查看: 1549|回复: 2
[讨论] 多边形内剪切程序
发表于 2011-8-14 18:29:44 | 显示全部楼层 |阅读模式
请高手看一下多边形内剪切程序,加载后出现:错误: no function definition: GXL-DATA-XD-H
(defun c:edgetrimin (/ kd pl edge en)
  (initget 7 "S")
  (setq kd (getpoint "\n [选择多边形<S>]起点:"))
  (cond ((= "S" kd )
  (while (not (setq edge (gxl-Sel-ENTSEL "\n 请选多边形: "
'((0 . "*Polyline,circle,spline,ELLIPSE"))))))
  (setq edge (car edge))
  (if (WCMATCH (GXL-DXF edge 0) "*POLYLINE" ) (vla-put-Closed
(vlax-ename->vla-object edge) :vlax-true))
((and kd (= 'list (type kd)))
   (SETQ EN (ENTLAST))
   (vl-cmdf "_.pline" kd)
   (while (= 1 (getvar "cmdactive"))
     (vl-cmdf pause)
   ) ;_ while
  (if (not (eq en (entlast)))
    (setq edge (entlast))
    (vla-put-Closed (vlax-ename->vla-object edge) :vlax-true)
    (GXL-DATA-XD-H edge "edgecopyflag")
  (if (not edge)
      (alert "没有选中边界!")
      (abcdefg)
  (GXL-TRIMEDGEIN edge)
  (setq ss (ssget "x" '((-3 ("edgecopyflag")))))
  (if ss (vl-cmdf "_erase" ss ""))
  (reerr)
发表于 2011-8-14 21:05:06 | 显示全部楼层
no function definition: GXL-DATA-XD-H  提示的很明确了.缺少名字叫  GXL-DATA-XD-H    这个的自定义函数.你从哪弄到的代码.找放代码的人把程序要全了先.
发表于 2011-8-14 21:08:55 | 显示全部楼层
百度了下.好像是 Gu_xl  的程序,要不你问问他看
GMT+8, 2025-6-9 23:51 , Processed in 0.144613 second(s), 25 queries , Gzip On.
