查看: 1882|回复: 4
請教 dcl中 image_button 該如何寫才能顯示 SLD圖示??
发表于 2011-8-18 09:03:38 | 显示全部楼层 |阅读模式
我附檔內容是可執行lsp 但在dcl中 image_button  沒辨法 顯示出我所做的 sld檔!!
煩請各位前輩 有空指導一下!
該如何修改
謝謝@@
发表于 2011-8-18 09:22:25 | 显示全部楼层
  1. (defun c:test()
  2.    (setvar "cmdecho" 0)
  3.    (dcl_test)
  4.    (prin1)
  5. )
  6. (defun dcl_test()
  7.    (setq dcl_id (load_dialog "test"))   ;更癸杠
  8.    (new_dialog "test" dcl_id)           ;币笆癸杠
  9.
  10.    (start_image "a1")
  11.    (slide_image 0 0 (dimx_tile "a1") (dimy_tile "a1") "a1.sld")
  12.    (end_image)
  13.    (start_image "a2")
  14.    (slide_image 0 0 (dimx_tile "a2") (dimy_tile "a2") "a2.sld")
  15.    (end_image)
  16.
  17.    (action_tile "a1" "(done_dialog 11)")  ;HH
  18.    (action_tile "a2" "(done_dialog 21)")  ;BP
  19.
  20.    (setq dd (start_dialog))               ;盢北ユパDcL北
  21.    (cond ((= dd 11)(c:chg0))
  22.          ((= dd 21)(c:chg1))
  23.    )
  24. )
  25. (defun c:chg0 (/ sel)
  26.   (setvar "cmdecho" 0)
  27.   (setvar "osmode" 0)
  28.   (while(setq sel (ssget))
  29.   (command "change" sel "" "p" "la" "0" "");
  30.   (prompt "\n chghh 跑瓜糷  0"))
  31.   (princ))
  32. ;******************************************************************************************************
  33. (defun c:chg1 (/ sel)
  34.   (setvar "cmdecho" 0)
  35.   (setvar "osmode" 0)
  36.   (while(setq sel (ssget));;ノ匡栋ン匡拒;跑计莱砞﹚跋办跑计
  37.   (command "change" sel "" "p" "la" "1" "")
  38.   (prompt "\n chgbp 跑瓜糷  1"))
  39.   (princ))
謝謝您的指導!!  发表于 2011-8-18 11:35
发表于 2011-8-18 09:28:43 | 显示全部楼层
(defun SLD (key SLD_name / x y)
  (start_image key)
  (setq  x(dimx_tile key)
y(dimy_tile key)
  (fill_image 0 0 x y 0)
  (slide_image 0 0 x y SLD_name)
  (end_image)
(defun c:test()
   (dcl_test)
   (prin1)
(defun dcl_test()
   (setq dcl_id (load_dialog "test"))   //載入對話框
   (new_dialog "test" dcl_id)           //啟動對話框
   (action_tile "a1" "(done_dialog 11)")  //HH
   (action_tile "a2" "(done_dialog 21)")  //BP
   (sld "a1" "a1")
   (sld "a2" "a2")
   (setq dd (start_dialog))               //將控制交由DcL控制
         ((= dd 21)(c:chg1))
  (setvar "osmode" 0)
  (prompt "\n chghh 已變更圖層  0"))
  (princ))
  (setvar "osmode" 0)
  (while(setq sel (ssget));;用選集物件選擇;此變數應設定為區域變數
  (prompt "\n chgbp 已變更圖層  1"))
  (princ))
謝謝您的指導!!  发表于 2011-8-18 10:12
 楼主| 发表于 2011-8-18 10:11:31 | 显示全部楼层
xshrimp 发表于 2011-8-18 09:22
謝謝!!
感謝二位的指導!!!!
发表于 2021-3-16 22:08:39 | 显示全部楼层
感謝二位的指導!!!!
GMT+8, 2025-10-2 03:19 , Processed in 0.162258 second(s), 28 queries , Gzip On.
