- 积分
- 4948
- 明经币
- 个
- 注册时间
- 2004-6-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
- ;;LayerISO & LayerunISO
- ;;color fade scale , 0~90 , fitable 50~75 .
- (setq #gsls_color_fade# 75)
- (defun c:myLayISO (/ *error* om oc oe ss lst ssen la)
- ;;by GSLS(SS) 2011-09-16
- (setq om (getvar "MODEMACRO")
- oc (getvar "cmdecho")
- oe *error*
- (defun *error* (msg)
- (command)
- (command)
- (if (or (= msg "Function cancelled")
- (= msg "quit / exit abort")
- (princ msg)
- (princ (strcat "\n错误: " msg))
- (setvar "MODEMACRO" om)
- (setvar "cmdecho" oc)
- (setq *error* oe)
- (vla-EndUndoMark
- (vla-get-ActiveDocument (vlax-get-acad-object))
- (vla-startundomark
- (vla-get-activedocument (vlax-get-acad-object))
- (setvar "MODEMACRO" "选择要隔离的图层上的对象:")
- (setvar "cmdecho" 0)
- (setq ss (ssget))
- (if ss
- (progn
- (setq ssen (ss2lst ss nil))
- (foreach a ssen
- (if (not (member (setq la (dxf 8 (entget a))) lst))
- (setq lst (cons la lst))
- (ss:layer:iso lst)
- (princ "\n未选择对象,请重新执行命令.")
- (vla-EndUndoMark
- (setq *error* oe)
- (princ)
- (defun c:myLayUnISO (/ *error* oc oe)
- (setq oc (getvar "cmdecho")
- oe *error*
- (command)
- (command)
- (princ msg)
- (setq *error* oe)
- (vla-EndUndoMark
- (ss:layer:uniso)
- (ss:layer:on)
- (vla-EndUndoMark
- (setq *error* oe)
- (princ)
- (defun ss:layer:ISO (l / las ent col lay tc)
- (setq las (xyp-get-tblnext "LAYER"))
- (while las
- (setq lay (car las)
- las (cdr las)
- ent (entget (TblObjName "layer" lay))
- (if (and (not (member lay l))
- (/= (logand 1 (dxf 70 ent)) 1)
- (/= (logand 2 (dxf 70 ent)) 2)
- (> (dxf 62 ent) 0)
- (progn (setq col (dxf 62 ent)
- tc (dxf 420 ent)
- (vlax-ldata-put "date" lay (list col tc))
- (if tc
- (setq col (ss:color:true:fade tc))
- (setq col (ss:color:aci:fade col))
- (Entmod
- (ch-en (cons 420 col) (subst (cons 70 4) (cons 70 0) ent))
- ;;ADD regen
- ;_(setq ti (car (_VL-TIMES)))
- (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object))
- acActiveViewport
- ;_(princ(strcat"\n "(rtos(/ (- (car (_VL-TIMES)) ti) 1000.)2 4)" secs."))
- (defun ss:layer:uniso (/ las lay ent col tc)
- (while las
- las (cdr las)
- (if (and (= (logand 4 (dxf 70 ent)) 4)
- (progn
- (if (and (setq col (vlax-ldata-get "date" lay))
- (setq tc (cadr col))
- (setq
- ent (ch-en (cons 62 (car col)) (ch-en (cons 420 tc) ent))
- (setq ent (ch-en (cons 62 (car col))
- (vl-remove (assoc 420 ent) ent)
- (setq ent (ch-en (cons 70 0) ent))
- (vlax-ldata-delete "date" lay)
- (Entmod ent)
- acActiveViewport
- (defun ss:layer:on (/ las lay ent col)
- (foreach lay las
- (setq ent (entget (TblObjName "layer" lay)))
- (if (or (= (logand 1 (dxf 70 ent)) 1) (= (logand 2 (dxf 70 ent)) 2))
- (princ (strcat "\n图层" lay "处于冻结状态**"))
- (if (< (setq col (dxf 62 ent)) 0)
- (progn
- (entmod (ch-en (cons 62 (- col)) ent))
- (princ (strcat "\n图层" lay "已打开。"))
- (defun xyp-get-tblnext (table-name / lst d)
- ;;by xyp1964
- (while (setq d (tblnext table-name (null d)))
- (setq lst (cons (dxf 2 d) lst))
- (reverse lst)
- (defun dxf (co en)
- (if(eq(type en)(quote ENAME))(setq en(entget en(quote("*")))))
- (if(vl-consp co)(mapcar (function (lambda (x)(cdr (assoc x en))))co)
- (cdr (assoc co en))))
- (defun ch-en (co en /)
- (if (eq (type en) (quote ename))
- (setq en (entget en (list "*")))
- (if (assoc (car co) en)
- (subst co (assoc (car co) en) en)
- (append en (list co))
- ;;; aci fade -> true
- (defun ss:color:aci:fade (c / r h )
- ;;by GSLS(SS)
- ;;key fun ...
- (setq r (lm:aci->rgb c))
- (setq h (apply (function lm:rgb->hsl ) r)
- h (append (butlast h) (list (fix (round (* (last h) (- 100 #gsls_color_fade#) 0.01) 0))))
- (apply (function lm:rgb->true) (apply (function lm:hsl->rgb ) h))
- ;;; true fade -> true
- (defun ss:color:true:fade (c / r h )
- ;;by GSLS(SS)
- ;;key fun ...
- (setq r (lm:true->rgb c))
- (defun butlast(a)
- (reverse (cdr(reverse a)))
- (defun ss2lst (ss vla / a e i)
- (if (= (type ss) (quote PICKSET))
- (progn
- (setq i -1)
- (while (setq e (ssname ss (setq i (1+ i))))
- (if vla
- (setq e (vlax-ename->vla-object e))
- nil
- (setq a (cons e a))
- nil
- (defun round (a jd / b)
- (setq b (expt 10.0 jd))
- (/ (fix (+ (* a b) 0.5)) b)
- ;;following codes written by LeeMac
- ;;copy from
- ;; [url=http://www.lee-mac.com/colourconversion.html]http://www.lee-mac.com/colourconversion.html[/url]
- ;; True -> RGB - Lee Mac 2011
- ;; Args: c - True Colour
- (defun LM:True->RGB ( c )
- (list
- (lsh (lsh (fix c) 8) -24)
- (lsh (lsh (fix c) 16) -24)
- (lsh (lsh (fix c) 24) -24)
- ;; RGB -> True - Lee Mac 2011
- ;; Args: r,g,b - Red,Green,Blue values
- (defun LM:RGB->True ( r g b )
- (lsh (fix r) 16)
- (lsh (fix g) 8)
- (fix b)
- ;; OLE -> True - Lee Mac 2011
- ;; Args: c - OLE Colour
- (defun LM:OLE->True ( c )
- (lsh (lsh (lsh (fix c) 24) -24) 16)
- (lsh (lsh (lsh (fix c) 16) -24) 8)
- ;; True -> OLE - Lee Mac 2011
- (defun LM:True->OLE ( c )
- ;; RGB -> HSL - Lee Mac 2011
- (defun LM:RGB->HSL ( r g b / _round d h l m n s )
- (setq r (/ r 255.)
- g (/ g 255.)
- b (/ b 255.)
- n (min r g b)
- m (max r g b)
- d (- m n)
- l (/ (+ m n) 2.)
- (defun _round ( n )
- (fix (+ n (if (minusp n) -0.5 0.5)))
- (mapcar '_round
- (cond
- ( (zerop d)
- (list 0 0 (* m 100))
- (t
- (setq s (if (< l 0.5) (/ d (+ m n)) (/ d (- 2. m n))))
- (setq h
- (cond
- ( (= g m) (+ (/ (- b r) d) 2))
- ( (= b m) (+ (/ (- r g) d) 4))
- ( (/ (- g b) d))
- (list (rem (+ 360 (* h 60)) 360) (* s 100) (* l 100))
- ;; HSL -> RGB - Lee Mac 2011
- ;; Args: 0 <= h <= 360, 0 <= s,l <= 100
- (defun LM:HSL->RGB ( h s l / _sub _round u v )
- (setq h (/ h 360.)
- s (/ s 100.)
- l (/ l 100.)
- (defun _sub ( u v h )
- (setq h (rem (1+ h) 1))
- (cond
- ( (< (* 6 h) 1) (+ u (* 6 h (- v u))))
- ( (< (* 2 h) 1) v)
- ( (< (* 3 h) 2) (+ u (* 6 (- (/ 2. 3.) h) (- v u))))
- ( u )
- (mapcar '_round
- (mapcar '* '(255 255 255)
- (cond
- ( (zerop s)
- (list l l l)
- ( (zerop l)
- '(0 0 0)
- (t
- (setq v (if (< l 0.5) (* l (1+ s)) (- (+ l s) (* l s)))
- u (- (* 2 l) v)
- (mapcar '(lambda ( h ) (_sub u v h)) (list (+ h (/ 1. 3.)) h (- h (/ 1. 3.))))
- ;; True -> ACI - Lee Mac 2011
- (defun LM:True->ACI ( c / cObj aci ) (vl-load-com)
- (if
- (and
- (setq cObj
- (vla-getInterfaceObject (vlax-get-acad-object)
- (strcat "AutoCAD.AcCmColor." (substr (getvar 'ACADVER) 1 2))
- (not
- (vl-catch-all-error-p
- (vl-catch-all-apply 'vla-SetRGB (cons cObj (LM:True->RGB c)))
- (setq aci (vla-get-ColorIndex cObj))
- (if cObj (vlax-release-object cObj))
- aci
- ;; ACI -> True - Lee Mac 2011
- ;; Args: c - ACI (AutoCAD Colour Index) Colour
- (defun LM:ACI->True ( c / cObj tc ) (vl-load-com)
- (if
- (and (<= 1 c 255)
- (setq cObj
- (not
- (vl-catch-all-apply 'vla-put-ColorIndex (list cObj c))
- (setq tc (LM:RGB->True (vla-get-Red cObj) (vla-get-Green cObj) (vla-get-Blue cObj)))
- tc
- ;; ACI -> RGB - Lee Mac 2011
- (defun LM:ACI->RGB ( c / cObj rgb ) (vl-load-com)
- (if
- (and (<= 1 c 255)
- (setq cObj
- (not
- (setq rgb (list (vla-get-Red cObj) (vla-get-Green cObj) (vla-get-Blue cObj)))
- rgb
- ;; RGB -> ACI - Lee Mac 2011
- (defun LM:RGB->ACI ( r g b / cObj aci ) (vl-load-com)
- (if
- (and
- (setq cObj
- (not
- (vl-catch-all-apply 'vla-SetRGB (list cObj r g b))
- aci
