查看: 1498|回复: 0
Modifying AutoCAD tooltips using .NET
发表于 2011-7-12 10:26:36 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/07/modifying-autocad-tooltips-using-net.html
To continue on the theme established in the last post, today we’re going to go ahead and modify AutoCAD tooltips, prefixing them with a fixed string. This is the next step on the path to modifying them in a more meaningful way (to translate them into a different language, for instance).
Here’s some C# code that implements a command to prefix all AutoCAD tooltips with a silly string (“Kean says this command …“):
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using System.Collections.Generic;
using System.Windows.Controls;
using System.Windows;
namespace PrefixTooltips
  public class Commands
    List<string> _handled = null;
    [CommandMethod("PREFTT")]
    public void PrefixTooltips()
      Document doc =
        Autodesk.AutoCAD.ApplicationServices.Application.
          DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      _handled = new List<string>();
      const string prefix = "Kean says this command ";
      Autodesk.Windows.ComponentManager.ToolTipOpened +=
        (s, e) =>
          Autodesk.Internal.Windows.ToolTip tt =
            s as Autodesk.Internal.Windows.ToolTip;
          if (tt != null)
            Autodesk.Windows.RibbonToolTip rtt =
              tt.Content as Autodesk.Windows.RibbonToolTip;
            if (rtt == null)
              // Basic tooltip
              if (tt.Content is string)
                string contents = (string)tt.Content;
                if (!contents.StartsWith(prefix))
                  tt.Content = prefix + contents;
            else
              // Enhanced tooltips
              if (rtt.Content is string)
                string contents = (string)rtt.Content;
                if (!_handled.Contains(rtt.Command))
                  rtt.Content = prefix + contents;
                  _handled.Add(rtt.Command);
                  if (rtt.ExpandedContent != null)
                    TextBlock tb = rtt.ExpandedContent as TextBlock;
                    if (tb != null)
                      tb.Text = prefix + tb.Text;
                    else
                      StackPanel sp =
                        rtt.ExpandedContent as StackPanel;
                      if (sp != null)
                        foreach (UIElement elem in sp.Children)
                          tb = elem as TextBlock;
                          if (tb != null)
When we run the PREFTT command and hover over ribbon, toolbar or statusbar icons, we see our tooltips – and even their extended content – gets prefixed with our string:
We keep track of tooltips that have already been translated by adding their command-names to a list: we need some tracking mechanism to avoid modifying tooltips multiple times, but this isn’t really optimal (something a bit more intelligent would be better, as – for one thing – this mechanism doesn’t differentiate between toolbars and ribbonbars, which may have different tooltips). All the same, it works reasonably well to prove the concept.
GMT+8, 2026-1-24 11:38 , Processed in 1.975138 second(s), 31 queries , Gzip On.
