- (DEFUN C:LBOX () (SETQ DCL_ID (LOAD_DIALOG "C:/LBOX.DCL") CHK 0)
- (NEW_DIALOG "LBOX" DCL_ID)
- (ADDL)
- (ACTION_TILE "LBOX_l" "(SETQ TMP_R (ATOI (GET_TILE\"LBOX_L\")))(SETC)")
- (ACTION_TILE "accept" "(SETQ CHK 1
- TMP_S (GET_TILE \"LBOX_E\"))(DONE_DIALOG)")
- (START_DIALOG) (UNLOAD_DIALOG DCL_ID)(IF (= CHK 1)
- (COMMAND "TXT" (GETPOINT \"Select text insert point :")"0" TMP_S)
- (PRINC))
- (DEFUN ADDL() (SETQ F_ID (OPEN "C:/TEXT1.TXT" "r"))
- (SETQ TMP_T (READ-LINE F_ID) TMP_L (LIST ""))
- (WHILE (/= TMP_T NIL)
- (SETQ TMP_L (APPEND TMP_L (LIST TMP_T)))
- (SETQ TMP_L (READ-LINE F_ID)))
- (CLOSE F-ID)
- (SETQ TMP_L (LIST (CDR TMP_L)))
- (START_LIST "LBOX_L" 3 0)
- (MAPCAR 'ADD_LIST (CAR TMP_l))
- (END_LIST))
- (DEFUN SETC() (SETQ F_ID (OPEN "C:TEXT1.TXT" "r"))
- (IF (> TMP_R 0)
- (REPEAT TMP_R (REAN-LINE F_ID)))
- (SETQ TMP_S (GET_TILE "LBOX_E"))
- (SETQ TMP_S (STRCAT TMP_S (READ-LINE F_ID)))
- (CLOSE F_ID)
- (SET_TILE "LBOX_E" TMP_S))
- LBOX:dilalog{ label="Create chinese";
- :list_box //清单选框元件
- { label="中文字";
- key="LBOX_L";
- width=25;
- height=8;
- fixed_width=true;
- fixed_height=true;
- :edit_box
- { label="中文字";
- key="LOBX_E";
- width=25;
- fixed_width=true;
- ok_cancel}
