查看: 850|回复: 0
交互式操作代码出错
发表于 2011-5-31 00:12:48 | 显示全部楼层 |阅读模式
Sub yy()
    Dim pt As Variant
    Dim xyz(2) As Double
    pt = ThisDrawing.Utility.GetPoint(xyz, "请在屏幕上指定一个点")
    Dim ptname As String
    ptname = ThisDrawing.Utility.GetString(1, "请输入点号")
    Dim keys As String
    keys = "Y N"
    ThisDrawing.Utility.InitializeUserInput 1, keys
    Dim mykey As String
    mykey = ThisDrawing.Utility.GetKeyword("是否要显示点号?是(Y)否(N)")
    If UCase(mykey) = "Y" Then
        ThisDrawing.ModelSpace.AddText ptname, pt, 0
    End If
End Sub
交互式操作代码出错 请问如何修改
GMT+8, 2025-5-25 22:41 , Processed in 0.159817 second(s), 24 queries , Gzip On.
