查看: 1498|回复: 9
按层选中可多选
发表于 2011-5-10 10:51:12 | 显示全部楼层 |阅读模式
这个例子可以选中某个层内的物体,请问怎样改造为可以多选几个层        (setvar "cmdecho" 0)
(Defun C:cxx (/ CNAME ENT SS)
  (and
    (setq ss (entsel "\n请选择需要选择的层中的一个物体: "))
    (setq ent (entget (car ss)))
    (setq cname (cdr (assoc 8 ent)))
    (princ (strcat "\n选中了图层: \"" cname "\""))
    (princ "\n框选范围....")
    (setq ss (ssget (list (cons 8 cname))))
    (sssetfirst NIL SS)
发表于 2011-5-10 12:09:53 | 显示全部楼层
回复 adc 的帖子
  1. (Defun C:cxx (/ CNAME ENT SS lay n)
  2.     (setq ss (ssget))
  3.     (repeat (setq n (sslength ss))
  4.       (setq ent (ssname ss (setq n (1- n))))
  5.       (setq la (cdr (assoc 8 (entget ent))))
  6.       (if (not (member la lay)) (setq lay (cons la lay)))
  7.       )
  8.     (setq cname (apply 'strcat (apply 'mapcar (cons 'strcat (list lay (mapcar '(lambda (x) ",") lay))))))
  9.     (princ (strcat "\n选中了图层: \"" cname "\""))
  10.     ;;
  11.     (princ "\n框选范围....")
  12.     (sssetfirst nil (ssget "x" (list (cons 8 cname))))
  13. )
 楼主| 发表于 2011-5-10 13:05:05 | 显示全部楼层
谢谢版主!
发表于 2011-6-29 22:16:43 | 显示全部楼层
谢谢Gu_xl版主!
发表于 2011-6-29 22:38:14 | 显示全部楼层
    (setq ss1 (ssget))
  (setq        i   -1
        lst '()
  (while (setq s1 (ssname ss1 (setq i (1+ i))))
      (setq ent (entget s1))
      (setq lst (append lst (list (cdr (assoc 8 ent)))))
    (setq
      layer_fili
       (apply 'strcat
              (mapcar '(lambda (x) (strcat x ",")) lst)
    (setq layer_fili (vl-string-right-trim "," layer_fili))
    (setq filiter (list (cons 8 layer_fili)))
    (setq ss2 (ssget filiter))
发表于 2011-6-30 17:39:14 | 显示全部楼层
感谢Gu_xl 版主及skynoon楼主分享经验 < 谢谢 ! >
发表于 2012-5-25 14:48:36 | 显示全部楼层
Gu版的好程序,学习了~
发表于 2013-1-24 10:15:02 | 显示全部楼层
Gu_xl 发表于 2011-5-10 12:09
回复 adc 的帖子
版主,这个好像不能选择范围啊,整张图的同层选都选择了。
发表于 2013-1-24 10:23:02 | 显示全部楼层
回复 adc 的帖子
发表于 2013-1-24 10:51:23 | 显示全部楼层
(sssetfirst nil (ssget (list (cons 8 cname))))
去掉那“x”就行
GMT+8, 2025-6-1 23:17 , Processed in 0.188191 second(s), 26 queries , Gzip On.
