查看: 2349|回复: 0
构建闭合的样条曲线
发表于 2011-9-5 21:20:45 | 显示全部楼层 |阅读模式
Spline(
System.Int32 degree,
System.Boolean rational,
System.Boolean closed,
System.Boolean periodic,
Autodesk.AutoCAD.Geometry.Point3dCollection controlPoints,
Autodesk.AutoCAD.Geometry.DoubleCollection knots,
Autodesk.AutoCAD.Geometry.DoubleCollection weights,
System.Double controlPointTolerance,
System.Double knotTolerance)
,怎样用上述构造函数,创建闭合的样条曲线?最好能有个参照的例子.在此先谢谢了。
GMT+8, 2025-4-22 16:27 , Processed in 0.172063 second(s), 25 queries , Gzip On.
