查看: 4926|回复: 19
TEXT的DCL版 (明镜亦非台)
发表于 2011-9-18 01:17:53 | 显示全部楼层 |阅读模式
                             为庆祝论坛发言不乱码,特贴上我这个dcl处女作
;网上收集大部分素材,整理所得。感谢各位前辈
;通过读写txt文件的方式记录上次注记的字高和角度
;其中或许图上所有图层和文字样式的程序是网上收集的,感觉很爽感。。。
;整理 by  明镜亦非台(yanshengjiang)
; ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^ ^_^
;文字注记对话框版,替换南方cass的T命令效果还行
;智能记住上次注记的字高和旋转角度
;文字注记  2011年9月6日 21:00:20  by yanshengjiang
(defun c:t(/ te h x pt sty lay style layer dcl_id dcl_file lujin file d dd len pop layer2 layername)
  (setvar "cmdecho" 0)
  (setq te nil pt nil sty nil lay nil h nil)
  (vl-catch-all-apply
    '(lambda();出错回显
(text2-dcl_te)
(if (= te "")
   (exit)
   (if (= sty nil) (setq sty (nth 0 style)))
   (if (= lay nil) (setq lay (nth 0 layer)))
   (if (= x nil)(setq x "0"))
  (if (/= nil te)
;(entmake (list '(0 . "TEXT") '(100 . "AcDbEntity") '(100 . "AcDbText") '(62 . 256)
;(CONS 1 te) (CONS 10 pt)(cons 40 (read h)) '(41 . 0.8) '(50 . 0.0)(cons 8 lay)(cons 7 sty)  ))
    (setq pt (getpoint"\n指定点"))
    (command "_.text" "s" sty "j" "m" pt h x te "_.change" (entlast) "" "p" "la" lay "")
);if
  (xie-text2-txt)
  (unload_dialog dcl_id)
  (vl-file-delete Dcl_File)
));if progn
       ));出错回显
);defun
(defun text2-dcl_te();驱动
  (setq dcl_id (load_dialog (setq Dcl_File (text2-dclfottext))))
  (new_dialog "text2" dcl_id)
  (set_tile "te" "")
  (du-text2-txt)
  (if (= nil h)(setq h "1.5"))
  (if (= nil x)(setq x "0"))
  (set_tile "h" h)
  (set_tile "x" x)
      (setq style (cyanqq))
      (setq layer (get_all_layer))
      (show_list_yan "sty" style)
      (show_list_yan "lay" layer)
    (action_tile "sty" "(setq pop 1)(sub_pop $value)")
    (action_tile "lay" "(setq pop 2)(sub_pop $value)")
  (action_tile "accept" "(text2-ok_te)(done_dialog 1)")
  (start_dialog)
(defun text2-ok_te();驱动
  (setq te (vl-princ-to-string (get_tile "te")))
  (setq h (vl-princ-to-string (get_tile "h")))
  (setq x (vl-princ-to-string (get_tile "x")))
  ;(setq sty(get_tile "sty"))
; (setq lay(get_tile "lay"))
;写dcl
(defun text2-dclfottext()
  (setq Dcl_File (vl-filename-mktemp nil nil))
  (setq lujin(vl-filename-directory Dcl_File))
  (setq Dcl_File (strcat lujin "\\文字注记.dcl"))
  (setq file (open Dcl_File "w"))
  (write-line "text2:dialog{" file)
  (write-line " label= \"文字注记                    \";" file)
  (write-line " :edit_box{label=\"文字内容\";key=\"te\";edit_width=70;fixed_width = true;}" file)
  (write-line " :boxed_row{" file)
  (write-line " :edit_box{label= \"文字高度\"; key= \"h\";edit_width=3;fixed_width = true;}"  file)
  (write-line " :edit_box{label= \"旋转角度\"; key=\"x\";edit_width=3;fixed_width = true;}"  file)
        (write-line ": popup_list {label=\"样式\";key = \"sty\";edit_width = 10;fixed_width = true;fixed_width = true;}" file)
        (write-line ": popup_list {label=\"图层\";key = \"lay\";edit_width = 10;fixed_width = true;fixed_width = true;}" file)
        (write-line "spacer_1;" file)
  (write-line "              }" file)
  (write-line "                ok_cancel;" file)
   (close file)
  Dcl_File
;写txt
(defun xie-text2-txt()
  (setq text2-txt_File (vl-filename-mktemp nil nil))
  (setq lujin(vl-filename-directory text2-txt_File))
  (setq text2-txt_File (strcat lujin "\\文字注记.txt"))
  (setq file (open text2-txt_File "w"))
  (write-line (strcat "字高:" h) file)
  (write-line (strcat "旋转:" x) file)
  (close file)
;读txt
(defun du-text2-txt()
(if (setq file (open text2-txt_File "r"))
  (while
    (setq d (read-line file))
    (setq len (strlen d))
    (if (/= 0 len)
(setq dd(substr d 1 4))
  (if (= dd "字高")(setq h (substr d 6 (- len 5))))
  (if (= dd "旋转")(setq x (substr d 6 (- len 5))))
  (defun get_all_style (/ sty style sty_list);得到图内所有字体样式
    ;;;示例  ("FS" "HT" "HZ" "KHZ" "STANDARD" "等线体" "仿宋体" "楷体" "宋体")
    (setq sty_list nil
   sty (tblnext "style" t)
    (setq style (cdr (assoc 2 sty)))
    (while style
      (if (/= "" style)
(setq sty_list (append
    sty_list
    (list style)
      (setq sty (tblnext "style"))
    )           ; end while]
    (setq sty_list (ACAD_Strlsort sty_list))
    sty_list
  ); end defun
(defun cyanqq(/ style n x nt xh st)
  (setq style (get_all_style));得到字体列表
;;;  (mapcar  '(lambda (x) (= x "HZ")) style)
  (setq n (vl-list-length style));表内元素个数
  (setq x 0)
(while (< x n);
    (setq nt (nth x style))
    (if (= nt "HZ");
      (progn;
(setq xh x)
(setq x n)
      );progn
    );if
(setq x (1+ x))
    );while
  (if (and(<= xh n)(= nt "HZ"))
    (Setq st (cons "HZ" (vl-remove "HZ" style)))
    (setq st style)
    );if
);defun
  (defun get_all_layer (/ lay layer2 layname);;;;;得到图层列表。。。
    (setq layer2 nil
   lay (tblnext "LAYER" T)
    (while (/= lay nil)
      (setq layname (cdr (assoc 2 lay))
     layer2 (cons layname layer2)
      (setq lay (tblnext "LAYER"))
    (setq layer2 (ACAD_Strlsort layer2))
    layer2
;=======================显示下拉列表=============================
(defun show_list_yan(key newlist)
   (start_list key)
   (mapcar 'add_list newlist)
   (end_list)
;=======================设置下拉内容=============================
(defun sub_pop(vvs)
   (if (= pop 1)(setq sty (nth (atoi vvs) style)))
   (if (= pop 2)(setq lay (nth (atoi vvs) layer)))
参与人数 3明经币 +1 金钱 +50 收起 理由
jicqj + 1 + 20 很给力!
hhh454 + 10 很给力!
zctao1966 + 20 赞一个!
发表于 2019-6-26 12:01:32 | 显示全部楼层
非常不错,谢谢分享啊
发表于 2019-6-29 00:33:53 来自手机 | 显示全部楼层
留名收藏了
发表于 2019-6-26 13:15:50 | 显示全部楼层
真的不錯用!!
 楼主| 发表于 2011-9-18 01:18:35 | 显示全部楼层
卖沙发了。吼吼
发表于 2011-9-18 21:52:12 | 显示全部楼层
学习,不错
 楼主| 发表于 2011-9-18 22:29:02 | 显示全部楼层
  (setq No (vl-position "HZ" style))
  (if (/= No nil)
    (setq st style)
    );if
  );defun
发表于 2011-9-19 06:38:16 | 显示全部楼层
两个cyanqq函数有什么区别?
发表于 2011-9-19 07:07:05 | 显示全部楼层
先支持后学习!
发表于 2011-9-19 08:44:34 | 显示全部楼层
試了一下
真的不錯用!!
 楼主| 发表于 2011-9-19 09:50:29 | 显示全部楼层
Michael527 发表于 2011-9-19 06:38
两个cyanqq函数有什么区别?
功能一样的前提下,精简了很多撒。。。
发表于 2011-9-19 12:24:05 | 显示全部楼层
支持原创!
发表于 2011-9-20 09:00:29 | 显示全部楼层
支持,喜欢
GMT+8, 2025-5-18 22:58 , Processed in 0.794736 second(s), 30 queries , Gzip On.
