bool wasCalibrating = _calibrating;
      while (_lineSegs.Count > 0)
        // Get the line segment and remove it from the list
        LineSegment3d ls = _lineSegs[0];
        _lineSegs.RemoveAt(0);
        // Create an equivalent, red, database line
        Line ln = new Line(ls.StartPoint, ls.EndPoint);
        ln.ColorIndex = (wasCalibrating ? 2 : 1);
        _lines.Add(ln);
        // Draw it as transient graphics
        ctm.AddTransient(
          ln, AcGi.TransientDrawingMode.DirectShortTerm,
          128, ints
        _calibrating = false;
      if (_drawing)
        if (_cursor == null)
            // Clear our skeleton
            ClearTransients();
            _curPt = _vertices[_vertices.Count - 1];
            Solid3d sol = new Solid3d();
            sol.CreateSphere(40.0);
            _cursor = sol;
            _cursor.TransformBy(
              Matrix3d.Displacement(_curPt - Point3d.Origin)
            //_cursor = new DBPoint(_curPt);
            //_cursor.Layer = "0";
            _cursor.ColorIndex = 2;
            ctm.AddTransient(
              _cursor, AcGi.TransientDrawingMode.DirectShortTerm,
              128, ints
        else
            Point3d newPt = _vertices[_vertices.Count - 1];
              Matrix3d.Displacement(newPt - _curPt)
            _curPt = newPt;
            ctm.UpdateTransient(_cursor, ints);
      else // !_drawing
        if (_cursor != null)
          ctm.EraseTransient(_cursor, ints);
          _cursor.Dispose();
          _cursor = null;
      return true;
    public void AddPolylines()
      ClearTransients();
      // Dispose of the database objects
      foreach (DBObject obj in _lines)
        obj.Dispose();
      _lines.Clear();
      // Create a true database-resident 3D polyline
      // (and let it be green)
      if (_vertices.Count > 1)
        BlockTableRecord btr =
          (BlockTableRecord)_tr.GetObject(
            _doc.Database.CurrentSpaceId,
            OpenMode.ForWrite
        Polyline3d pl =
          new Polyline3d(
            Poly3dType.SimplePoly, _vertices, false
        pl.ColorIndex = 3;
        btr.AppendEntity(pl);
        _tr.AddNewlyCreatedDBObject(pl, true);
      _vertices.Clear();
    public void ClearTransients()
      // Erase the various transient graphics
      ctm.EraseTransients(
        AcGi.TransientDrawingMode.DirectShortTerm, 128,
    public void ExportPointCloud(string filename)
      if (_vecs.Count > 0)
        using (StreamWriter sw = new StreamWriter(filename))
          // For each pixel, write a line to the text file:
          // X, Y, Z, R, G, B
          foreach (ColorVector3 pt in _vecs)
            sw.WriteLine(
              "{0}, {1}, {2}, {3}, {4}, {5}",
              pt.X, pt.Y, pt.Z, pt.R, pt.G, pt.B
  public class Commands
    [CommandMethod("ADNPLUGINS", "KINECT", CommandFlags.Modal)]
    public void ImportFromKinect()
      Document doc =
        Autodesk.AutoCAD.ApplicationServices.
          Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Transaction tr =
        doc.TransactionManager.StartTransaction();
      KinectJig kj = new KinectJig(doc, tr);
      kj.StartSensor();
      PromptResult pr = ed.Drag(kj);
      kj.StopSensor();
      if (pr.Status != PromptStatus.OK && !kj.Finished)
        kj.ClearTransients();
        tr.Dispose();
        return;
      kj.AddPolylines();
      tr.Commit();
      // Manually dispose to avoid scoping issues with
      // other variables
      tr.Dispose();
      // We'll store most local files in the temp folder.
      // We get a temp filename, delete the file and
      // use the name for our folder
      string localPath = Path.GetTempFileName();
      File.Delete(localPath);
      Directory.CreateDirectory(localPath);
      localPath += "\\";
      // Paths for our temporary files
      string txtPath = localPath + "points.txt";
      string lasPath = localPath + "points.las";
      // Our PCG file will be stored under My Documents
      string outputPath =
        Environment.GetFolderPath(
          Environment.SpecialFolder.MyDocuments
        ) + "\\Kinect Point Clouds\\";
      if (!Directory.Exists(outputPath))
        Directory.CreateDirectory(outputPath);
      // We'll use the title as a base filename for the PCG,
      // but will use an incremented integer to get an unused
      // filename
      int cnt = 0;
      string pcgPath;
      do
        pcgPath =
          outputPath + "Kinect" +
          (cnt == 0 ? "" : cnt.ToString()) + ".pcg";
        cnt++;
      while (File.Exists(pcgPath));
      // The path to the txt2las tool will be the same as the
      // executing assembly (our DLL)
      string exePath =
        Path.GetDirectoryName(
          Assembly.GetExecutingAssembly().Location
      if (!File.Exists(exePath + "txt2las.exe"))
        ed.WriteMessage(
          "\nCould not find the txt2las tool: please make sure " +
          "it is in the same folder as the application DLL."
        return;
      // Export our point cloud from the jig
      ed.WriteMessage(
        "\nSaving TXT file of the captured points.\n"
      kj.ExportPointCloud(txtPath);
      // Use the txt2las utility to create a .LAS
      // file from our text file
      ed.WriteMessage(
        "\nCreating a LAS from the TXT file.\n"
      ProcessStartInfo psi =
        new ProcessStartInfo(
          exePath + "txt2las",
          "-i \"" + txtPath +
          "\" -o \"" + lasPath +
          "\" -parse xyzRGB"
      psi.CreateNoWindow = false;
      psi.WindowStyle = ProcessWindowStyle.Hidden;
      // Wait up to 20 seconds for the process to exit
      try
        using (Process p = Process.Start(psi))
          p.WaitForExit();
      catch
      // If there's a problem, we return
      if (!File.Exists(lasPath))
        ed.WriteMessage(
          "\nError creating LAS file."
        return;
      File.Delete(txtPath);
      ed.WriteMessage(
        "Indexing the LAS and attaching the PCG.\n"
      // Index the .LAS file, creating a .PCG
      string lasLisp = lasPath.Replace('\\', '/'),
              pcgLisp = pcgPath.Replace('\\', '/');
        "(command \"_.POINTCLOUDINDEX\" \"" +
          lasLisp + "\" \"" +
          pcgLisp + "\")(princ) ",
        false, false, false
      // Attach the .PCG file
        "_.WAITFORFILE \"" +
        pcgLisp + "\" \"" +
        lasLisp + "\" " +
        "(command \"_.-POINTCLOUDATTACH\" \"" +
        pcgLisp +
        "\" \"0,0\" \"1\" \"0\")(princ) ",
        false, false, false
        "_.-VISUALSTYLES _C _Conceptual ",
        false, false, false
      //Cleanup();
    // Return whether a file is accessible
    private bool IsFileAccessible(string filename)
      // If the file can be opened for exclusive access it means
      // the file is accesible
      try
        FileStream fs =
          File.Open(
            filename, FileMode.Open,
            FileAccess.Read, FileShare.None
        using (fs)
          return true;
      catch (IOException)
        return false;
    // A command which waits for a particular PCG file to exist
    [CommandMethod(
      "ADNPLUGINS", "WAITFORFILE", CommandFlags.NoHistory
    public void WaitForFileToExist()
      Document doc =
      HostApplicationServices ha =
        HostApplicationServices.Current;
      PromptResult pr = ed.GetString("Enter path to PCG: ");
      if (pr.Status != PromptStatus.OK)
        return;
      string pcgPath = pr.StringResult.Replace('/', '\\');
      pr = ed.GetString("Enter path to LAS: ");
        return;
      string lasPath = pr.StringResult.Replace('/', '\\');
      ed.WriteMessage(
        "\nWaiting for PCG creation to complete...\n"
      // Check the write time for the PCG file...
      // if it hasn't been written to for at least half a second,
      // then we try to use a file lock to see whether the file
      // is accessible or not
      const int ticks = 50;
      TimeSpan diff;
      bool cancelled = false;
      // First loop is to see when writing has stopped
      // (better than always throwing exceptions)
      while (true)
        if (File.Exists(pcgPath))
          DateTime dt = File.GetLastWriteTime(pcgPath);
          diff = DateTime.Now - dt;
          if (diff.Ticks > ticks)
            break;
        System.Windows.Forms.Application.DoEvents();
      // Second loop will wait until file is finally accessible
      // (by calling a function that requests an exclusive lock)
      if (!cancelled)
        int inacc = 0;
        while (true)
          if (IsFileAccessible(pcgPath))
            break;
          else
            inacc++;
        ed.WriteMessage("\nFile inaccessible {0} times.", inacc);
        try
          CleanupTmpFiles(lasPath);
        catch
    internal void CleanupTmpFiles(string txtPath)
      if (File.Exists(txtPath))
      Directory.Delete(
        Path.GetDirectoryName(txtPath)
I’m yet to look seriously at the navigation side of things, but it might be fun to create some additional 3D geometry types, first.
GMT+8, 2025-5-24 01:01 , Processed in 0.192882 second(s), 29 queries , Gzip On.
