查看: 1242|回复: 3
[基础] 本人刚学LISP,做的小程序
发表于 2011-7-7 23:58:41 | 显示全部楼层 |阅读模式
求两圆公切线的小程序,请大家看看!我想请问一个问题,怎么把在最后把LISP编出的图型变成块啊,我用(command "block" neiqie "w" a "")怎么不行啊!block命令要怎样用呢!
发表于 2011-7-8 00:10:12 | 显示全部楼层
还是定义成命令使用较方便
即将(defun neipie ()......)改成(defun c:neiqie ()......)
发表于 2011-7-8 09:27:42 | 显示全部楼层
发表于 2011-7-8 09:33:24 | 显示全部楼层
  1. ;;子程序,将一个选择集中的物体原地制成匿名块。
  2. ;;参数:ss:选择集。
  3. ;;例:(makeblock (ssget))
  4. (defun makeblock (ss / holdecho holdblip a blkref)
  5.   (setq holdecho (getvar "cmdecho"))
  6.   (setq holdblip (getvar "blipmode"))
  7.   (setvar "cmdecho" 0)
  8.   (setvar "blipmode" 0)
  9.   (setq a (rtos (* (getvar "CDATE") 1E8)))
  10.   (command "_.BLOCK" a "0,0" ss "")
  11.   (command "_.INSERT" a "@" "" "" "")
  12.   (setq blkref (vlax-ename->vla-object (entlast)))
  13.   (vla-put-name
  14.     (vla-item (vla-get-blocks
  15.     (vla-get-activedocument (vlax-get-acad-object))
  16.         ) ;_ 结束vla-get-blocks
  17.         (vla-get-name blkref)
  18.     ) ;_ 结束vla-item
  19.     "*U"
  20.   ) ;_ 结束vla-put-name
  21.   (vlax-release-object blkref)
  22.   (setvar "blipmode" holdblip)
  23.   (setvar "cmdecho" holdecho)
  24.   (command "_.undo" "_end")
  25.   (princ)
  26. ) ;_ 结束defun
GMT+8, 2025-9-24 04:51 , Processed in 0.394789 second(s), 26 queries , Gzip On.
