查看: 1998|回复: 1
vba 如何控制动态块的可见性状态?
发表于 2011-9-14 22:06:56 | 显示全部楼层 |阅读模式
  大家好,我想用vba判断块的 Visibility的属性是“45度”还是“60度”,如何写代码?谢谢
有如下两种:
{      Block Name: "YTZK"
   Anonymous Name: "*U192"
                at point, X=3145.00000000  Y=3930.00000000  Z=0.00000000
   X scale factor: 1.00000000
   Y scale factor: 1.00000000
   rotation angle:     49
   Z scale factor: 1.00000000
  Scale uniformly: No
  Allow exploding: Yes
       Visibility: 45度}
{Block Name: "YTZK"   Anonymous Name: "*U200"                at point, X=3145.00000000  Y=3930.00000000  Z=0.00000000   X scale factor: 1.00000000   Y scale factor: 1.00000000   rotation angle:     49   Z scale factor: 1.00000000  Scale uniformly: No  Allow exploding: Yes       Visibility: 60度}
发表于 2011-12-21 13:20:11 | 显示全部楼层
首先选择一个块实体,再用GetAttributes取得属性,遍历各个属性,找到visibility标签对应的值,就可以判断这个属性是否是需要的。因为没有具体的图和要求,不然可以给你一段代码,联系我吧。QQ:38968681
GMT+8, 2025-5-25 16:54 , Processed in 0.165200 second(s), 24 queries , Gzip On.
