查看: 4733|回复: 14
网上找到一个注解输出的lisp,请大家观赏一下
发表于 2011-8-22 22:49:02 | 显示全部楼层 |阅读模式
顺便请高手帮忙看看
里面有个 "对不起!试用期巳过,请安装正版!"
是不是里面写了限制次数的源码在里面帮忙删一下啦
还有里面
请教一下大家比如:导柱孔,弹簧孔,,等等这些。我要怎么画才能让程序识别我的呢??
(cond ((= "LSPM" (strcase str_no_list))
         (setq str_ent1 " 内六角螺丝牙孔(攻牙)"
        str_ent2 "-M"
        str_ent3 (substr nam_no_list 5)
        MI_text  (/ (atof (substr nam_no_list 5)) 2)
        BIG_text MI_text
        ((= "LSPN" (strcase str_no_list))
         (setq str_ent1 " 塞打螺丝(MSB)"
        str_ent2 "-M"
        BIG_text MI_text
        ((= "LSPZ" (strcase str_no_list))
         (setq str_ent1 " 子母螺丝(MSW)"
        str_ent2 "-M"
        BIG_text MI_text
        ((= "LSPP" (strcase str_no_list))
         (setq str_ent1 " 导柱孔(线割,单边%%P0)"
        str_ent2 "-%%C"
        BIG_text MI_text
        ((= "LSPF" (strcase str_no_list))
         (setq str_ent1 " 导套孔(线割,单边%%P0,%%c背面沉深3.5)"
        str_ent2 "-%%C"
        BIG_text (+ 5 MI_text)
        ((= "LSPD" (strcase str_no_list))
         (setq str_ent1 " 定位销孔(线割,单边+0.00)"
        str_ent2 "-%%C"
        BIG_text MI_text
        ((= "LSPG" (strcase str_no_list))
         (setq str_ent1 " 浮升销孔(线割,单边+0.01)"
        str_ent2 "-%%C"
        BIG_text MI_text
        ((= "LSPL" (strcase str_no_list))
         (setq str_ent1 " 顶料销孔(线割,单边+0.01)"
        str_ent2 "-%%C"
        BIG_text MI_text
        ((= "LSPS" (strcase str_no_list))
         (setq str_ent1 " 弹簧孔(钻通)"
        str_ent2 "-%%C"
        BIG_text MI_text
        ((= "LSPH" (strcase str_no_list))
         (setq str_ent1 " 导正销孔(线割,单边+0.005,%%C正面沉深*)"
        str_ent2 "-%%C"
        BIG_text MI_text
        ((= "LSPA" (strcase str_no_list))
         (setq str_ent1 " 冲子(TA)"
        str_ent2 "-%%C"
        BIG_text (+ 1.5 MI_text)
         (if (> (atof str_ent3) 18)
    (setq str_ent3 (strcat (substr nam_no_list 5 1)
      (substr nam_no_list 6)
          MI_text (/ (atof str_ent3) 2)
        ((= "LSPC" (strcase str_no_list))
         (setq str_ent1 " 冲子(SH)"
        str_ent2 "-%%C"
        ((= "LSPE" (strcase str_no_list))
         (setq str_ent1 " 抽牙冲子(TE)"
        str_ent2 "-%%C"
        ((= "LSPW" (strcase str_no_list))
         (setq str_ent1 "的异形孔(线割,单边+0.00)"
        str_ent2 "-穿丝孔为%%C"
           (substr nam_no_list 6 1)
        BIG_text MI_text
        ((= "LSPR" (strcase str_no_list))
         (setq str_ent3 (substr nam_no_list 5)
        str_ent1 (strcat " 螺丝沉头孔(正面沉头深度*) "
           insert_3
        str_ent2 "-M"
        BIG_text (+ 2 MI_text)
        ((= "LSPB" (strcase str_no_list))
        str_ent1 (strcat " 螺丝沉头孔(背面沉头深度*) "
           insert_3
        str_ent2 "-M"
        (t
         (setq str_ent1 nam_no_list
        str_ent2 "-"
        str_ent3 "(线割,单边+0.00)"
        MI_text  4
        BIG_text 6
这些代码是啥意思
我要怎么画它才能认别
我是菜鸟哦
好东西,谢谢  发表于 2012-3-16 14:05
发表于 2021-12-21 03:53:18 | 显示全部楼层
nxchenjk 发表于 2011-8-30 22:42
(> cdat 20000430)改为(> cdat 30000430) 可用到3000年4月30号
也不行,,,,,,,,
发表于 2021-12-21 08:41:49 | 显示全部楼层
  (setq cdat (atoi (rtos (getvar "cdate"))))
  (if (> cdat 0)
发表于 2017-9-12 14:14:22 | 显示全部楼层
这种杂乱的LSP画五金模具很痛苦的,去网上下了下TASIPRESSCAD,有系统的功能,购正版也几百块钱.
发表于 2011-8-30 15:00:41 | 显示全部楼层
不错挺实用的
发表于 2011-8-30 17:44:13 | 显示全部楼层
用途?用法?
发表于 2011-8-30 22:42:10 | 显示全部楼层
 楼主| 发表于 2011-9-3 13:20:46 | 显示全部楼层
我是想问一下大家 的是:比如说导柱孔,弹簧孔等这些要怎么画程序才能识别呢??
发表于 2011-9-4 20:16:19 | 显示全部楼层
看你的这个是用块名判断的吧,统赢用的是扩展数据,我做这个模板标注也是用扩展数据
发表于 2011-9-5 21:53:08 | 显示全部楼层
扩展数据-3
发表于 2011-9-5 22:43:06 来自手机 | 显示全部楼层
高深的lsp,...
发表于 2011-10-10 15:11:12 | 显示全部楼层
不错的分享~~~!!!
发表于 2011-10-10 15:19:49 | 显示全部楼层
谢谢分享
GMT+8, 2025-5-16 07:04 , Processed in 0.187537 second(s), 32 queries , Gzip On.
