查看: 918|回复: 1
选择集的问题
发表于 2011-8-17 16:37:31 | 显示全部楼层 |阅读模式
Sub clear()
   Dim sstext As AcadSelectionSet
   Dim FilterType(0) As Integer
   Dim FilterData(0) As Variant
      On Error Resume Next
      If Not IsNull(ThisDrawing.SelectionSets.Item("Clear")) Then
        Set sstext = ThisDrawing.SelectionSets.Item("Clear")
        sstext.Delete
      End If
         Set sstext = ThisDrawing.SelectionSets.Add("Clear")
   FilterType(0) = 8
   FilterData(0) = "JZD"
   sstext.Select acSelectionSetAll FilterType,FilterData
end sub
如上代码,我想在让选择集sstext在窗口中处于被选中状态,然后执行move命令,改如何操作?
谢谢高手!
发表于 2011-9-19 15:56:11 | 显示全部楼层
for each obj in 选择集
   obj.move basepoint,newpoint
next
大概是这样,研究一下。记不太清MOVE的用法了
GMT+8, 2025-5-25 21:02 , Processed in 0.156650 second(s), 24 queries , Gzip On.
