查看: 803|回复: 0
ADN DevCast Episode 7 – Creating an installer to deploy apps via the Autoloader
发表于 2011-6-23 14:14:40 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/06/adn-devcast-episode-7-creating-an-installer-to-deploy-apps-via-the-autoloader.html
As a follow-up to their session on the Autoloader, AutoCAD 2012’s simplified deployment mechanism, Stephen and Fenton have recorded another DevCast focused on creating an installer to deploy apps via the Autoloader.
These two DevCasts are likely to be of relevance to anyone wishing to deploy their plugin via the “Apps” tab in Autodesk Exchange. There’s also a new Developer Center focused on this very task, providing the guidelines and requirements for publishing apps along with a couple of helpful DevTV sessions to get you started.
GMT+8, 2026-1-24 11:42 , Processed in 0.247010 second(s), 31 queries , Gzip On.
