查看: 1390|回复: 2
如何用C# 实现CAD添加菜单?
发表于 2011-6-3 16:48:31 | 显示全部楼层 |阅读模式
大侠们,如何用C# 实现CAD添加菜单?菜单下包含二级菜单呢??
 楼主| 发表于 2011-6-3 16:59:23 | 显示全部楼层
Autodesk.AutoCAD.Interop.AcadPopupMenu popMenu;
[CommandMethod("myMenu")]
  public static void mymenu()
   Autodesk.AutoCAD.Interop.AcadApplication acadApp=Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication as Autodesk.AutoCAD.Interop.AcadApplication;
            try
                popMenu = acadApp.MenuGroups.Item(0).Menus.Add("我的菜单");
                Autodesk.AutoCAD.Interop.AcadPopupMenuItem popItem0 = popMenu.AddMenuItem(0, "设置地形图目录", "_setmappath ");
                Autodesk.AutoCAD.Interop.AcadPopupMenuItem popItem1 = popMenu.AddMenuItem(1, "查询图号", "_shoumapname ");
                Autodesk.AutoCAD.Interop.AcadPopupMenuItem popItem2 = popMenu.AddMenuItem(2, "插入地形图", "_insertMap ");
                //Autodesk.AutoCAD.Interop.AcadPopupMenuItem popItem3 = popMenu.AddMenuItem(3, "查询图号", "_sssss ");
          popMenu.InsertInMenuBar(11);
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                MessageBox.Show(ex.Message.ToString());
 楼主| 发表于 2011-6-3 16:59:55 | 显示全部楼层
如何添加二级菜单呢??
GMT+8, 2025-5-25 23:07 , Processed in 0.149388 second(s), 23 queries , Gzip On.
