查看: 645|回复: 0
New self-paced AutoCAD .NET training material
发表于 2011-5-10 13:31:15 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/05/new-self-paced-autocad-net-training-material.html
Wayne Brill, a member of the DevTech Americas team, has been beavering away on a new set of training material for AutoCAD .NET. This material is now live on the AutoCAD Developer Center (the image on the right should help you locate the link).
This new material contains information on the following topics:
  • Overview of .NET
  • Plugin Basics
  • User Interaction
  • Database fundamentals
  • Dictionaries
  • User Interface
  • Events
  • InputPoint Monitor
  • Jigs
To accompany this material, Wayne has also recorded a set of DevTV sessions, which I’ll be serialising over the coming weeks.
Here are links to the introduction and the first, getting started session:
AutoCAD .NET DevTV - Introduction
AutoCAD .NET DevTV - Session 1
GMT+8, 2025-11-25 11:36 , Processed in 0.240872 second(s), 32 queries , Gzip On.
