查看: 752|回复: 0
Capturing and combining multiple Kinect point clouds inside AutoCAD
发表于 2011-5-10 13:33:22 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/05/capturing-and-combining-multiple-kinect-point-clouds-inside-autocad.html
Over the weekend, I had more fun exploring the use of Kinect with AutoCAD. It was prompted by an email I had from a UK-based creative team who are interested in the potential of capturing  time-lapse point clouds using Kinect. They were curious whether the quality of data coming from the Kinect device would be adequate for doing some interesting  trompe l’oeil video compositions.
I started by taking the code from last week’s Kinect post: I removed the code related to gesture detection and beefed up the point-cloud related implementation to deal with composite point clouds that are built up over time.
Some notable changes:
  • Given the potential number of points generated by a sequence of captures, it made sense to limit the volume to within a specific bounding box
    • The KINBOUNDS command sets a clipping volume from the 3D extents of a selected object
    • We use LINQ (similar to the technique shown in this previous post) to filter the points
  • Our jig, used by the KINSNAPS command, now has a timer to measure the appropriate delay between snapshots
    • It shows the snapshot history in ascending colour indeces, to make them stand out from each other
    • As we now have fewer points to display we can display more of them
      • We’re now showing 50% – rather than 10% – of the points inside our bounding box
  • The points from the various capture get combined into a single LAS/PCG file
    • A design decision – they could easily have been kept separate
Here’s how it turned out:
http://www.youtube.com/embed/FW59E6puwnQ
Here’s the C# source code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using System.Runtime.InteropServices;
using System.Collections.Generic;
using System.Diagnostics;
using System.Reflection;
using System.Timers;
using System.Linq;
using System.IO;
using System;
using NKinect;
namespace KinectIntegration
  public class KinectDelayJig : DrawJig
    [DllImport("acad.exe", CharSet = CharSet.Auto,
      CallingConvention = CallingConvention.Cdecl,
      EntryPoint = "?acedPostCommand@@YAHPB_W@Z"
    extern static private int acedPostCommand(string cmd);
    // A transaction and database to add polylines
    private Transaction _tr;
    private Document _doc;
    // We need our nKinect sensor
    private Sensor _kinect = null;
    // A list of points captured by the sensor
    // (for eventual export)
    private List<ColorVector3> _vecs;
    // Uber list of points for final export/import
    private List<ColorVector3> _totalVecs;
    // A list of points to be displayed
    // (we use this for the jig)
    private Point3dCollection _points;
    // Transient points that have already been snapped
    private List<Point3dCollection> _snapped;
    // An offset value we use to move the mouse back
    // and forth by one screen unit
    private int _offset;
    // The number of snapshots to be taken
    private int _numShots;
    // Extents to filter points
    Extents3d? _ext;
    // Is it time to take a snapshot of the sensor data?
    private bool _snapshot;
    // Timer to tell us when to take a snapshot
    private Timer _timer;
    // Ready to exit the jig?
    private bool _finished;
    public bool Finished
      get { return _finished; }
    public KinectDelayJig(
      Document doc, Transaction tr,
      int numShots, double delay, Extents3d? ext
      // Initialise the various members
      _doc = doc;
      _tr = tr;
      _numShots = numShots;
      _ext = ext;
      _points = new Point3dCollection();
      _snapped = new List<Point3dCollection>();
      _totalVecs = new List<ColorVector3>();
      _offset = 1;
      _snapshot = false;
      _finished = false;
      _timer = new System.Timers.Timer(delay * 1000);
      // Hook up the Elapsed event for the timer
      _timer.Elapsed +=
        delegate(object source, ElapsedEventArgs args)
          // Flag that it's time to capture a snapshot
          _snapshot = true;
          // Turn off the timer to be re-enabled later
          ((Timer)source).Enabled = false;
      // Create our sensor object - the constructor takes
      // three callbacks to receive various data:
      // - skeleton movement
      // - rgb data
      // - depth data
      _kinect = new Sensor(s => {}, r => {}, d => {});
      _timer.Enabled = true;
    public void StartSensor()
      if (_kinect != null)
        _kinect.Start();
    public void StopSensor()
        _kinect.Stop();
        _kinect.Dispose();
        _kinect = null;
    protected override SamplerStatus Sampler(JigPrompts prompts)
      // Se don't really need a point, but we do need some
      // user input event to allow us to loop, processing
      // for the Kinect input
      PromptPointResult ppr =
        prompts.AcquirePoint("\nClick to capture: ");
      if (ppr.Status == PromptStatus.OK)
        if (_finished)
          acedPostCommand("CANCELCMD");
          return SamplerStatus.Cancel;
        // Generate a point cloud via nKinect
        try
          List<ColorVector3> vecList =
            _kinect.GeneratePointCloud();
          // Apply a bounding box filter, if one is defined
          if (_ext.HasValue)
            // Use LINQ to get the points within the
            // bounding box
            var vecSet =
              from ColorVector3 vec in vecList
              where
                vec.X > _ext.Value.MinPoint.X &&
                vec.X < _ext.Value.MaxPoint.X &&
                vec.Y > _ext.Value.MinPoint.Y &&
                vec.Y < _ext.Value.MaxPoint.Y &&
                vec.Z > _ext.Value.MinPoint.Z &&
                vec.Z < _ext.Value.MaxPoint.Z
              select vec;
            // Convert our IEnumerable<> into a List<>
            _vecs = vecSet.ToList<ColorVector3>();
          else
            _vecs = vecList;
          // Extract the points for display in the jig
          // (note we only take 1 in 2)
          _points.Clear();
          for (int i = 0; i < _vecs.Count; i += 2)
            ColorVector3 vec = _vecs[i];
            _points.Add(
              new Point3d(vec.X, vec.Y, vec.Z)
          // Let's move the mouse slightly to avoid having
          // to do it manually to keep the input coming
          System.Drawing.Point pt =
            System.Windows.Forms.Cursor.Position;
          System.Windows.Forms.Cursor.Position =
            new System.Drawing.Point(
              pt.X, pt.Y + _offset
          _offset = -_offset;
        catch {}
        return SamplerStatus.OK;
    protected override bool WorldDraw(AcGi.WorldDraw draw)
      if (_snapshot)
        if (_points.Count > 0)
          // Make a copy of the latest set of points
          Point3d[] tmp = new Point3d[_points.Count];
          _points.CopyTo(tmp, 0);
          // Add the copy to the list of snapshot previews
          _snapped.Add(new Point3dCollection(tmp));
          // Add the core list to the total set
          _totalVecs.AddRange(_vecs);
      short origColor = draw.SubEntityTraits.Color;
      for (int i = 0; i < _snapped.Count; i++)
        // Cycle through colour indeces for each snapshot
        draw.SubEntityTraits.Color = (short)(i + 1);
        // Draw the actual snapshot, one by one
        if (_snapped[i].Count > 0)
          draw.Geometry.Polypoint(_snapped[i], null, null);
      // Set the colour back to the original
      draw.SubEntityTraits.Color = origColor;
      if (_snapshot)
        // Reset the flag, timer and check whether finished
        _snapshot = false;
        _finished = (--_numShots == 0);
      else
        // This simply draws our points
          draw.Geometry.Polypoint(_points, null, null);
      return true;
    public void ExportPointCloud(string filename)
      if (_totalVecs.Count > 0)
        using (StreamWriter sw = new StreamWriter(filename))
          // For each pixel, write a line to the text file:
          // X, Y, Z, R, G, B
          foreach (ColorVector3 pt in _totalVecs)
            sw.WriteLine(
              "{0}, {1}, {2}, {3}, {4}, {5}",
              pt.X, pt.Y, pt.Z, pt.R, pt.G, pt.B
  public class Commands
    // Static members for command settings
    private static int _numShots = 5;
    private static double _delay = 5.0;
    private static Extents3d? _ext = null;
    [CommandMethod("ADNPLUGINS", "KINBOUNDS", CommandFlags.Modal)]
    public void SetBoundingBox()
      Document doc =
        Autodesk.AutoCAD.ApplicationServices.
          Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      // Ask the user to select an entity
      PromptEntityOptions peo =
        new PromptEntityOptions(
          "\nSelect entity to define bounding box"
      peo.AllowNone = true;
      peo.Keywords.Add("None");
      peo.Keywords.Default = "None";
      PromptEntityResult per = ed.GetEntity(peo);
      if (per.Status != PromptStatus.OK)
        return;
      // If "None" selected, clear the bounding box
      if (per.Status == PromptStatus.None ||
          per.StringResult == "None")
        _ext = null;
        ed.WriteMessage("\nBounding box cleared.");
        return;
      // Otherwise open the entity and gets its extents
      Transaction tr =
        doc.TransactionManager.StartTransaction();
      using (tr)
        Entity ent =
          tr.GetObject(per.ObjectId, OpenMode.ForRead)
            as Entity;
        if (ent != null)
          _ext = ent.Bounds;
        ed.WriteMessage(
          "\nBounding box set to {0}", _ext
        tr.Commit();
    [CommandMethod("ADNPLUGINS", "KINSNAPS", CommandFlags.Modal)]
    public void ImportFromKinect()
      Document doc =
      // Get some user input for the number of snapshots...
      PromptIntegerOptions pio =
        new PromptIntegerOptions("\nNumber of captures");
      pio.AllowZero = false;
      pio.DefaultValue = _numShots;
      pio.UseDefaultValue = true;
      pio.UpperLimit = 20;
      pio.LowerLimit = 1;
      PromptIntegerResult pir = ed.GetInteger(pio);
      if (pir.Status != PromptStatus.OK)
        return;
      _numShots = pir.Value;
      // ... and the delay between them
      PromptDoubleOptions pdo =
        new PromptDoubleOptions("\nNumber of seconds delay");
      pdo.AllowZero = false;
      pdo.AllowNegative = false;
      pdo.AllowArbitraryInput = false;
      pdo.DefaultValue = _delay;
      pdo.UseDefaultValue = true;
      PromptDoubleResult pdr = ed.GetDouble(pdo);
      if (pdr.Status != PromptStatus.OK)
        return;
      _delay = pdr.Value;
      Transaction tr =
      KinectDelayJig kj =
        new KinectDelayJig(doc, tr, _numShots, _delay, _ext);
      kj.StartSensor();
      PromptResult pr = ed.Drag(kj);
      kj.StopSensor();
      if (pr.Status != PromptStatus.OK && !kj.Finished)
        tr.Dispose();
        return;
      tr.Commit();
      // Manually dispose to avoid scoping issues with
      // other variables
      tr.Dispose();
      // We'll store most local files in the temp folder.
      // We get a temp filename, delete the file and
      // use the name for our folder
      string localPath = Path.GetTempFileName();
      File.Delete(localPath);
      Directory.CreateDirectory(localPath);
      localPath += "\\";
      // Paths for our temporary files
      string txtPath = localPath + "points.txt";
      string lasPath = localPath + "points.las";
      // Our PCG file will be stored under My Documents
      string outputPath =
        Environment.GetFolderPath(
          Environment.SpecialFolder.MyDocuments
        ) + "\\Kinect Point Clouds\\";
      if (!Directory.Exists(outputPath))
        Directory.CreateDirectory(outputPath);
      // We'll use the title as a base filename for the PCG,
      // but will use an incremented integer to get an unused
      // filename
      int cnt = 0;
      string pcgPath;
      do
        pcgPath =
          outputPath + "Kinect" +
          (cnt == 0 ? "" : cnt.ToString()) + ".pcg";
        cnt++;
      while (File.Exists(pcgPath));
      // The path to the txt2las tool will be the same as the
      // executing assembly (our DLL)
      string exePath =
        Path.GetDirectoryName(
          Assembly.GetExecutingAssembly().Location
      if (!File.Exists(exePath + "txt2las.exe"))
        ed.WriteMessage(
          "\nCould not find the txt2las tool: please make sure " +
          "it is in the same folder as the application DLL."
        return;
      // Export our point cloud from the jig
      ed.WriteMessage(
        "\nSaving TXT file of the captured points.\n"
      kj.ExportPointCloud(txtPath);
      // Use the txt2las utility to create a .LAS
      // file from our text file
      ed.WriteMessage(
        "\nCreating a LAS from the TXT file.\n"
      ProcessStartInfo psi =
        new ProcessStartInfo(
          exePath + "txt2las",
          "-i \"" + txtPath +
          "\" -o \"" + lasPath +
          "\" -parse xyzRGB"
      psi.CreateNoWindow = false;
      psi.WindowStyle = ProcessWindowStyle.Hidden;
      // Wait up to 20 seconds for the process to exit
      try
        using (Process p = Process.Start(psi))
          p.WaitForExit();
      catch
      // If there's a problem, we return
      if (!File.Exists(lasPath))
        ed.WriteMessage(
          "\nError creating LAS file."
        return;
      File.Delete(txtPath);
      ed.WriteMessage(
        "Indexing the LAS and attaching the PCG.\n"
      // Index the .LAS file, creating a .PCG
      string lasLisp = lasPath.Replace('\\', '/'),
              pcgLisp = pcgPath.Replace('\\', '/');
      doc.SendStringToExecute(
        "(command \"_.POINTCLOUDINDEX\" \"" +
          lasLisp + "\" \"" +
          pcgLisp + "\")(princ) ",
        false, false, false
      // Attach the .PCG file
        "_.WAITFORFILE \"" +
        pcgLisp + "\" \"" +
        lasLisp + "\" " +
        "(command \"_.-POINTCLOUDATTACH\" \"" +
        pcgLisp +
        "\" \"0,0\" \"1\" \"0\")(princ) ",
        false, false, false
        "_.-VISUALSTYLES _C _Conceptual ",
        false, false, false
      //Cleanup();
    // Return whether a file is accessible
    private bool IsFileAccessible(string filename)
      // If the file can be opened for exclusive access it means
      // the file is accesible
      try
        FileStream fs =
          File.Open(
            filename, FileMode.Open,
            FileAccess.Read, FileShare.None
        using (fs)
          return true;
      catch (IOException)
        return false;
    // A command which waits for a particular PCG file to exist
    [CommandMethod(
      "ADNPLUGINS", "WAITFORFILE", CommandFlags.NoHistory
    public void WaitForFileToExist()
      Document doc =
      HostApplicationServices ha =
        HostApplicationServices.Current;
      PromptResult pr = ed.GetString("Enter path to PCG: ");
      if (pr.Status != PromptStatus.OK)
        return;
      string pcgPath = pr.StringResult.Replace('/', '\\');
      pr = ed.GetString("Enter path to LAS: ");
        return;
      string lasPath = pr.StringResult.Replace('/', '\\');
      ed.WriteMessage(
        "\nWaiting for PCG creation to complete...\n"
      // Check the write time for the PCG file...
      // if it hasn't been written to for at least half a second,
      // then we try to use a file lock to see whether the file
      // is accessible or not
      const int ticks = 50;
      TimeSpan diff;
      bool cancelled = false;
      // First loop is to see when writing has stopped
      // (better than always throwing exceptions)
      while (true)
        if (File.Exists(pcgPath))
          DateTime dt = File.GetLastWriteTime(pcgPath);
          diff = DateTime.Now - dt;
          if (diff.Ticks > ticks)
            break;
        System.Windows.Forms.Application.DoEvents();
      // Second loop will wait until file is finally accessible
      // (by calling a function that requests an exclusive lock)
      if (!cancelled)
        int inacc = 0;
        while (true)
          if (IsFileAccessible(pcgPath))
            break;
          else
            inacc++;
        ed.WriteMessage("\nFile inaccessible {0} times.", inacc);
        try
          CleanupTmpFiles(lasPath);
        catch
    internal void CleanupTmpFiles(string txtPath)
      if (File.Exists(txtPath))
      Directory.Delete(
        Path.GetDirectoryName(txtPath)
I still feel I need to do more with navigation – which is hopefully the next area of focus – but we’ll see. It depends on whether something else comes in to distract me. :-)
GMT+8, 2025-11-25 11:36 , Processed in 0.217272 second(s), 32 queries , Gzip On.
