查看: 1575|回复: 1
[讨论] 删除爆破后的尺寸
发表于 2011-6-28 15:32:42 | 显示全部楼层 |阅读模式
;;;想删除爆破后的尺寸,但一直找不到好的方法,搞一个试试,求助各位有没有好的办法
;;;通只针对实心箭头这一个情况
(defun C:Te (/ E1 E1LIST N P10 P1011 P11 P12 P1P2 SS SS12 SSS X Y)
  ;;求两点之中点
  (defun MJ:MIDPOINT (P1 P2 / X Y)
    (mapcar '(lambda (X Y) (/ (+ X Y) 2.0)) P1 P2)
  ;;求得一点周围两点
  (defun grbox1        (pt / H P1 P2)
    ;;copy from eachy
    (setq h  (*        (/ (getvar "viewsize") (cadr (getvar "screensize")))
                (getvar "pickbox")
          p1 (mapcar '- pt (list h h 0.))
          p2 (mapcar '+ pt (list h h 0.))
    (list p1 p2)
  (command "undo" "be")
  (command "zoom" "e")
  ;;实心箭头选择集sss
  (setq ss (ssget "X" '((0 . "SOLID"))))
  (setq n 0)
  (setq sss (ssadd))
  (repeat (sslength ss)
    (setq e1 (ssname ss n))
    (setq e1list (entget e1))
    (if        (equal (Li_item 12 e1list) (Li_item 13 e1list))
       (ssadd e1 sss)
    (setq n (1+ n))
  (setq n 0)
  (while (/= (sslength sss) 0)
    (setq e1 (ssname sss n))
    (setq p10 (Li_item 10 e1list))
    (setq p11 (Li_item 11 e1list))
    (setq p1011 (MJ:MIDPOINT p10 p11))
    (setq p12 (Li_item 12 e1list))
    ;;ss12箭头尖角处直线e12选择集
    (setq p1p2 (grbox1 p12))
    (setq ss12 (ssget "C" (car p1p2) (cadr p1p2) '((0 . "LINE"))))
    (command "erase" ss12 "")
    ;;ss12箭头后部中点处直线ss1011选择集
    (setq p1p2 (grbox1 p1011))
    (setq n (1+ n))
  (command "erase" sss "")
  (command "undo" "e")
;;;删除爆破后的尺寸
(Defun LI_item (N E) (CDR (Assoc N E)))
发表于 2011-6-28 16:51:49 | 显示全部楼层
研究下实体生成顺序,试试entnext,不过总之不安全。
GMT+8, 2025-6-12 05:26 , Processed in 0.162389 second(s), 27 queries , Gzip On.
