查看: 3126|回复: 3
怎样用getxdata 读取扩展数据
发表于 2011-5-31 12:11:21 | 显示全部楼层 |阅读模式
           从明经上下了个函数,用来读取扩展数据的,AX:getxdata
但是老是会中断退出,恳请版主帮修正下,谢
;以下来自明经
   (defun ax:GetXData (vlaObj AppID / xType XData)
  (vla-getxdata vlaObj AppID 'xType xData)
  (mapcar '(lambda (key val) (cons key (lisp-value val)))
          (vlax-safearray->list xType)
          (vlax-safearray->list xData)
(defun lisp-value (v)
   (cond
     ((= (type v) 'variant)
       (lisp-value (variant-value v)))
     ((= (type v) 'safearray)
       (mapcar 'lisp-value (safearray-value v)))
     (T v)
;--------------为何以下老是中断
(defun c:ReadComponentxdata ()
   (vl-load-com)
    (setq acadobject (vlax-get-acad-object)
          acaddoc (vla-get-activedocument acadobject)
          mspace (vla-get-ModelSpace acaddoc))
    (graphscr)
  (SETQ en (car  (entsel "Select object: ")))
  (setq vlaobj (vlax-ename->vla-object en))
  (ax:GetXData VlaObj "*")
  );end defun
发表于 2011-6-1 21:47:51 | 显示全部楼层
     (vla-getxdata vlaObj AppID 'xType 'xData)
xData改成 'xData试一下
 楼主| 发表于 2011-6-2 12:32:48 | 显示全部楼层
      谢楼上,试验成功
发表于 2013-12-29 15:41:08 | 显示全部楼层
按2楼的改了以后,运行时出错
错误: 参数类型错误: safearrayp nil
是什么情况?
GMT+8, 2025-5-26 02:57 , Processed in 0.188981 second(s), 25 queries , Gzip On.
