查看: 667|回复: 0
Sweeping an AutoCAD solid from Kinect-captured geometry
发表于 2011-5-19 18:07:10 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/05/sweeping-an-autocad-solid-from-kinect-captured-geometry.html
In this previous post we looked at some code to capture and combine a series of point clouds using a Kinect sensor.
In today’s post we’re going to take a very slightly modified version of the code – which really only adds the feature to let the user choose when the sequence of captures should start by clicking, rather than it just starting at the beginning of the command – to capture the geometry created by dragging a 2D cross-section in 3D space. The code in the last post clearly played a big part in helping digitise the profile and create the spline path for our sweep.
Here’s how it turned out:
http://www.youtube.com/embed/fB51I-Q0WOQ
Here’s the updated C# source code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using System.Runtime.InteropServices;
using System.Collections.Generic;
using System.Diagnostics;
using System.Reflection;
using System.Timers;
using System.Linq;
using System.IO;
using System;
using NKinect;
namespace KinectIntegration
  public class KinectDelayJig : DrawJig
    [DllImport("acad.exe", CharSet = CharSet.Auto,
      CallingConvention = CallingConvention.Cdecl,
      EntryPoint = "?acedPostCommand@@YAHPB_W@Z"
    extern static private int acedPostCommand(string cmd);
    // A transaction and database to add polylines
    private Transaction _tr;
    private Document _doc;
    // We need our nKinect sensor
    private Sensor _kinect = null;
    // A list of points captured by the sensor
    // (for eventual export)
    private List<ColorVector3> _vecs;
    // Uber list of points for final export/import
    private List<ColorVector3> _totalVecs;
    // A list of points to be displayed
    // (we use this for the jig)
    private Point3dCollection _points;
    // Transient points that have already been snapped
    private List<Point3dCollection> _snapped;
    // An offset value we use to move the mouse back
    // and forth by one screen unit
    private int _offset;
    // The number of snapshots to be taken
    private int _numShots;
    // Extents to filter points
    Extents3d? _ext;
    // Is it time to take a snapshot of the sensor data?
    private bool _snapshot;
    // Timer to tell us when to take a snapshot
    private Timer _timer;
    // Ready to exit the jig?
    private bool _finished;
    public bool Finished
      get { return _finished; }
    public KinectDelayJig(
      Document doc, Transaction tr,
      int numShots, double delay, Extents3d? ext
      // Initialise the various members
      _doc = doc;
      _tr = tr;
      _numShots = numShots;
      _ext = ext;
      _points = new Point3dCollection();
      _snapped = new List<Point3dCollection>();
      _totalVecs = new List<ColorVector3>();
      _offset = 1;
      _snapshot = false;
      _finished = false;
      _timer = new System.Timers.Timer(delay * 1000);
      _timer.Enabled = false;
      // Hook up the Elapsed event for the timer
      _timer.Elapsed +=
        delegate(object source, ElapsedEventArgs args)
          // Flag that it's time to capture a snapshot
          _snapshot = true;
          // Turn off the timer to be re-enabled later
          ((Timer)source).Enabled = false;
      // Create our sensor object - the constructor takes
      // three callbacks to receive various data:
      // - skeleton movement
      // - rgb data
      // - depth data
      _kinect = new Sensor(s => {}, r => {}, d => {});
    public void StartSensor()
      if (_kinect != null)
        _kinect.Start();
    public void StopSensor()
        _kinect.Stop();
        _kinect.Dispose();
        _kinect = null;
    public void StartTimer()
      if (_timer != null)
        _timer.Enabled = true;
    protected override SamplerStatus Sampler(JigPrompts prompts)
      // We don't really need a point, but we do need some
      // user input event to allow us to loop, processing
      // for the Kinect input
      PromptPointResult ppr =
        prompts.AcquirePoint("\nClick to capture: ");
      if (ppr.Status == PromptStatus.OK)
        if (_finished)
          acedPostCommand("CANCELCMD");
          return SamplerStatus.Cancel;
        // Generate a point cloud via nKinect
        try
          List<ColorVector3> vecList =
            _kinect.GeneratePointCloud();
          // Apply a bounding box filter, if one is defined
          if (_ext.HasValue)
            // Use LINQ to get the points within the
            // bounding box
            var vecSet =
              from ColorVector3 vec in vecList
              where
                vec.X > _ext.Value.MinPoint.X &&
                vec.X < _ext.Value.MaxPoint.X &&
                vec.Y > _ext.Value.MinPoint.Y &&
                vec.Y < _ext.Value.MaxPoint.Y &&
                vec.Z > _ext.Value.MinPoint.Z &&
                vec.Z < _ext.Value.MaxPoint.Z
              select vec;
            // Convert our IEnumerable<> into a List<>
            _vecs = vecSet.ToList<ColorVector3>();
          else
            _vecs = vecList;
          // Extract the points for display in the jig
          // (note we only take 1 in 2)
          _points.Clear();
          for (int i = 0; i < _vecs.Count; i += 2)
            ColorVector3 vec = _vecs[i];
            _points.Add(
              new Point3d(vec.X, vec.Y, vec.Z)
          // Let's move the mouse slightly to avoid having
          // to do it manually to keep the input coming
          System.Drawing.Point pt =
            System.Windows.Forms.Cursor.Position;
          System.Windows.Forms.Cursor.Position =
            new System.Drawing.Point(
              pt.X, pt.Y + _offset
          _offset = -_offset;
        catch {}
        return SamplerStatus.OK;
    protected override bool WorldDraw(AcGi.WorldDraw draw)
      if (_snapshot)
        if (_points.Count > 0)
          // Make a copy of the latest set of points
          Point3d[] tmp = new Point3d[_points.Count];
          _points.CopyTo(tmp, 0);
          // Add the copy to the list of snapshot previews
          _snapped.Add(new Point3dCollection(tmp));
          // Add the core list to the total set
          _totalVecs.AddRange(_vecs);
      short origColor = draw.SubEntityTraits.Color;
      for (int i = 0; i < _snapped.Count; i++)
        // Cycle through colour indeces for each snapshot
        draw.SubEntityTraits.Color = (short)(i + 1);
        // Draw the actual snapshot, one by one
        if (_snapped[i].Count > 0)
          draw.Geometry.Polypoint(_snapped[i], null, null);
      // Set the colour back to the original
      draw.SubEntityTraits.Color = origColor;
      if (_snapshot)
        // Reset the flag, timer and check whether finished
        _snapshot = false;
        _finished = (--_numShots == 0);
      else
        // This simply draws our points
          draw.Geometry.Polypoint(_points, null, null);
      return true;
    public void ExportPointCloud(string filename)
      if (_totalVecs.Count > 0)
        using (StreamWriter sw = new StreamWriter(filename))
          // For each pixel, write a line to the text file:
          // X, Y, Z, R, G, B
          foreach (ColorVector3 pt in _totalVecs)
            sw.WriteLine(
              "{0}, {1}, {2}, {3}, {4}, {5}",
              pt.X, pt.Y, pt.Z, pt.R, pt.G, pt.B
  public class Commands
    // Static members for command settings
    private static int _numShots = 5;
    private static double _delay = 5.0;
    private static Extents3d? _ext = null;
    private static Matrix3d? _trans = null;
    public static Extents3d? Extents
      get { return _ext; }
    public static Matrix3d? Transformation
      get { return _trans; }
    [CommandMethod("ADNPLUGINS", "KINBOUNDS", CommandFlags.Modal)]
    public void SetBoundingBox()
      Document doc =
        Autodesk.AutoCAD.ApplicationServices.
          Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      // Ask the user to select an entity
      PromptEntityOptions peo =
        new PromptEntityOptions(
          "\nSelect entity to define bounding box"
      peo.AllowNone = true;
      peo.Keywords.Add("None");
      peo.Keywords.Default = "None";
      PromptEntityResult per = ed.GetEntity(peo);
      if (per.Status != PromptStatus.OK)
        return;
      // If "None" selected, clear the bounding box
      if (per.Status == PromptStatus.None ||
          per.StringResult == "None")
        _ext = null;
        ed.WriteMessage("\nBounding box cleared.");
        return;
      // Otherwise open the entity and gets its extents
      Transaction tr =
        doc.TransactionManager.StartTransaction();
      using (tr)
        Entity ent =
          tr.GetObject(per.ObjectId, OpenMode.ForRead)
            as Entity;
        if (ent != null)
          _ext = ent.Bounds;
        ed.WriteMessage(
          "\nBounding box set to {0}", _ext
        tr.Commit();
    [CommandMethod("ADNPLUGINS", "KINSNAPS", CommandFlags.Modal)]
    public void ImportFromKinect()
      Document doc =
      // Get some user input for the number of snapshots...
      PromptIntegerOptions pio =
        new PromptIntegerOptions("\nNumber of captures");
      pio.AllowZero = false;
      pio.DefaultValue = _numShots;
      pio.UseDefaultValue = true;
      pio.UpperLimit = 20;
      pio.LowerLimit = 1;
      PromptIntegerResult pir = ed.GetInteger(pio);
      if (pir.Status != PromptStatus.OK)
        return;
      _numShots = pir.Value;
      // ... and the delay between them
      PromptDoubleOptions pdo =
        new PromptDoubleOptions("\nNumber of seconds delay");
      pdo.AllowZero = false;
      pdo.AllowNegative = false;
      pdo.AllowArbitraryInput = false;
      pdo.DefaultValue = _delay;
      pdo.UseDefaultValue = true;
      PromptDoubleResult pdr = ed.GetDouble(pdo);
      if (pdr.Status != PromptStatus.OK)
        return;
      _delay = pdr.Value;
      Transaction tr =
      KinectDelayJig kj =
        new KinectDelayJig(doc, tr, _numShots, _delay, _ext);
      kj.StartSensor();
      PromptResult pr = ed.Drag(kj);
      if (pr.Status == PromptStatus.OK)
        kj.StartTimer();
        pr = ed.Drag(kj);
      kj.StopSensor();
      if (pr.Status != PromptStatus.OK && !kj.Finished)
        tr.Dispose();
        return;
      tr.Commit();
      // Manually dispose to avoid scoping issues with
      // other variables
      tr.Dispose();
      // We'll store most local files in the temp folder.
      // We get a temp filename, delete the file and
      // use the name for our folder
      string localPath = Path.GetTempFileName();
      File.Delete(localPath);
      Directory.CreateDirectory(localPath);
      localPath += "\\";
      // Paths for our temporary files
      string txtPath = localPath + "points.txt";
      string lasPath = localPath + "points.las";
      // Our PCG file will be stored under My Documents
      string outputPath =
        Environment.GetFolderPath(
          Environment.SpecialFolder.MyDocuments
        ) + "\\Kinect Point Clouds\\";
      if (!Directory.Exists(outputPath))
        Directory.CreateDirectory(outputPath);
      // We'll use the title as a base filename for the PCG,
      // but will use an incremented integer to get an unused
      // filename
      int cnt = 0;
      string pcgPath;
      do
        pcgPath =
          outputPath + "Kinect" +
          (cnt == 0 ? "" : cnt.ToString()) + ".pcg";
        cnt++;
      while (File.Exists(pcgPath));
      // The path to the txt2las tool will be the same as the
      // executing assembly (our DLL)
      string exePath =
        Path.GetDirectoryName(
          Assembly.GetExecutingAssembly().Location
      if (!File.Exists(exePath + "txt2las.exe"))
        ed.WriteMessage(
          "\nCould not find the txt2las tool: please make sure " +
          "it is in the same folder as the application DLL."
        return;
      // Export our point cloud from the jig
      ed.WriteMessage(
        "\nSaving TXT file of the captured points.\n"
      kj.ExportPointCloud(txtPath);
      // Use the txt2las utility to create a .LAS
      // file from our text file
      ed.WriteMessage(
        "\nCreating a LAS from the TXT file.\n"
      ProcessStartInfo psi =
        new ProcessStartInfo(
          exePath + "txt2las",
          "-i \"" + txtPath +
          "\" -o \"" + lasPath +
          "\" -parse xyzRGB"
      psi.CreateNoWindow = false;
      psi.WindowStyle = ProcessWindowStyle.Hidden;
      // Wait up to 20 seconds for the process to exit
      try
        using (Process p = Process.Start(psi))
          p.WaitForExit();
      catch
      // If there's a problem, we return
      if (!File.Exists(lasPath))
        ed.WriteMessage(
          "\nError creating LAS file."
        return;
      File.Delete(txtPath);
      ed.WriteMessage(
        "Indexing the LAS and attaching the PCG.\n"
      // Index the .LAS file, creating a .PCG
      string lasLisp = lasPath.Replace('\\', '/'),
              pcgLisp = pcgPath.Replace('\\', '/');
      doc.SendStringToExecute(
        "(command \"_.POINTCLOUDINDEX\" \"" +
          lasLisp + "\" \"" +
          pcgLisp + "\")(princ) ",
        false, false, false
      // Attach the .PCG file
        "_.WAITFORFILE \"" +
        pcgLisp + "\" \"" +
        lasLisp + "\" " +
        "(command \"_.-POINTCLOUDATTACH\" \"" +
        pcgLisp +
        "\" \"0,0\" \"1\" \"0\")(princ) ",
        false, false, false
        "_.-VISUALSTYLES _C _Conceptual ",
        false, false, false
      //Cleanup();
    // Return whether a file is accessible
    private bool IsFileAccessible(string filename)
      // If the file can be opened for exclusive access it means
      // the file is accesible
      try
        FileStream fs =
          File.Open(
            filename, FileMode.Open,
            FileAccess.Read, FileShare.None
        using (fs)
          return true;
      catch (IOException)
        return false;
    // A command which waits for a particular PCG file to exist
    [CommandMethod(
      "ADNPLUGINS", "WAITFORFILE", CommandFlags.NoHistory
    public void WaitForFileToExist()
      Document doc =
      HostApplicationServices ha =
        HostApplicationServices.Current;
      PromptResult pr = ed.GetString("Enter path to PCG: ");
      if (pr.Status != PromptStatus.OK)
        return;
      string pcgPath = pr.StringResult.Replace('/', '\\');
      pr = ed.GetString("Enter path to LAS: ");
        return;
      string lasPath = pr.StringResult.Replace('/', '\\');
      ed.WriteMessage(
        "\nWaiting for PCG creation to complete...\n"
      // Check the write time for the PCG file...
      // if it hasn't been written to for at least half a second,
      // then we try to use a file lock to see whether the file
      // is accessible or not
      const int ticks = 50;
      TimeSpan diff;
      bool cancelled = false;
      // First loop is to see when writing has stopped
      // (better than always throwing exceptions)
      while (true)
        if (File.Exists(pcgPath))
          DateTime dt = File.GetLastWriteTime(pcgPath);
          diff = DateTime.Now - dt;
          if (diff.Ticks > ticks)
            break;
        System.Windows.Forms.Application.DoEvents();
      // Second loop will wait until file is finally accessible
      // (by calling a function that requests an exclusive lock)
      if (!cancelled)
        int inacc = 0;
        while (true)
          if (IsFileAccessible(pcgPath))
            break;
          else
            inacc++;
        ed.WriteMessage("\nFile inaccessible {0} times.", inacc);
        try
          CleanupTmpFiles(lasPath);
        catch
    internal void CleanupTmpFiles(string txtPath)
      if (File.Exists(txtPath))
      Directory.Delete(
        Path.GetDirectoryName(txtPath)
I’ve been making some good progress on a few other samples: one which performs the spline capture and sweep automatically (in the same way as we drew 3D polylines, before) and another that actually does some navigation with the Kinect (which I’ve been talking about for some time). More on those, soon.
GMT+8, 2025-11-25 11:34 , Processed in 0.226289 second(s), 31 queries , Gzip On.
