查看: 1819|回复: 2
帮忙看一下这个程序错在哪里?谢谢!
发表于 2003-7-23 15:00:00 | 显示全部楼层 |阅读模式
大家帮忙看看
DCL:
test:dialog{
  :edit_box{label = "Enter"; key="edit1";}
  ok_cancel;
LSP:
(setq a (list "Hello"))
(defun c:test()
(setq sdt 0)
(setq filename(getfiled "请选择DCL文件:" "e:/" "dcl" 8))
(setq id (load_dialog filename))
(if(< id 0)(exit))
(if (not (new_dialog "test" id))(exit))
(set_tile "edit1" (car a))
(action_tile "accept" "(done_dialog 1)(setq a (list (get_tile \"edit1\")))")
(action_tile "cancel" "(done_dialog -1)")
(setq sdt(start_dialog))
(unload_dialog id)
发表于 2003-7-23 16:21:00 | 显示全部楼层
这样
(action_tile "accept" "(setq a (list (get_tile \"edit1\"))) (done_dialog 1)")
,不好意思,上次写的漏了结束对话框了。
 楼主| 发表于 2003-7-24 09:36:00 | 显示全部楼层
谢谢了,程序可以了
GMT+8, 2025-4-4 12:34 , Processed in 0.175958 second(s), 27 queries , Gzip On.
