查看: 2102|回复: 1
Translating tooltips in AutoCAD, Inventor and Revit using .NET
发表于 2011-7-27 22:23:41 | 显示全部楼层 |阅读模式
作者:kean
原文地址:http://through-the-interface.typepad.com/through_the_interface/2011/07/translating-tooltips-inside-autocad-inventor-and-revit-using-net.html
Once again, it turned out to be pretty straightforward to add Inventor support to our TransTips application. We now have a single solution which builds plugins for AutoCAD, Inventor and Revit. The plugins share a common translation and caching engine as well as a WPF graphical user interface for selecting languages.
Here’s a demonstration of the various plugins in action:
http://www.youtube.com/embed/7YeM1a8rJQo (Youtube链接地址)
I’ve fixed the right-to-left issue highlighted in the video, incidentally.
The next steps are to implement an in-product editing capability and then perhaps to support 3ds Max. One great aspect of this project is that I’m getting to learn a little more about developing for products other than AutoCAD, which is fun. :-)
发表于 2012-11-16 12:33:43 | 显示全部楼层
Very good!
GMT+8, 2025-5-23 12:59 , Processed in 0.160637 second(s), 31 queries , Gzip On.
