推荐个PLINE线逆序函数gile写的
- (defun gile-reverse-pl (ent / e_lst vtx v_lst p_lst l_vtx)
- (setq e_lst (entget ent))
- (cond
- ((= (cdr (assoc 0 e_lst)) "POLYLINE")
- (setq vtx (entnext ent))
- (while (= (cdr (assoc 0 (entget vtx))) "VERTEX")
- (setq v_lst (cons (entget vtx) v_lst)
- vtx (entnext vtx)
- ((= (cdr (assoc 0 e_lst)) "LWPOLYLINE")
- (setq p_lst (vl-remove-if-not
- '(lambda (x)
- (member (car x) '(10 40 41 42))
- e_lst
- e_lst (vl-remove-if
- '(lambda (x)
- (member x p_lst)
- e_lst
- (while p_lst
- (setq v_lst (cons
- (list (car p_lst) (cadr p_lst) (caddr p_lst) (cadddr p_lst))
- v_lst
- p_lst (member (assoc 10 (cdr p_lst)) (cdr p_lst))
- (setq l_vtx (last v_lst)
- l_vtx (subst (cons 40 (cdr (assoc 41 (car v_lst))))
- (assoc 40 l_vtx)
- l_vtx
- l_vtx (subst (cons 41 (cdr (assoc 40 (car v_lst))))
- (assoc 41 l_vtx)
- l_vtx
- l_vtx (subst (cons 42 (- (cdr (assoc 42 (car v_lst)))))
- (assoc 42 l_vtx)
- l_vtx
- (setq v_lst
- (mapcar
- '(lambda (x y)
- (setq x (subst (cons 40 (cdr (assoc 41 y))) (assoc 40 x) x)
- x (subst (cons 41 (cdr (assoc 40 y))) (assoc 41 x) x)
- x (subst (cons 42 (- (cdr (assoc 42 y)))) (assoc 42 x) x)
- v_lst
- (cdr v_lst)
- (if (= (logand 1 (cdr (assoc 70 e_lst))) 1)
- (setq v_lst (append (list l_vtx) v_lst))
- (setq v_lst (append v_lst (list l_vtx)))
- (cond
- (mapcar 'entmake
- (append (list e_lst) v_lst (list (entget vtx)))
- (entdel ent)
- (setq e_lst (append e_lst (apply 'append v_lst)))
- (entmod e_lst)
我自己用的是箭头可以倒向的
- (defun ss-reverse-pl (en / ent pl_vetex b is fst est lst n)
- (setq ent (entget en '("*")))
- (setq pl_vetex nil
- b nil
- is T
- fst nil
- est nil
- (foreach n ent ;_(setq e (assoc 10 ent))
- (if (= (car n) 210)
- (setq is nil)
- (cond ((and (or (= 10 (car n))
- (= 40 (car n))
- (= 41 (car n))
- (= 42 (car n))
- is
- (setq b (cons (cdr n) b))
- (if (= 4 (length b))
- (setq pl_vetex (append pl_vetex (list b))
- b
- nil
- (is
- (setq fst (cons n fst))
- (T (setq est (cons n est)))
- (setq lst nil)
- (foreach a pl_vetex
- (setq lst (append (list (cons 10 (cadddr a))
- (cons 40 (caddr a))
- (cons 41 (cadr a))
- (cons 42 ( -(car a)))
- lst
- (setq lst (append (reverse fst)
- lst
- (reverse est)
- (setq ent lst)
- (entmod ent)
